Question about Roku LT
Have a Roku LT. Plujgged in red yellow white on Roku and tv. Turned TV on.Hit OK on remote. Nothing happened.
I can't get it to work. Need to register an account?
  • Roku Expert
  • 138 Answers
Please make sure to set the input source of your TV to the correct source... since you're using Red Yellow White cable, select Video.
Posted on Jan 28, 2014
2 Suggested Answers
tgvern
  • 281 Answers
SOURCE: Can't get Roku N1100 to
Make sure you select the correct input for your device. If you are using RCA cables then select the RGB option on your inputs, or it may RCA as a connection. If you are using HDMI then make sure that is selected.
Posted on Dec 10, 2011
How to hook up a Roku2 to Sony KLV-S32A10 TV with A/V cable (yellow/red/white Ports)
If you plug into the box and TV with the composite plugs then you need to change inputs. Your TV is currently set to use HDMI. You need to change the source with your remote.
Dec 25, 2014 | Roku 2 HD
Can I hook up my roku device to this tv If so what kind of cable do I need?
On the back of the TV/VCR unit there is an input for audio & video plugs. These will accept a composite video signal and mono audio signal. I'm not sure if newer roku has these outputs as they are low def only signals. The roku would need to have have red, white & yellow sockets. (Old Roku's had these....) Yellow is video, red and white are L & R audio. Use a y adapter to merge red & white together, and use a standard RCA patch cord to connect the roku composite outputs to the TV VCR inputs.
May 01, 2014 | GE 19TVR62 19 in. TV/VCR Combo
Can I plug my roku into the red, yellow & white inputs at the side of my tv (video 2)
No, yours will do composite yellow to video, red and white are sound. or hdmi thin flat
Mar 07, 2014 | Televison & Video
Connect roku tv
Yes, if they are red white (are audio) yellow (is video) not, green blue and red this are for video only.
Mar 07, 2014 | Office Equipment & Supplies
I only have on set of white, yellow & red receptors on back of tv. There is a set (entitled Video 2) on the side of the tv.1st - can I attach the Roku to the receptors at the side of the tv or2nd - i...
You didn't say which Roku you have, so I will assume you have a Roku 3 since it's the only one without RCA output jacks (the red, white, and yellow jacks you mention). You can return the Roku 3 and get a Roku 2. You can only attach the Roku to a switching box if 1) the Roku has the RCA outputs and your switch has A/V inputs. If you DO have the Roku 3, then you may be able to purchase a HDMI to RCA cable from Amazon http://www.amazon.com/HDMI-RCA-VGA-Cable-1-8m/dp/B002ZUI68G
Mar 03, 2014 | Televison & Video
I can't get the video to work so I can use my roku. How can I watch roku?
Which way did you connect the roku? HDMI or with the yellow,red and white RCA cable? If you used the HDMI cable, look on the TV to see what number is on the input port. Select that number when you use the input button on the tv or the remote. Same goes for the RCA cables. Each input has a number next to it.
Sep 01, 2013 | Insignia NS-RC03A-13 Remote Control...
I am trying to install ROKU video streamer into my Sharp TV model 27KS300. Roku says to plug their red/yellow/white RCA cable into the video in ports on your TV. I do this but nothing happens. I am...
Yes these are the same yellow white and red ports that you would use to connect your DVD player. I believe this television has one port in the front and one in the back. I might be wrong but I believe video 1 is in the back and video 2 is in the front. If you have tried video 1 and video 2 making sure you have pressed the video/input button to select the proper one after connecting your Roku then you have done everything properly. Make sure to try a different RCA cable to make sure it is not the cable that is causing the problem. Also try the Roku on a different television because if it is working on a different television with the same RCA cable then you'll know that it isn't compatible with this particular television.
Apr 13, 2011 | Sharp 27K-S300 27" TV
I have a RCA model 24V511T can I hook up a roku receiver to view Netfliks etc from the internet. I have hooked up the red white yellow connectors to the input ports on the tv set and nothing happens?
First of all, make sure all components are powered up and plugged in. Next, check that your tv is set to the correct input by pressing tv/video or input button on either the front of your tv or at your remote. Scroll through the inputs by continuously pressing the input button until the see the roku video displayed on your tv.
Good Luck
Jan 07, 2011 | RCA 24V511T 24" TV
My ps2 wont work on the TV
so back your tv input says yellow red and white should be sterio in unless its mono tv then just use white then in front hit ch down past 2 to go into inputs to see ps2 ok
Feb 10, 2008 | Sanyo DS31590 31" TV
Roku LT Logo
81 people viewed this question
Top Roku Televison & Video Experts
David Payne
David Payne
Thomas Stauber
Thomas Stauber
ray gallant
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
