I always get a non-white background when printing a scan of a child's drawing where the child has used colour markers on very white thick drawing paper. The background may be grey, pinkish etc and very feint but it is definitely not as white as the original drawing p[aper.
    Sergeant:
  • 296 Answers
Hi
chek this site to get your required answer for gettin white back ground while printing a scanned drawing.
http://www.sceptre.com/Support/Faq/scanner300.htm#6
all the best
thankyou.
Posted on May 18, 2009
My Canon e510 printer scanner scans with full red background
hi . if the light is not white the image sensor unit is defective and has to be replacex
Apr 29, 2017 | Canon Office Equipment & Supplies
Wont print in full black, does print in grey or any other colour.
Assuming you are using MS Excel, try going into page setup, sheet, and check the setting for 'print black & white'. If it is checked, then try unchecking it.
Apr 18, 2016 | Office Equipment & Supplies
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Jun 27, 2013 | Canon DR-5010C Scanner
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
Dec 29, 2010 | Office Equipment & Supplies
Corel-DRAW 12 UNABLE TO EMBED (COLOR) JPG ONTO COLOR BACKGROUND
Right click the graphic and choose the image tools and you wil find an option for color and one for B&W. Play with those to find the problem. That should solve it
Michael
Feb 26, 2009 | Corel WordPerfect Office 12 Standard...
Internal test page fine, external prints black in blue
before you print, you have to check your options.
For example, if you want to print black and white, when you select PRINT from the menu, you click on PROPERTIES to the right side or bottom side, depending on which windows you use, then select grayscale/black and white, etc in the options that will follow to correctly use your ink, you can always REMOVE the ink from your printer as you only want to print black and white or non color pages.
I hope this helps you.
ManOwar
Jul 12, 2008 | HP DeskJet 845c Printer
When printing a scanned object, paper is all gray
Whatever scanning utility you are using, set it to Black and white, not grayscale nor colour! regards, babb
May 05, 2007 | Umax Astra 610P Flatbed Scanner
Will not print white on black
hi you need to change the font colour of your priter == for this you can go to the properties of the printer and change the colour = this may help you = Good Luck
Apr 27, 2007 | SATO CL 408 Thermal Label Printer
k24674
jasbo
jasbo
