E3 error code on klimaire ptyac unit - Heating & Cooling
3 Suggested Answers
SOURCE: Error code in the top zone E3
An E-3 error code on your product indicates a problem with the DC fan in the upper zone. Your issue could be with the fan motor, control board or connecting wire harness. A DC motor can not be ohmed out like an AC motor, so if you detrmine the motor is not running, check for DC voltafe at the motor connections. If there is 12 to 24VDC, then you have a bad motor. If no voltage is present, check the output on the board. Before replacing an expensive circuit board, you may want to have a professional service tech come out and diagnose your problem. ***ALWAYS remove electrical power from the product when removing panels to gain access to components, and also when putting the panels back in place.
Posted on Nov 04, 2009
SOURCE: LG LD-12AW2 ( Not 12BW5 ) Error code E3 shows.
WTF, do you have any solution on this stinking website
Posted on Jan 06, 2011
Klimaire KSWG012H113 Split System Air Conditioner
Check web site for significance of the four flashes. Could be that it is overheating and shutting down due to excessive current consumption.
Jul 24, 2016 | SNK Klimaire KSWG012H113 Split System Air...
Error code e1
outdoor and indoor unit is not communicating with each other, check wiring and contacts.
Nov 30, 2013 | SNK Klimaire KSWG012H113 Split System Air...
E3 error in spin dry
Hello Jhunne, thank you for your post! I understand your unit is experiencing an issue with error code, E3 on your appliance. However, could the error code possibly be missing any characters? According from my research E3 is not a valid error code. Let's try resetting the unit by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn the unit back on. If resetting the power to the appliance does not correct the issue, I would recommend connecting with an expert repair tech to assist further.
Aug 01, 2013 | Electrolux Washing Machines
Error code e3 on a whirlpool LSE 1055 washing machine
The E3 error may indicate that there is a problem with the washer software or the touchpad. Try to reset the unit following the reset procedure.
Disconnect power to the unit and wait 30 minutes.
Oct 21, 2012 | Whirlpool Washing Machines
I keep getting a p5 error code on the indoor unit of my klimaire minisplit
I have a 3 unit split.
I found out that you can not have one unit set to warm and the other to cold. The compressor doesn't understand it.
Cycle off on and quickly re mode to Cool .
Do it to each unit and you will get it to stay on and then you can adjust.
Took a while for me but it did stay on after switching Mode at startup
Jul 12, 2011 | Cfm Klimaire KSWG009H113 Split System Air...
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
My tape was stuck in the unit, managed to free it up and noe I have an erro code of E3 on the LED screen, what does this mean?
First you must make sure you got all of the video tape out of the unit. Unplug your unit from power and check for any remaining tape. Any small piece of tape could jam your unit and give you error code E3. Once you know you removed all tape leave your unit unplugged for 5 minutes to see if it clears up the error code. E3 is a drum rotation error code and usually clears after plugging the unit back into the power. If this did not help then further repair will be necessary.
I hope this helped you out! Good Luck!
Nov 15, 2009 | Sony SLV-660HF VHS VCR
Sep 06, 2008 | LG 24 in. LD-12BW5 Free-standing...
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
