Question about Metz mecablitz 45 CL-4 TTL Flash
Metz 45 CT-1 Outup Calibration
Hi All!
Does anyone have a circuit diagram for the Metz 45 CT-1 please?
One of my units gives an output approximately 1.5 stops too low, is there an easy setup to correct this?
I have an accurate flashmeter, and a total of 7 Metz 45 series flashes.
I'm tempted to swap the photocell with another unit, but since the unit is firing consistantly low it would suggest that the photo cell is too sensitive!
Any Ideas?
  • Austinii May 31, 2009
    Many thanks for that Kalaci, I originally trained as an electronics engineer, so no probs on terminologly.
    I had already traced the two trim pots, but neither has an effect. I don't have the circuit diagram, and can't be bothered with tracing it all out myself, however the flash works perfectly with a Mecamat attached and for the moment I'm using it like that.
    If I can find a circuit diagram then I'll go deeper into it.
    Thanks again,
    Gérard
  • Neil May 11, 2010
    I have a service manual for the Metz 45CT-1, but it's in German.I can probably find something in the circuit, if I know what I need to look for.
    New Friend:
  • 22 Answers
I have a 45CT-1 Service Manual, but it's in German. If I knew what to look for, I could probably find what you want. I know some German, but not enough to follow the technical description in the manual.
Posted on Jul 07, 2009
    New Friend:
  • 30 Answers
During the flash impulse the "photocell", actually a phototransistor, charges a capacitor with current, proportional to the reflected light intensity. As soon as the voltage on that capacitor reaches the trigger voltage of a four-layer diode (which, in fact, is playing a role of a PUT) that turns on and triggers the quench thyristor. There is a trimmer potentiometer in the four-layer diode circuitry, which sets the trigger voltage. You can try to fiddling with that. But the culprit of the misalignment easily can be in any of the parts in the above described circuitry.
Posted on May 22, 2009
  • Laszlo Kalmar
    Laszlo Kalmar May 22, 2009
    This is not a true fix, but may be of quick help. Cover the light sensor with one or more layers of frosted tape until the output reaches the exact value. The real fix demands some knowledge in the field of electronics. PUT, four-layer diode, photortansistor, circuit-commutated quenching of an SCR. If any of these expressions are unfamiliar to you then try to fix the internal circuitry on your own is not advised. If however you need more detailed explanation, drop me a mail.
    Problem Solver:
  • 7 Answers
I think that they all slightly under expose, and would'nt muck about with the internals. Have you removed the flash diffuser that is clipped on the front?
Posted on Feb 11, 2010
Ttl connection to a metz 60ct4 or 45 ct-5
You have to use a special cable adapter for each type of camera.
These old flash units do not have adapters for current digital cameras. For old cameras the only place to get the adapters, is on ebay or from KEH.
Feb 10, 2014 | Metz Mecablitz 60CT4 TTL Flash
I need a manual for a metz 45 ct-5 . Can any one help?
please try this link below. its one from fixya!!!
www.metz.de/en/photo-electronics/instruction-manuals/mecablitz.html
Aug 19, 2009 | Cameras
AC Power Supply for Metz 45 ct5
Hi daf4,
I have a circuit diagram for the 45CT-5 and the flash unit as well. The voltage is 360V DC, which goes straight across the flash tube. The top pin is positive, when the notch in the socket is on the right hand side, i.e. towards the back of the flash.
I'm also looking for a circuit diagram for a 45CL-4, if you know anyone who has one.
Regards,
Neil
Feb 07, 2009 | Metz mecablitz 45 CL-4 TTL Flash
Metz 45CL-4 Service Manual wanted..
Hi !
Here is a link to the Metz manufacturer:
http://www.metz.de/en/photo-electronics/instruction-manuals/mecablitz.html
I hope it will be to some help.
Regards Lars
Jan 27, 2009 | Metz mecablitz 45 CL-4 TTL Flash
Metz mecablitz 45 ct 1 and Nikon D-90
The trigger voltage of the 45CL-1 is about 12V, so it should be safe to connect directly to the hot shoe with an adaptor, or to the pc soclet, if the D90 has one. If the D90 is anything like my Canon 40D, which can stand about 30V on the hot shoe, then all the 45CL series will be ok, as they have trigger voltages between 9V and 12V. The 45CT-5 has a trigger voltage of 15V and works well on the 40D. I use 3 different Metz 45 models with my 40D and all work well on automatic, where the flash sensor itself controls the light output.
Jan 26, 2009 | Metz 45 CL-1 Flash
Metz 45 CT 1
I had that same problem also, but mines was temporarly. Ik think the condensor inside the Metz has to regeneratie (recover) itself by using with a full charged fresh batteries. The high freq. sound is normal. (although not to loud) after a 5 MINUTES the orange bulb should light up. How more u used how better the start-up time. My old Metz start-up time was around 40 sec. and now ot is within 7 sec.
Jun 22, 2008 | Metz 45 CL-1 Flash
Metz 45 ct5 flash battery pack wiring diagram
You can rig that fella up for a better power.
atdlee@netzero.com
Oct 23, 2007 | Metz 70 MZ-5 TTL Flash
Metz mecablitz 45 CL-4 TTL Flash Logo
1,142 people viewed this question
Top Metz Cameras Experts
bhargav
TimHu
Level 1 Expert
Tony
Are you a Metz Camera Expert? Answer questions, earn points and help others
