Question about Nexgrill 720-0234 (LP)
Seering Burner on 720-0466
Cant get the seering to light under any circumstances on my new nexgrill 720-0466 barbeque.
  • 68 Answers
Push and turn clockwise when so that it will spark.I hope it will help your problem.
Posted on May 18, 2009
Tubes blow flames out the front of burner
Burner out of postion , gas leak on control on off . or burner is blocked try cleaning burner some thing could be in the burner causing the gas tO light back , or you need new burner.
Mar 26, 2012 | Nexgrill 720-0234 (LP)
How do I change the burners on a Nexgrill Model 720-0108? Thanks for any info for less than handy woman!
That same model number has several different burners. One is a straight burner (three each); a couple are loop types and several have a flat surface with gas outlets.
Part Number
Description
Shopping
Cart
10361
Stainless Steel
Tube Burner
10361.jpgThis stainless steel tube burner is a replacement burner for numerous gas grills produced by Nexgrill, some of which are sold under the Charmglow brand name. This burner is 16 & 13/16 inches long. Please use our Nexgrill drop down model list, together with the illustration and sizes, to select the correct burner for your grill. Most of these grills use three to five burners. If you wish to benefit from quantity pricing on the 10361 burner, see the order entries below for three-pak and five-pak quantities.
This is the easy one - Just pick up the flutted end and slide out from the gas line. No screws or bolts
$12.79 each
Quantity:
Jun 05, 2011 | Grilling
Dash lights dont work (speedometer and fuel gauge) lights do not illuminate. Is there another cause other than blown bulbs ?
there is a little roller knob to the left of the seering wheel (verticle) it will increase or decrease the dash lights. Did someone turn them off ??
Feb 21, 2011 | 2000 Oldsmobile Intrigue
Right blinker is very slow. All bulbs are good - 1986 Fleetwood
Hi!!
Replace the Turn Signal Flasher, fisrt buy it at the autoparts to see how it look like and then remove kick panel drivers side and look under by the left of the seering colum for the old one. If you are unsure, activate the sigal lights and follow the clicking noise.
Don't forget to rate this post!! Good Luck!!
Jul 23, 2010 | 1986 Cadillac Fleetwood
Jenn-air model 720-0061 LP burners only light on one side cleaned with wirebrush and blew out with air?
The crossover for the flame to "jump" to the other side of the burner is clogged, rusgted, etc. It looks like a straight cut line on the rear under side of the burner. Nexgrill told me that the burners did not have an adequate amount of "finish" on them. Call them and get all new burners for free under warranty, Since 2004, I am on my 5th set of burners.
May 05, 2010 | Jenn-Air JLG7130A
Why wont my reverse lights work on my 1989 chevy 1500 all my fuses are good
theres a switch at the bottom of seering collum under the dash its called a nutral saftey switch thy replacing that
Nov 21, 2009 | 1989 Chevrolet C1500
1999 toyota avalon horn works intermitely
I would suggest to you to have the spiral cable (or 'clockspring') replaced. This is the electrical unit that transfers power to the air bag, the horn and the cruise control.
It is located right under the seering wheel.
Your description of the issue indicates to me that your spiral cable is loose, and making intermittant contact. If the vehicle had an air-bag deployment, this cable-device should have been changed.
Nov 11, 2009 | 2004 Toyota Avalon
Turn signals
If ur fuses are ok u might want to check ur signal switch (flasher) located under seering colunm (cylinder object)
Sep 17, 2008 | 1997 GMC Sierra
Nexgrill patio heater won't stay lit
I called Nexgrill technical support at 1-800-913-8999. They are sending me a new thermo couple to keep the valve open when ignited - so the patio heater will stay on. I needed to give them the serial number (inside the propane tank door) and fax them a copy of the receipt.
Hope this helps.
Jun 01, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Nexgrill 720-0234 (LP) Logo
310 people viewed this question
Top Nexgrill Grilling Experts
80stech
Gary Kenady
Gary Kenady
Michael Vincent Cruz
Are you a Nexgrill Grilling Expert? Answer questions, earn points and help others
