Question about NAD C162 Amplifier
My nad amp wont turn on - i've checked plug fuse so it must be something inside - was told it might not be worth fixing but i wuld like toknow what it is so i can at least decide. it's only 2 years ol
My nad amp was working fine and suddenly when i switch on i get nothing. checked plug fuse so must be something in side. Cheers lisa
  • NAD Master
  • 5,487 Answers
Yes it could be the internal fuse. If your lucky it might have just failed on it's own!
Posted on Jun 02, 2009
I have a nad 3130 amplifier which has been in storage for sometime. I've plugged it in and I have no power to the amp.
If the fuses are good....do this.....
1...unplug the amp from the wall AND KEEP IT UNPLUGGED !!!
2 Turn the power switch on ( again , the amp is UNPLUGGED from the wall )
3 with an ohm meter or a multimeter set on ohms., measure the ohms across the ac cord that plugs into the wall....in other words...take one meter lead and touch it to only one " blade" that plugs into the wall and keep it touching the " blade".....while you are holding it there, touch the other meter lead to the other " blade " that plugs into the wall.....you should get a very low ohm reading ( 2-50 ohms )......if it is over that number, your transformer or your switch is open ( toast ). hopefully it is the switch as transformers are un-available......good luck, be safe, and if you arent sure....ask before doing something silly.....Rob
Apr 03, 2015 | NAD Audio Players & Recorders
After 7 yrs of use, it just stopped working
I agree that It could be one of the other reasons listed here.....
But, I had the same problem with a 1,000 watt Kenwood amplifier and it worked like a boss for the whole two years that I had it and then one day the box that I had my subs in somehow came apart and after I changed out boxes the amp quit working. It came on but it wouldn't work anymore except for when I turned it a certain way or sat it against something.. Anyway it ended up being a loose female port plug on the inside where the auxilary cables plug up.
Hope it helps.
May 11, 2013 | Clarion APA4320 Car Audio Amplifier
I am trying to locate which fuse inside the cab operates the windshield fluid pump to spray fluid on my windshield. If you can send me a diagram or something. I just need toknow which one it is.
It should be the same fuse as the wipers. The fuse must be in the main fuse box. The position and function of the fuses is normally marked on the inside of the fuse box cover and also in the owner's handbook. If you don't come right with these, work your way through the fuses looking for a blown one. To ease your search the wiper fuse it should be around 15 to 20 amps.
Feb 24, 2011 | Dodge Neon Cars & Trucks
I have a NAD 510 CD player with no display lighting working and would like to repair this myself, and also a NAD 710 receiver/amp that does not tune in any stations but otherwise works fine, would it do...
wont do any harm to open it up. look for blown fuses. i have a NAD amp and the desplay goes blank and sound distorts when there is a blown fuse inside, my amp has abourt 8 fuses inside it 4 per chanel
Jan 04, 2010 | NAD C521 CD Player
NAD 7100. It wont start when you turn it on. It worked just fine yesterday. Does it have a fuse on the inside that needs to be changed?
if you unplug and carefully open the case there are four fuses inside. If one of them has a blown filament take it down to radio shack and match it. Make sure to note (inwriting) which fuse came from where because the amperage varies
Nov 12, 2009 | NAD C160 Amplifier
Nad c 370 no power
You need to look inside. There will be a fuse inside too. If your lucky it will restore the amp once replaced, but if it blows again you have a fault. You can track it down yourself if your any good, you might even see a burnt out part when looking for that fuse, otherwise get the repairman in.
Sep 20, 2009 | NAD C370 2-Channel Amplifier
Myc370amp turns its self about 15seconds after turn on
Replace 3 capacitors on the protect printboard. (located near the outpt terminals) 50V electrolyt: 4,7uF, 47uf and 10uF. And move the big diode to the back of the printboard (the heat from the diode dries out the capacitors)
Work in 9/10 times ;)
Aug 12, 2009 | NAD C370 2-Channel Amplifier
Amplifier only making buzzing sounds
u r amplifires output system is not working properly somthig pcb break problem go to thew mechanic
Apr 05, 2009 | NAD D 3020 Hybrid Digital Amplifier
Sw-32ht kenwood subwoofer
Open the case and check the fuses and the speaker to see if it actualy still working and not blown.
Oct 26, 2008 | Kenwood SW36HT Subwoofer
NAD 370
try to re-set mini circuit breaker inside.
Jan 21, 2008 | NAD C370 2-Channel Amplifier
NAD C162 Amplifier Logo
469 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
