Question about IBM ThinkPad T40 2373 Notebook
ThinkPad T40 Help, ThinkPad T40 turns off whenever I move the computer from one place to I need a new motherboard or new memory? Glenn
  • 5 more comments
  • aand Nov 11, 2007
    Laptop turns off when moved slightly. Basically same problem you are having.
  • aand Nov 13, 2007
    Have same problem. So long at unit is on stable surface or not moved, all is fine. As soon as unit is moved, no matter how minutely, the display goes black.
  • Anonymous Nov 27, 2007
    I do have the same problem. Move my T40 a bit then the monitor goes blakc off with some dim light. Please help.
  • gadamson Jan 05, 2008
    I just bought a IBM T40 on eBay. The laptop works perfectly except when ever the laptop is moved slightly the screen goes blank. I have added an external monitor and tested it. Both screens go blank when the laptop is moved or jiggled a little. Assume it is some loose connection inside but don't no.
  • Anonymous Jan 28, 2008
    I have the same problem with my laptop. It began very quickly and my computer became unusable in a matter of a couple days. I will attempt to look at the video card section and see how that goes.
  • motah33 Feb 17, 2008
    Exactly the same problem here as well. What I've noticed is that once the screen goes off, the hard drive light comes on and if I wait around long enough the machine resets.
    The odd thing is that when the machine is booting up or if you are running the diagnostic utilities from DOS, then you can move and shake the machine as much as you want and it's fine. It's only when you get into windows and attempt to move the machine that it also resets.
    I've also noticed that when I hit some keys it can go off too, so the idea of the video chips being loose kind of fits here. Really annoying as this has started to happen just after the warranty!!
  • Anonymous Apr 27, 2008
    Same issue - mine is the AGP video chip BGA problem, probably related to the first use of non-lead solder in favor of the more brittle green variety IMO. I am using an elaborate pressure plate of rubber and a steel plate to reinforce the keyboard under the mouse buttons. This creates greater pressure than the keyboard alone. This works for weeks at a time, but it still freezes when I pick it up quickly. Cure then is to loosen screws and re-tension the video chip. When this no longer works I'll try the reflow before I junk the machine. These are a very thin and therefore flexible chassis and that is the root of the problem. However, the same thing can happen to a Dell D800, and they are certainly not svelte.
  • 324 Answers
If you can make the problem come and go by slightly twisting or flexing the bottom (keyboard) section of the case, you may have a loose internal connector. If the laptop has been dropped recently, more probably you have a cracked land pattern on the motherboard.
Posted on Nov 03, 2007
  • Ron Roske Nov 06, 2007
    Addition to my previous comment. Didn't think to mention it at the time, but...
    The Txx series has a real bad habit of the graphics chip coming loose from the system board. Unfortunately this chip is soldered to the board. This is an engineering problem and there has been a lot of discussion as to the large percentage of Txx's that are developing this problem after a couple of years. Current fixes are as follows:
    1. If it's still under warrenty, IBM may fix it for you.
    2. If not, send it to IBM and pay them $500-$600 to fix it.
    3. Buy a good, tested board off of e-bay, or similar and replace it. ($2500-$300)
    4. Attempt to reflow the solder yourself. (Check on YouTube as there are a couple of postings there on the process.)
    5. Jam something between the top of the graphics chip and bottom of the keyboard, so that a downward pressure is on the graphics chip. That presses it against the system board, and you may regain contact.
    6. Forget the whole thing and get yourself another laptop.
    The problem that you are having will, in all probability, slowly degrade the laptop to the point of unusability.
    Not what you wanted to hear, but you aren't alone in this. There are a lot of other folks experiencing the same thing.
Same here as well. A T40 and I have allready bought a T61 to replace it (some never learn).
Will still not stop using "old not-so-faitfull" - that is my old T40 that keeps freezing.
Maybe will try this:
Posted on Jul 30, 2008
  • 457 Answers
I shouldnt think so if it is still running ok.
Posted on Oct 17, 2007
IBM ThinkPad T40: the problem is the following Modem HSP56 MR( Intel) doesnot work, Other devices:Nework Controller and unknown device doesn't work
Windows is missing the "device-drivers" for your network adapter and your modem.
On a different computer, access IBM's ThinkPad web-site, and download those device-drivers for your T40. Copy the device-drivers to either a CD-writable or to a USB memory-stick.
Move the media to your T40, and install from that removable media.
May 10, 2011 | IBM ThinkPad T40 2373 Notebook
My ibm thinkpad t41 turns off after sometime when i turn it show cmos checksum bad
It is time to change the CMOS Battery Backup, its located inside the unit is the size of an nickle.
Dec 19, 2010 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
I have an IBM thinkpad T40 when I turned on the laptop the image doesn't appear and that times it would but then after a few seconds or minute the screen blanks out and won't appear again and sometimes...
There is no problem in your motherboard. In your motherboard, clean your ram and also where ram is put. Then restart your system again it will work. When it will not work please change your ram. Then it will work.
Nov 07, 2010 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
I need to know the part no. for the motherboard and the priceand where can I order the part. IBM T40 2374 thinkpad
Apr 02, 2010 | IBM ThinkPad T40 2374 Notebook
Computer turns on and off all by itself.
check out wall power
change the smps
may be software problen unintall and reinstall operating system
Aug 05, 2009 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
1 Gig of free space out of 32 gigs
maby u should look for hidden memory or downloading takes up space a lot
Jul 26, 2009 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
When stat thinkpad R50 beeps 2x and nothing
Two short beeps and no further activity mean you could have a motherboard problem or a memory (RAM) problem.
Reseat the RAM modules and reboot the laptop, if the laptop still doesn't work, remove the RAM module/s and insert them into a working laptop to test them, or take them to you friendly computer shop to have them tested.
If the RAM is OK then the fault is the motherboard. Replacing the motherboard may not be a cost effective solution.
May 14, 2009 | IBM ThinkPad T40 2373 Notebook
T40 manual
Hi friend rascie_1959
No need to buy any manual
here is the link for you
T40 IBM Thinkpad manual
Jun 18, 2008 | IBM ThinkPad T40 2373 Notebook
IBM-T40 water on motherboard
ibm service ceter almost in all main places
Nov 04, 2007 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 Notebook Logo
1,883 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
