Question about Boating
Stearns spree We need two replacement floor bladders for stearns spree one kayaks. Please advise where to get one? Jen 561-4003295
3 Suggested Answers
  • 1833 Answers
SOURCE: I have an older Stearns
I think the rivet has come out. You have to repair the rivet or put a new rivet which can hold the seam back in ot its original position. Here are the instructions to repair.
If a part that is riveted to the boat needs to be replaced, the rivet needs to be drilled out. Using the center punch, punch the center of the rivet down. This will provide a pilot hole to make the drilling operation easier. Then, using the 13/64" drill bit, drill straight down on the center of the rivet (small silver center). If the outer black disk begins to spin, hold it in place with the needle nose pliers. Once the hole is drilled out, a new rivet may then be attached. Check to make sure the rivet fits snugly in the hole. If it does not, refill the hole and re-drill the hole with a 13/64" drill bit. Next, replace the broken part. If attaching a strap, be sure to use a washer between the rivet and the strap.
You will need these tools. Drill, 13/64" drill bit, needle nose pliers, cherry rivets, center punch, and cherry rivet gun
Posted on Mar 04, 2011
dcramer531
  • 1654 Answers
SOURCE: Have had our Stearns Spree
The best way to find a leak in an inflatable is to first inflate to normal or even slightly over normal and then mix up some Joy dishwashing soap and water to where the bubbles from the soapy water are tight and not flimsy. With a hand held sprayer start spraying the effected areas with the solution until you see bubbles forming from where the leak is occurring. There are other liquids you can use as well and Windex will work as well as a product called Snoop which can be purchased at hardware stores for finding gas leaks. Once the leak is discovered you can decide how you want to either patch it or have it repaired. Test the entire air valve very well to make sure it is not leaking. Most Dish washing soaps will work I just found thet Joy is the easiest to work with cause its bubbles stand up nice and clear. Check all the seams real well for small leaks like this as they tend to sprout up in the seams over time. Pin holes can be repaired very quickly using either the patch kit you received with your product or by using Air Seal (U051/AS1). It only takes a few minutes for Air Seal to dry completely.
Posted on Aug 14, 2011
Where can I get a replacement floor for my Spree 2?
Impossible dream. Not made nor anyway of attachment.
Jun 21, 2014 | Stearns Spree 2 Person Inflatable Kayak
Need a replacement zipper for a Stearns IK 140
Stearns is now owned by Colman. Contact them at http://www.coleman.com/contactus/
You will probably need to find a specialist shop to install the zipper, if you can get it.
Sep 03, 2013 | Stearns Kayak Inflat 1Per Pointr...
Sevylor st5656 what air presure should be in it
The ST5656 is a low pressure hull, so shouldn't be inflated to more than 1 psi, or about as firm as a ripe grapefruit. If you leave it out in the sun you need to let some air out or the air inside will expand and it will blow up
Apr 04, 2013 | Stearns SEVYLOR Sit on Top Kayak U250
Can you repair sevylor bladders? if so how?
dollar store contact cement in tube., an old bike tire, cut a patch out of tire and glue the patch on glueing around hole and underneath patch. apply patch smoothly. now glue around edge of patch. and let it dry for a few days at least 24 hrs. I have patched a bic yakka and a few cheaper inflatables patches hold up and hold air. good luck.
Aug 30, 2012 | Stearns SEVYLOR Sit on Top Kayak U250
One of the tubes leaks, how to find a replace one?
bike tube Contact cemnt( a dollar at store). A patch will work great i have done it many times and save you some cash.
Aug 25, 2012 | Stearns Spree Two Person Inflatable Kayak
I need a spray skirt for a Yukatat? Any solutions, suggestions?
we have a hibbet sports and a **** sporting goods that sell universal spray skirts for around $40 and i have used one on several 8-10.5 ft. kayaks.just practice taking it off before getting in the river and be safe!
Dec 27, 2011 | Stearns Yukatat Inflatable Kayak
Small leak somewhere- help- after kayaking yesterday, the kayak was somewhat deflated. can't find hole.
If it is a inflatable I would suggest mixing soap and water in a sprayer and inflate it back to normal then spray the whole kayak down and look for bubble, then youll find your leak.
Aug 16, 2009 | Stearns Cordova Inflatable Kayak
Boating Logo
63 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
