Question about Maytag Refrigerators
Msf25c2exwoo Remove ice bucket
Cannot get the ice bucket out.
Take a hair blower and defrost it
Dec 31, 2015 | Refrigerators
We have a Samsung RF4287HARS french door refrigerator. The ice maker seemed to not be working properly and I tried to pull out the ice bucket and it will not budge. Any suggestions as to why we can't...
I would suggest that the ice bucket has water around the base and that has frozen the bucket bin place . If you can, try filling the bucket with hot water to loosen the ice around the base.
Feb 11, 2015 | Samsung Refrigerators
How to release jammed ice maker bucket
you have ice stuck in it . best thing to do so you dont damage it is to defrost it/remove/clean .
Jan 23, 2015 | Refrigerators
Freezer temp flashing post removal of ice bucket components - is this why?
Possibly because of ice build-up under ice bucket, a common occurrence. It needs to be removed and wiped off periodically. And the ice sometimes makes it difficult to remove the ice bucket, so you may need to use some warm (not hot) water in a spray bottle (squirt warm water under the seam at bottom of bucket) to get it loose. Of course, this is all assuming the bucket is the type attached to the door.
Dec 15, 2014 | Refrigerators
Dispenses crushed ice only, not cubed
remove the dispenser bucket where the ice drops into inside the freezer and get a Tupper ware bowl,remove the bucket and dump this ice into the bowl,then rinse with the dispenser bucket with warm tap water to melt any ice on each end of this ice maker,then wipe dry and replace into freezer where you removed it to get cold again and leave empty till the next harvest of ice,this can be normal on some units after so many weeks,as it will not let the blades retract so as just to dispense only cubes,once bucket is cleaned of ice jams the solenoid and blades will again retract for cubes only
Feb 10, 2013 | Refrigerators
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
WILL NOT MAKE SWITCH FROM CUBE ICE TO CRUSHED I CE
remove bucket,empty into large bowel. inspect bucket opening,and be sure ther are no chunks of ice hindering movement of blade bypass mech. w/bucket out operate ice disp on crushed and cubed selections,listen for sharp snapping sound before motor turns.if sound is heard,reinstall bucket,and you should be good to go
Mar 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Auger inside the ice bucket not turning - ice not dispensing
I had same problem. Fixed it by remove the motor at the back and spraying with wd40.
v_rampersad@hotmail.com
Dec 17, 2008 | GE GSS25SGMBS Side by Side Refrigerator
Ice maker arm issue
If you are a real DIY'er, remove the ice maker from the frig and see if the arm has or had a spring return down or check its position with the cam that operates it as it goes around.
May 29, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
