-   lease describe the specifics of your problem below. We'll add your post as a comment to niko_deb's "paper jam problem in pixma mp145. E3 error." problem, and notify you when a new solution is offered.
-   Guest
May 21, 2009
-   my canon mp 145 is showing "E3" error
-   ERIMARC
hi just recently had these problems symptoms: LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover. Also the when the cover was open the inks did not slide out to the left and stayed to the right side. There was no paper jam, but error said paper jam.
Solution: 1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed.. 2. turned off the printer and turned it back on. 3,
while printer was turning on,and makings sound as it does normally when
turning on, I pushed through the piece of paper and the rotors stoped
for a millisecond. 4.the rotors started again and pushed out the paper by it self with out my force. 5. I let the printer get started. and then turned it off and then on. 6. this solved all of my problems. this was the first problem ever with this printer in 3 years.,preety good printer.
MP160 PIXMA paper feed jam E3 error.I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180.With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper.The usual c-clunk sound that indicated the feed roller has been engaged was not there.The screen warning said to remove jammed paper and the printer showed an E3 error. The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front).The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads.Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points.Its not a quick fix. When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier.The lever is actuated by the ink cartridge carrier when it moves to the right.If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer.Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
hi, CANON PIXMA MP160 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
Having trouble with printer..alarm light keeps flashing on..says check printer. will not print...
(More)
Having trouble with printer..alarm light keeps flashing on..says check printer. will not print paper. frustrating!
the printer has a icon of a lightning inside a triangle and the light is on I could print or turn on...
(More)
the printer has a icon of a lightning inside a triangle and the light is on I could print or turn on the printer please help me
i have a canon mp 560 printer and the message the type of print head is incorrect install the...
(More)
i have a canon mp 560 printer and the message the type of print head is incorrect install the correct print head. this is a new priter just out of box.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
