Question about Dell 1720dn Laser Printer
Flashing:remove output and cannot print
    Problem Solver:
  • 5 Answers
Sounds like the Outputflag is sticking or not returning back to the proper position as quickly as i should. The output flag is gravity return in other words there is no spring required.
Perhaps there is paper or dust collecting in that area and causing the flag to stick... regardless follow these instructions to test this :
The output bin flag on the 1720dn is on the right side. (as you face the printer)
Turn the printer off, hold up the flag while pwring on, wait until al the lights stop cycling. the only light remaining ON (flashing) should be "Remove Output".
Release the Output Bin flag; the light should stop flashing (go out) and the "Ready" light
If this is the case try cleaning that area with compressed air to see if the flag will lower on its own.
Best of Luck
Posted on May 18, 2009
  • dsewell80200 Jul 24, 2011
    Ok I found a way to bypass this problem all you have to do is remove the right side cover follow the wire that comes from the flapper down to the circuit board (there is a cover over the circuit board remove that as well) unplug the wire. Problem solved
Printer fault
The Canon Pixma IP 4000 printer has a self-diagnosing print head error notification system. Generally the "Alarm/Power" light will flash and tell you what kind of problem you might be having with your print head.
You can also run tests yourself to identify problems.
Look at the "Alarm/Power" light and see how many times it's flashing.
If it flashes orange 11 times consecutively, that means there is a print head alignment issue. Perform deep cleaning, then move the printer away from any strong light sources.
To deep clean, click the Maintenance tab in the "Printers" folder.
Then click the "Deep Cleaning" icon. You can select all colors, black, or selected colors. Click on "Execute."
If it flashes orange five times consecutively, that means there is a print head error.
Reseat the print head, then reset the printer.
To reseat the print head, make sure the printer is on.
Open the paper output tray and top cover.
Make sure the print head holder is in the center and open the inner cover. remove all the ink tanks.
Raise the print head lock lever and remove the print head.
Reseat the print head and lock the lever.
Replace the ink tanks.
Check to see if the ink is ejecting normally from the print head nozzles by running a test.
Press and hold the "Resume/cancel" button.
When the Power lamp flashes twice, release the button.
Examine the printed output.
Use the references below to compare your output to what Canon suggest is correct.
If the output is incorrect, then perform deep cleaning, if necessary repeat twice.
Replace the ink tanks if you're unable to get a good result by following the previous steps. make sure the printer is on, lift the top cover.
The print head holder will move to the center.
Press on the tab to release the tank.
Unwrap a new tank.
Make sure you can see the air hole and insert the new tank until you hear a firm click.
Repeat for the other tanks if you suspect from your print test that they have failed.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=10239 - SupportDetailAct
Apr 23, 2013 | Office Equipment & Supplies
Canon Printer i550 Printer will not start, but warning light flashes green/yellow green etc. Flashing does not stop if press right hand button Flashing still goes on after re-installing printer...
this is the service error for this you have to reset ink counter, it's available on your manual.
or you can use utility like ip tools available free on net
Oct 13, 2008 | Canon Office Equipment & Supplies
Just stopped working, orange light flashing
  • If it flashes orange five times consecutively, that means there is a print head error.
  • Reseat the print head, then reset the printer.
  • To reseat the print head, make sure the printer is on.
  • Open the paper output tray and top cover.
  • Make sure the print head holder is in the center and open the inner cover.
  • Remove all the ink tanks.
  • Raise the print head lock lever and remove the print head.
  • Reseat the print head and lock the lever.
  • Replace the ink tanks.
Jan 30, 2011 | Canon Pixma iP4500 InkJet Printer
My MP510 was just printing fine then went to rear feed and now all I get is a flashing green and yellow lights
review this to determine your problem.. If all else fails simply unplug your printer wait a minute and plug back in.
Handling Error Messages
When a printer error occurs, the POWER/ERROR lamp flashes.
The number of flashes indicates the type of error that has occurred.
Count the flashes and take the appropriate
action to correct the error.
Number of Flashes
Possible Cause
Try This
Two flashes Printer is out of
paper/Paper does
not feed
Reload paper in the Sheet Feeder or Cassette and press the RESUME/CANCEL
button.
Three flashes Paper jam/Paper
Output Tray is
closed
Clear the jammed paper, reload paper in the printer, then press the RESUME/
CANCEL button. If the Paper Output Tray is closed, open it.
See “Paper Jams” on page 72.
Four flashes Empty ink tank Press the RESUME/CANCEL button to resume printing with an empty ink tank.
Replace it with a new ink tank immediately after the printing. It may damage the
printer if you continue printing with an empty ink tank.
See “Replacing an Ink Tank” on page 42.
Five flashes Print Head not
installed/Print
Head not installed
correctly/Defective
Print Head
Install the Print Head. If the Print Head is already installed, remove the Print Head
and check the electrical contacts for foreign matter, then reinstall.
After reinstalling the Print Head, you may need to realign it.
If this error still remains, the Print Head may be damaged. Contact the Customer
Care Center.
Six flashes Inner Cover is open Close the Inner Cover and press the RESUME/CANCEL button.
Eight flashes Waste ink absorber
almost full
The printer has a built-in waste ink absorber for the ink used during Print Head
Cleaning.
Eight flashes indicates that the waste ink absorber is nearly full.
Press the RESUME/CANCEL button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact the Customer Care
Center.
Nine flashes A specified period
of time has elapsed
without receiving a
response from the
digital camera/The
digital camera or
digital video
camcorder
connected is not
compatible with
this printer
Disconnect the camera cable, press the RESUME/CANCEL button and reconnect
the cable.
If the error is still unresolved, there is a possibility that you are using a digital
camera or digital video camcorder that is not supported by this printer. Use a
digital cameras or digital video camcorder compatible with this printer
Mar 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Light kee flashing orange/green and says computer is busy when there is nothing in print queue
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 29, 2010 | Canon BubbleJet i320 Printer
The orange light keeps flashing
Mar 22, 2010 | Canon I990 InkJet Photo Printer
5 orange flashes
5 time orange flash indicate Cartridge Error or Print Head Error.
1) Reseat the Print Head
  • Confirm that the printer is powered on.
  • Open the paper output tray and top cover. Gently open the paper output tray while holding it.
  • After confirming that the print head holder has moved to the center, open the inner cover.
  • Remove all ink tanks.
  • Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
  • Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
  • Close the inner cover and top cover. Check that each ink tank is installed in the correct position.
2) Reseat the Printer
  • Turn the printer off with the Power button.
  • Disconnect the data cable from the printer
  • Unplug the printer's power cord for approx. 10 minutes, and then plug it back in.
  • Turn the printer back on.
Else either your device require service or print head may need to replace.
Good luck...don't forget to rate the solution
Feb 25, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
The remove output light is flashing on my printer and the output flag is off what can i do to print
There are two pivioting flaps where the paper exits the printer on top. These flaps raise as the paper comes out of the printer and then fall back down after the paper has exited the printer.. The flap on the right has a tab that trips a paper sensor above it, this tab ofter breaks and it will not trip the sensor. This causes the printer to think the top output tray is full and wants you to "Remove Output". Some times you can push that right flap back towards the back of the printer and it will trip the sensor, then you will get a ready light and you can print. Be aware if you push to hard you can break the flap. This worked for me. Be carefull !! I am in the process of tracking down the part number and order process. I will post the results later.
Aug 30, 2009 | Dell 1720dn Laser Printer
A big PGBK ink cartridge problem
Call - 1-800-828-4040
Verify they are installed correctly.
Remove the print head or ink tanks properly following the procedure below.
1. Confirm that the printer is powered on and open the top cover. The print head moves to the replacement position.
Note: When the top cover is opened more than ten minutes, the print head moves to the right side. If this occurs, close the top cover, and open it again.
2. Open the paper output tray and pull down the inner cover.
3. Remove the ink tanks by pressing the tab of each tank.
Note: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. When replacing multiple ink tanks, make sure to replace one by one.
ip4200_ink_remove.gif4. When removing the print head, raise the print head lock lever first.
raisephlocklever.gif To reinstall the Print Head and Ink Tanks
1. Place the print head in the holder and lower the print head lock lever carefully until you hear a click.
putinphnlockit.gif2. Insert ink tanks into the print head.
Press the mark 'PUSH' on the ink tank firmly until you hear a click.
3. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
<1> The ink tanks are installed properly.
<2> The ink tanks are not installed properly.
Note: <Ink Tank Lamp> You can check the status of each ink tank according to the way its lamp flashes.
On: The printer is ready to print.
Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
Off: An error has occurred and the printer is not ready to print.
4. Put back the inner cover and close the top cover.
Note: When starting printing next time, the print head cleaning launches automatically.
During the print head cleaning, the Power lamp flashes green. Do not do other operations until the flashes stops.
James Mac
Sep 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Canon service 6000
Well... here it is :
The POWER Lamp Flashes Orange title-bar.gif An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
When a printer error occurs, the POWER lamp flashes. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error.
bullet.gif Two flashes: Printer is out of paper /Paper does not feed
Reload paper to the sheet feeder or cassette and press the RESUME button.
bullet.gif Three flashes: Paper jam/Paper output tray is closed
If paper is jammed, remove the jammed paper, reload paper in the printer, and then press the RESUME button. If the paper output tray is closed, open it.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
Press the RESUME button to resume printing with an empty ink tank. Replace it with a new ink tank immediately after the printing. It may damage the printer if you continue printing with an empty ink tank.
bullet.gif Five flashes: Print head not installed/Print head not installed correctly/Print head is defective
Install the Print Head. If the Print Head is already installed, remove the Print Head and check the electrical contacts for foreign matter, then reinstall.
If this error still remains, the Print Head may be damaged. Contact a Canon service representative.
bullet.gif Six flashes: Inner cover error
To print on paper:
Close the inner cover. Then press the RESUME button to start printing.
Do not move or close the inner cover during printing. It may damage the printer.
bullet.gif Seven flashes: The CD-R or DVD-R is not set on the CD-R tray
Reset the CD-R tray feeder with a CD-R tray containing a CD-R or DVD-R, and then press the RESUME button. Printing will resume.
This function only works with models that support CD-R printing.
bullet.gif Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during print head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible.
bullet.gif Nine flashes: A specified period of time has lapsed without receiving no response from the digital camera / The digital camera or digital video camcorder connected is not compatible with this printer
Disconnect the camera cable, press the printer's RESUME button and reconnect the cable.
If the error is still not solved, there is a possibility that you are using a digital camera or digital video camcorder that is not supported by this printer. Use a digital camera or digital video camcorder compatible with this printer.
bullet.gif Ten Flashes: Cannot print on both sides of the page
The size of paper may not be compatible with automatic duplex printing. For information on the size of paper compatible with auto duplex printing, see "Automatically Printing on Both Sides of the Page." Pressing the RESUME button will discharge the paper, and restart printing from the front side of the next paper. The reverse side will not be printed when an error occurs.
bullet.gif Eleven flashes: Cannot perform automatic print head alignment correctly
Possible causes are as follows:
bullet_s.gif A4 or Letter-sized paper is not loaded on the sheet feeder.
bullet_s.gif Ink has run out or ink tanks are not installed correctly.
See Ensure that the ink tank is installed properly.
bullet_s.gif Ink level is low.
bullet_s.gif Print Head nozzles are clogged.
Press the RESUME button.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
bullet_s.gif The paper output slot has been exposed to a strong light source preventing correct print head alignment.
Press the RESUME button to resolve the error. Align the printer so the paper output slot will not be exposed directly to a strong light source.
After carrying out the above measures, if the problem continues after aligning the print head again, press the RESUME button to resolve the error, and then perform manual print head alignment. For details on manual print head alignment, see "Aligning the Print Head."
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Disconnect the printer cable from the printer, and then turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on after leaving it for a while.
If the problem remains, contact a Canon service representative.
Apr 21, 2008 | Canon PIXMA iP1600 Printer
Dell 1720dn Laser Printer Logo
3,330 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
