Question about Canon PIXMA MG2120 Inkjet Photo All-In-One
Error P07 pixma canon MG2120 - Canon PIXMA MG2120 Inkjet Photo All-In-One
5 Suggested Answers
kifuat90
  • 31 Answers
SOURCE: I have a canon pixma
its mean absorber full..(i think)
Check this steps :
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
1 Press the power button to turn off the printer.
  • 2 Hold the "Stop/Reset" button while pushing the power button. While still holding down the power button, release the "Stop/Reset" button and then push it twice in a row.
  • 3 Wait approximately 20 to 30 seconds until the LED shows 0.
  • 4 Push the "Stop/Reset" button four times in a row.
  • 5 Push the power button twice.
  • 6 Turn off the printer by pushing the power button one more time. The printer is now reset. Next comes resetting the counter on the cartridge.
  • 7 Unplug the power and the USB cables from the printer.
  • 8 Open the cartridge door and hold down the power button.
  • 9 Reconnect the power cables while still holding down the power button.
  • 10 Close the cartridge door and release the power button. The ink cartridge is now reset.
  • Posted on Aug 11, 2011
    Geekman
    • 32281 Answers
    SOURCE: Just bought a CANON PIXMA MG2120 printer and the setup CD-ROM will not load. Why?
    The CD maybe damaged or faulty.
    You can download the Canon printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
    Posted on Aug 26, 2012
    • 5128 Answers
    SOURCE: My Canon PIXMA MG2120 stop printig last night, Gave me an error message 5100.
    When the 5100 error happens, there are a few things you can check. The error means that the ink carriage isn't moving across the printer properly. First check if any ink cartridges are not properly seated. (Open the front cover and the paper output tray and then the paper output cover of the printer while it is on. The head cover should open when the cartridge carrier moves into the Fine cartridge replacement position. Then you can double check the cartridges.) Close the covers and check if the problem has been resolved.
    If the cartridge carrier doesn't move to the replacement position or the cartridges are not the problem, then you need to check for a jam (paper or other object) blocking cartridge carrier. (Possibly the block is between the cartridge carrier and the "home" position for the carrier.) Turn off the printer and unplug it from the outlet. Open the paper output cover. Avoid the clear film but check for any paper or foreign objects. Move the cartridge carrier to the different sides of the printer to make sure that nothing is under the carrier. Pull any paper slowly and steadily to minimize tearing the paper. You'll have to remove all the small pieces, if they are present. (Note: some paper might have ink on it and thus harder to see. Use a flashlight to help check the corners of the printer.) Check the paper input area as well. After clearing the jam, close the paper output cover, replace the paper in the input tray and check the printer again.
    If this doesn't resolve the problem, try resetting the printer. Turn off the printer. Disconnect the data cable if you use the USB cable. (I like to disconnect the cable from both the printer and the computer.) Unplug the power cord for at least 10 minutes (from the outlet and printer, if possible). Reconnect the power cord and data cable. Turn the printer on and check for any error messages.
    The next possible problem is a dirty encoder strip. Turn off and unplug the printer. Open the paper output cover and locate the plastic strip. If there are any smears on the strip, use a neutral pH detergent (2-3 drops) in a 1/4 cup of water. Moisten a cotton swab in the detergent solution and squeeze a bit to remove the excess water. (You don't want to drip the water inside the printer.) Wipe the swab across the encoder strip. Use multiple swabs to clean the entire strip. Do not touch the metal rail or push the encoder strip. Check that the encoder strip isn't dislocated from the springs on the ends of the strip. Take another set of cotton swabs, moistened only with water, to remove any detergent residue from the strip. Dry the strip with additional (dry) swabs. Let the printer dry before closing the paper output cover. Then plug in the printer and turn it on.
    If this doesn't solve the problem, the printer needs to be serviced. If it is under warranty, contact Canon. Otherwise, decide if it is worth the costs for service. (You have to get the printer to the service center and then pay for the initial evaluation; the evaluation charge will be applied to the repair if you decide to have the unit serviced.)
    Full descriptions and pictures of the steps to resolve a 5100 error are available from Canon support: http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/pixma_mg2120?CMD=MIXED_SEARCH&mName=PIXMA+MG2120&mType=PIXMA+MG&pageKeyCode=ekbresults&searchString=5100+error&BASIC_SEARCH_CURRENT_TOPIC_ID=2259&BASIC_SEARCH_CURRENT_TOPIC_TYPE=0&RESULTS=RELEVANCE&RELEVANCE_START=1&RELEVANCE_COUNT=25&CONFIGURATION=1011&PARTITION_ID=1&TIMEZONE_OFFSET=null&USERTYPE=1&isSecure=false .
    I hope this helps.
    Posted on Jul 16, 2013
    SOURCE: canon pixma mg2120 error code e3
    Yes
    Posted on Sep 11, 2013
    My Cannon pixma 280 printer wont print it says error 5B00 What can I do?
    How To Fix P07 or 5B00 Error On Canon MP Series Printer - YouTube
    ? 1:38
    https://www.youtube.com/watch?v=HvBpioLPm3M
    Jul 17, 2012 - Uploaded by Internet-Ink
    This video from Internet-ink.co.uk will instruct you on how to cancel the P07 error on the Canon MP series ...
    Canon PIXMA MP280 ERROR 5B00 - YouTube
    ? 2:39
    https://www.youtube.com/watch?v=sYhpW2UgEVw
    Jul 4, 2016 - Uploaded by Ozone Spot
    Coment? el error 5B00, cualquier pregunta no duden en mandarme un correo. Lo responder? ... Canon PIXMA ...
    How to Fix Canon Pixma iP2770 error 5B00 - YouTube
    ? 6:18
    https://www.youtube.com/watch?v=Ypi6wgoMo04 Nov 20, 2014 - Uploaded by ishadi aplus
    Canon Pixma iP2770 error code 5B00 mean the waste ink counter reset (yellow and orange light ...
    How to repair error 5B00 or P07 on Canon printer MP280 ' MP287
    acer-mini-laptops.blogspot.com/2015/04/how-to-repair-error-5b00-or-p07-on.html Apr 16, 2015 - Error type 5B00 or P07 on Canon MP280/287 printer can be caused by several reasons. To solve this problem, you need to do some simple ...
    How to get rid of the 5B00 error message on canon printers ' en ...
    www.en.rellenadodecartuchos.com/.../how-to-get-rid-of-5b00-error-message-on-cano... This post will teach you three different ways of solving the 5B00 error message on regular and multifunction canon printers.
    How reset the full pads in Canon PIXMA MP230 error 5B00 ' en ...
    www.en.rellenadodecartuchos.com/.../how-reset-full-pads-in-canon-pixma-mp230-err... Learn here how to eliminate the error 5B00 Canon PIXMA MP230 printer, follow all the steps and solve your problem.
    error 5B00 in Cannon 280 printer Google Search
    Jul 11, 2017 | Cannon Office Equipment & Supplies
    Why don't I get the print button when I click print and only a save or cancel button?
    what is the default printer is it paperport ?
    Go to settings printers and make Canon Pixma mg2120 the default printer
    or each time go to File Print in whatever the program you were printing from was and then select Canon Pixma mg2120 as the printer
    let me know if I am on the right track of paper port being the printer !
    Oct 13, 2015 | Canon PIXMA MG2120,INKJET PHOTO ALL IN ONE
    Error 2,156,50 canon mg 2120
    because I can not always quick scan shows me the error 2156.50
    Jan 17, 2013 | Canon PIXMA MG2120 Photo All-in-One Inkjet...
    Canon pixma mg2120 error 5100
    I just bought this Canon PIXMA MG2120 PRINTER about 2 weeksago, I've been able to print untillast night, it's giving me error message 5100, what do I do to fix this?
    Jul 15, 2012 | Canon Office Equipment & Supplies
    Canon pixma mp258 error 5B00
    Please go to the following website which describes the procedure needed to fix your printer. You will need to download a resetter, the link to everything is in the instructions:
    http://ekohasans.blogspot.com/2011/02/how-to-fix-mp258-p07-error-5b00.html
    Sep 07, 2011 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
    My printer mp250 error p07 led flash orange
    The Error P07 means your printer Ink absorber is full. See complete Error code Canon mp250/258 Printer
    Solution: How to reset it you can get detail on the web too. here is the link How to reset Canon MP 250 Series includes Manual Reset and Permanent Reset with Tools
    May 23, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    Canon PIXMA MG2120 Inkjet Photo All-In-One Logo
    605 people viewed this question
    old marine
    old marine
