Ricoh aficio 2090 error code sc966 - Office Equipment & Supplies
munybuny
  • 14 Answers
SOURCE: Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Posted on Jun 22, 2008
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
M2Tech1
  • 313 Answers
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Posted on Jun 26, 2009
This was EDP CODE 885013 for Ricoh Aficio 2090 toner. what is the new EEDP CODE FOR THIS TONER PLESE
Check the setting on the software. Check the tab number copies.
If you wish to get some details about Printer repair and Servcie ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 24, 2016 | Ricoh Aficio Office Equipment & Supplies
Sc 705 da ricoh 2090
SC705 RADF Bottom Plate Motor Error
Jan 05, 2011 | Ricoh Aficio 450 Copier
Ricoh AF/2090 finisher des'nt attached
The finisher for a Ricoh 2090 is not hot-swappable, meaning you have to turn the copier off completely, attach the finisher cable, and then turn the copier on in order for it to correctly recognize the finisher.
Jun 17, 2010 | Ricoh Aficio 1035 Copier
Ricoh 2090 SC542 error
model 2090 richo sc 542 thermistar and hetar mail cancektar parobelam
Aug 22, 2009 | Office Equipment & Supplies
Ricoh aficio 2090 gives sc866 when i put sd card in the slot &how i give up the license data
The error showing is for programme error on the sd card either the card is currupted or the wrond data is on the card my advise would be to download the newest driver/programme and try again you can try this with a new sd card also the original might have some other drivers installed and this is causing teh miss read..Good luck A
Jun 28, 2009 | Ricoh Office Equipment & Supplies
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Apr 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
110 people viewed this question
k24674
jasbo
jasbo
