Question about Electrolux E30EW75E Electric Single Oven
Electrolux E30EW75EPS4 Wall oven periodically blows circuit breaker and when oven is on desired temperature and then you set timer it cancels the oven temperature and temperature reading shows it on preheat. Please help!!
comike187
  • 17 Answers
SOURCE: DIAGRAM FOR A ELECTROLUX EOG600BN
240v mains powered soloniod for the oven is probably burnt the only other possibilities are the cooling fan on top or even the reignition unit on the top
Posted on Aug 28, 2009
  • 8 Answers
SOURCE: Electrolux oven won't come on
It appears that the "return to manual" button has to be reset
Posted on Sep 02, 2009
heatman101
  • 43501 Answers
SOURCE: Tried to clean single Electrolux wall oven. The
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Jan 20, 2011
SOURCE: Electrolux EOG600WN gas oven trips out circuit
You have a shortage in your wiring system and you'd need to call for service.
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Posted on Jan 25, 2011
seddy29732
  • 147 Answers
SOURCE: Electrolux EOB 6632 oven trips
Hi, welcome to FixYa! my name is Shaun. I hope i can help you out with your question. Your main house breaker is tripping over 180C because of the amount of current your oven is drawing. Keep in mind that an oven is capable of pulling up to 1/4 the amount of amperage of your total house current capacity, up to 50 Amps. This is assuming you have a typical 200 Amp main breaker. Add this in with your heating/air-conditioning, up to 30A, if electric, your water heater, 25 A if electric, and whatever lights and appliances you have plugged in and turned on, you can imagine how quickly those amps add up when your oven is on. Your oven breaker won't trip because you're not exceeding 50A on that circuit, however if your total household load is exceeding 200A, your main will trip. Also, breakers lose efficiency over time. Sometimes they can drop current capacity by as much as 25%. So your best bet is to replace your house main and see if that fixes your problem. Hope this helps out. Have a good day!
Posted on May 05, 2011
How do I stop an Electrolux double oven displaying a code F10 from beeping.
To cancel the F10 error, you need to unplug the oven or shut it off at the circuit breaker. Usually this error means that the oven is detecting a runaway temperature. Either the RTD (resistance temperature detector) sensor probe, the electronic oven (EOC) or the wiring is faulty.
You can check which one is bad by testing the resistance. The RTD sensor is on the back wall of the oven near the top of the cavity. It's somewhat easier to check the wire at the EOC. Unplug the connector and measure the resistance between the two wires. The resistance should be about 1100 Ohms in a room temperature environment. If you get the incorrect resistance, remove the sensor from the oven and check the resistance at the sensor. If you get the same faulty reading at the sensor and at the EOC, the sensor is probably bad. If the resistance is 1100 Ohms at the sensor, the wiring is bad. If the resistance is correct at all points, the EOC needs to be replaced.
Please add a comment with your oven's model number. I will try to find a source with the correct parts. I hope this helps.
Sep 20, 2015 | Electrolux 30" Built-In Double Electric...
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
How do you reset the frigidaire wall oven?
Good Afternoon Friend,
I understand you are trying to reset your Frigidaire wall oven, model# FEB27S5A, due to it not heating above 100 degrees. I suggest resetting at your homes circuit breaker for 3-5 minutes. When you restore power, you will first need to set the clock. After setting the clock, preheat your oven. If you are still noticing that the temperatures are still not going above 100 degrees, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to not reach the desired temperatures. Hope this is helpful.
-Best regards-
WP
May 11, 2014 | Frigidaire FEB27S5A Electric Single Oven
How do I fix Error F 11 on Electrolux wall oven E30EW75ESS2?
Hello Nancy Keller - Typically, error code F11 indicates a shorted keypad. Try resetting the wall oven by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Apr 08, 2013 | Electrolux 30" Built-In Single Electric...
I cleaned my electrolux oven for 3 hours and now my oven will not heat up any help please?
From what you have described sounds like you need to have the oven reset. Unfortunately, if resetting it at the household circuit breaker does not prove to be successful, then you will need a professional technician to pull the unit out of the cabinet/wall and reset it from the back panel.
Jul 31, 2012 | Electrolux 30" Built-In Single Electric...
F11 error on electrolux icon oven
The F10 F11 F12 F13 F14 Error Codes indicate that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa
Nov 27, 2010 | Electrolux ICON Designer E30SO75ESS Oven
An error f10 comes up and the oven keeps beeping
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 09, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
The electric power to my house was temporarily interrupted, and since it was restored my Modern Maid wall oven has not worked. The timer and griller work, but the wall oven does not. Does the oven need to...
The timer is 110 volt, and the grill may also be . The oven, however, is 220 volt. Suggest you check your main circuit breaker box and reset the breaker set marked "oven" or something similar. This would be the exterior breaker box where power comes into the home.
Nov 14, 2009 | Ovens
Wall Oven won't work
I tried randomly pushing 2 buttons at a time, and when I pushed "Timer Off/On" and "Cancel" together it unlocked and is now working fine. The following day it beeped a lot for an hour or so (must have been catching up on previous pushes) but now is back to normal.
Mar 14, 2008 | Tappan 30IN ELEC IGNa Oven
Electrolux E30EW75E Electric Single Oven Logo
Top Electrolux Ovens Experts
ashburton
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
