Question about Dryers
Klimaire ptac unit has e3 error code what does this mean
  • 1314 Answers
SOURCE: Error e3?
i need your serial num its important 17
Posted on Jan 04, 2008
SOURCE: kenwood dishwasher kdw12st3a error code
in the manual I have for this machine model E3 means: Longer heating time but not reaching requied temperature. The possible causes: malfunction of temperature sensor or of heating element
Posted on Aug 12, 2008
  • 3 Answers
SOURCE: e3 error
I got mine fixed tonight! It was not that easy but can be done.
After my last post, I called the customer service of DeLonghi. The agent can only refer me to the authorized repair shops but she does not know what “E3” meant. There is no shop in NJ where I live, and the closest one is in CT! One of the two shops there knows right away the E3 is the fault of a condenser sensor. He mailed me the part ($25) and I took the covers off (be very careful to record where the screws are from ---- they are not all the same size/shape, and also there are two small tabs on the top holding two cover pieces together, so don’t force it to open or you will break it). There is only one part looks like the same as the replacement part I newly obtained and it has a metal clip attached on the copper coils. Carefully replace the sensor on the coil as you find previously and plug the other end to the control board. It sounds lengthy but once you open the cover it will all become clear to you. Be patient and this can be done. Very glad to see/hear it is working now again!
p.s., the store first mailed me the wrong part (on the plug-in end it has two ridges rather than one) so I have to call them again to explain and they mailed me a different one with a single ridge. Apparently there are two types (old and new model) for this model.
Posted on Oct 11, 2008
fitnessbalan
  • 59 Answers
SOURCE: E3 Error
here are the codes i found
E-1 Electrodes were not firmly grasped. Grasp the electrodes correctly.
E-3 Hands are dry. Slightly moisten hands with
a wet towel.
E-4 Body Fat Percentage and BMI values are outside themeasurable range. verify your personal data is
correct.
E-5 and E-6 Irregular Operation Turn the unit off, then on. Take another measurement. If the error occurs again contact Customer Service at 800-634-4350
have a great weekend!
Posted on Mar 13, 2009
  • 34 Answers
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Posted on Aug 13, 2009
Klimaire KSWG012H113 Split System Air Conditioner
Check web site for significance of the four flashes. Could be that it is overheating and shutting down due to excessive current consumption.
Jul 24, 2016 | SNK Klimaire KSWG012H113 Split System Air...
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
AC has been woking great for two year. Now has error code E3- evaporator error
mfr. model no.? some mfr., e3 means low pressure. may need sufficient refrigerant, otherwise suspect the pressure switch.
Oct 13, 2015 | Heating & Cooling
I keep getting a p5 error code on the indoor unit of my klimaire minisplit
I have a 3 unit split.
I found out that you can not have one unit set to warm and the other to cold. The compressor doesn't understand it.
Cycle off on and quickly re mode to Cool .
Do it to each unit and you will get it to stay on and then you can adjust.
Took a while for me but it did stay on after switching Mode at startup
Jul 12, 2011 | Cfm Klimaire KSWG009H113 Split System Air...
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
My tape was stuck in the unit, managed to free it up and noe I have an erro code of E3 on the LED screen, what does this mean?
First you must make sure you got all of the video tape out of the unit. Unplug your unit from power and check for any remaining tape. Any small piece of tape could jam your unit and give you error code E3. Once you know you removed all tape leave your unit unplugged for 5 minutes to see if it clears up the error code. E3 is a drum rotation error code and usually clears after plugging the unit back into the power. If this did not help then further repair will be necessary.
I hope this helped you out! Good Luck!
Nov 15, 2009 | Sony SLV-660HF VHS VCR
Dryers Logo
Top Dryers Experts
