Question about Toys
Brand new, out of the box Doom fighter won't sync
We purchased this helicopter as a holiday gift. Right out of the box we followed the instructions. We've tried at least a dozen times to get the remote to sync with the helicopter and it won't. The helicopter is charged. the remote has all brand new batteries in it. We even tried both A and B settings to get it to sync right.
SOURCE: vtech whiz kid learning system has no sound. can
My son has a year old Vtech laptop and I can no longer get sound from it. Have replaced batteries but that has not solved the problem. Can anyone help?
Posted on Jan 15, 2010
  • 4 Answers
SOURCE: Need charging instructions for Air Hogs Havoc
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Posted on Jul 21, 2010
SOURCE: My air hogs sharpshooter is
Did you turn the actual helicopter OFF? make sure that is switched OFF. Did that help?
Posted on Dec 02, 2010
SOURCE: right out of the box
did you turn the radio on first. It must be powered up with the throttle stick at minimum. Turn power on and then move stick to maximum and back to minimum. The remote lite should stop flashing and then power on helicopter.
Posted on Dec 28, 2010
SOURCE: My new u-control helicopter is experencing spinning
I had the same problem, the helicopter would spin out of control and the trim did not help. I took a closer look and noticed that only the top rotor was turning. I took the bottom off of the round gear box to find a tiny white gear had slipped off the second motor. With a pair of needle nose tweezers I was able to reattach the gear and I was flying in no time.
Posted on Feb 02, 2012
How to copy my ringtones from iPhone 6s to iPhone 7 Plus?
When you want to transfer ringtones from old iPhone to new iPhone, you will come up with the sync problem when using iTunes. iTunes provides a "Transfer Purchases" function for the you to transfer purchased items back to iTunes library, but the customized ringtones cannot be transferred back. If you are not sure about how to use the "Transfer Purchases" function of iTunes, check out the following tutorial.
1. Start iTunes, and go to "Edit > Preference > Devices". Check "Prevent iPods, iPhones and iPads from syncing automatically".
connect iphone to itunes.
2. Connect your old iPhone to PC via USB cable, then double click on the iTunes icon to launch the iTunes app on your computer if it did not start automatically when your iPhone is connected to computer.
3. Click "File > Device > Transfer Purchases" at the upper corner. Then click "Apply" at the right bottom. iTunes will automatically sync the transferred items to iTunes library, and the purchased ringtones will be transferred back as well.
4. Then disconnect the old iPhone from computer. Connect your new iPhone to iTunes following the step 2. Click on your iPhone, click the "Tones" to open the ringtones tab. Check the box for "Sync Tones" and then check the boxes for the ringtones you want to sync. There are 2 options avaliable, check "All tones" to choose all the ringtone files to sync, or check "Selected tones" to select the specified ringtones that you want to transfer. Finally click "Sync" button in the bottom right corner of iTunes, it will start transferring ringtones from iPhone to iPhone via iTunes. The synced ringtone files will appear on your iPhone as a ringtone automatically.
If you want transfer customized ringtones between 2 iPhones, you may need a 3rd party tool on your computer. Feel free to read the following tutorial for details.
How to Transfer Ringtones from iPhone to iPhone
Nov 07, 2016 | Cell Phones
Tip
Ea electronic art freedom fighters pc
<pre>
tips.....
too fast and crash audio unsync
this because your pc is too fast
this works on winxp, not tested on ther os but try the same proccess might work..
2 option is available
1. on freedom fighters directory look for freedom fighter.ini open it and
find disablevsync (change this to enablevsyc) then right-click on
application ico then select properties change the
compability to 95 or 98 ( this sync does not include audio
2. start the game then alt+tab then endtask ctrl+alt+del then find
freedom fighters.exe right-click change affinity and disable either
1 or 0 cpu to reduce cpu processes speed, and back to game now
you can observe the audio is sync w/o eax creative audio card
by korotchan
note: everytime you start the application need to repeat 2nd step.... taskman resets the setting, or you can use processes control application
like coreaffinity application
</pre>
on Nov 01, 2010 | Video Game Consoles & Games
Skygiant rchelicopter when i sync it and then give it throttle all the lights on the helicopter syart flashing red and it dosent do anything
I bought 2 off brand ,of the same remote controlled Helicopters which cost about $30.00 each. The controller has A_B_C setting helicopter has none, You can set them up any way, either all on one or separate channels per controller which is channel A.
1st turn off Helicopter switch to off and controller off .
Set controller -1 to channel C , , then (controller-1 ) throttle knob to max, turn power on to controller -1 , throttle down and up 3 cycles and left and right 3 cycles
Turn on Helicopter 1 with controller -1 still on, it should work on channel C
Jun 11, 2014 | Team International Hawk Talon V3 RC Indoor...
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
Purchased Doom II, Ultimate Doom and Final Doom, but switched to new computer with Windows 7. Now these programs don't work.
The only thing you can try is the "Compatibility Mode" option in windows 7. Right click the executable for your game and choose properties. Go to compatibility tab and choose a lower version of Operating System (e.g. Windows XP SP2) that supports your game. Save the changes you made by clicking on OK and try the game again. If this won't work, there is no other way but to use another computer with a compatible OS or downgrade your OS to a lower version that works.
You might also want to check your game manufacturer website for any update or patch that you can use to make the game compatible for Windows 7.
Hope this helps.
Jul 30, 2011 | Computers & Internet
The helicopter will not synchronize and I can't get it to communicate with the remote.
Press the throttle up and and back down and hold down a few times, sometimes it help to move left right knobs also. Try on each channel to get it synced
Dec 25, 2010 | Team International Hawk Talon V3 RC Indoor...
Receiver problems right out of the box!!
You may have to "bind" the receiver to the transmitter again. See the instructions that came with the transmitter on how to do this. If this not the problem the hobby shop is obliged to make sure it works so take it back before it get damaged.
Mar 16, 2009 | Walkera HM5#10 RC Helicopter
New 27 MHZ Helicopter Controller won't turn on
I have a 27Mhz helicoper (looks identical to the one on the picture). I tried to fly it for the first time, but I am having problems controlling it. The left radio control lever sends the helicopter upwards, but the right hand control doesn't seem to do anything and that should make it go backwards and forwards. Can anyone help me as well please?
Mar 05, 2009 | Back To Basics Toys R/C Helicopter (27...
NEW MA933A DIGITAL MP3 PLAYER
*1st- Make sure your compputer has met all the system requirments.
*2nd- Make sure you have Windows Media Player 10 or newer. (If not you may download it from Microsoft's website)
*3rd- Once media player is installed plug your mp3 in to the computer and wait for the "Found New Hardware" Process to complete.
*4th- Transfrer all of your music into Windows Media Player
*5th- Your device should now show up in Windows Media Player under the sync tab
*6th- Drag the music into the sync list on the right and click the "Start Sync" button
*7th- When prompted unplug your device
*8th- Enjoy.
Happy Holidays
Dec 27, 2007 | Nextar MA933A MP3 Player
Toys Logo
257 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
