Question about Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder
How can i fix my panasonic dvd recorder error message rc3
When I push setup menu the dvd player go to a message rc3
SOURCE: Error code RC3
I absolutely can't believe this worked for me, I'm so excited!! My error was RC3; my remote had an OK button (not Enter) for a Panasonic DVD/VHS recorder. I held down OK and the number 3 and the remote started working!! Thank you so much, I was getting very frustrated!
Posted on Jan 31, 2009
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
SOURCE: Panasonic DMR ES15 remote stopped working with dvd/recorder...
Try holding enter button and 1 together on the r/c for at least 3 secs
Posted on Sep 30, 2009
SOURCE: error H02 for panasonic dvd s35
My Panasonic DVD Player Model S55 does not read the DVD disk. I get a H02 then no disk reading on the display.
Posted on Jan 19, 2010
  • 102 Answers
SOURCE: I have an error message U81. The DVD recorder
These are error codes generated by the main microprocessor which are tripped by corruption, preventing it's operation and which requires the processor to be reset.
The codes do not actually mean anything at all because the corruption error potentially has a great many possible causes.
It does not point to any specific fault as such.
U81 error literally means 'Microprocessor Communication Error on the Universal asynchronous receiver/transmitter' but I dare say if Panasonic told you that , you would be no further forward.
Corruption can arise for many different reasons .. and is not surprising in a box that has an aerial feeding endless streams of complex data into it, has a mains connection with interference on it, has two internal data storage and retrieval systems, either of which can be problematic... and sits permanently bathed in electrical and radio frequency fields of varying intensity.
Causes can be difficult to identify and may be internal or external.
Such problems may be exacerbated during the transitional phase of the DSO [ Digital Switch Over ]
In practice, all one can do is follow good practices:
Don't stack gear - or give it plenty ventilation if you do.
Ensure good clean mains supplies.
Ensure a properly installed aerial system with sound connectors and adequate screening.... etc.
Posted on Feb 05, 2010
Error rc 1 but cannot engage the setup in order to follow instructions provided by panasonic
press and hold the numbered button
corresponding to the code on the
remote control simultanously with OK button for approx 10 secondes
ex: if rc1 appear on panel press number 1 and ok button on the remote for approx 10 sec. ( if RC2 press number 2, if RC3 press number 3)
Oct 06, 2013 | Panasonic DMR-EZ28K DVD Recorder
I got a new machine, when I transfer from VHS to DVD-R it records, but will only play on the machine I recorded on, it doesn't load on other DVD players, why is that?
You need to FINALIZE the DVD-R you recorded in that unit for it to be playable on other DVD players. This function should be part of the on-screen menu for your unit. (in Panasonic DVD recorders, it's under DVD MANAGEMENT in the FUNCTIONS menu).
If the disc you recorded is already loaded, but stopped, press SETUP on your remote - an on screen menu should appear.
Using the UP/DOWN arrow keys, select DVD MENU and press ENTER. Use the UP/DOWN arrow keys again to select FINALIZE and press ENTER.
A message box will popup 'Finalize disc?' use the UP/DOWN arrow keys to select YES then press ENTER. Finalizing should start and may take a while to complete.
Once complete, the disc is now playable on other DVD players. (from page 32 of the owners manual with the heading 'PLAYING THE DISCS IN OTHER DVD PLAYERS')
Feb 10, 2013 | Toshiba DVR620 DVD Recorder/VCR
Dr 2 message
I just sorted this on my own dvd player. push HDD and DVD buttons on the front of the player together for 3+ secs. Menu will display DR-OFF. Do the same again menu will disolay DR-2. On the remote push mode and "2" together and ths will put the remote into DR-2 mode. All should now be well.
Aug 30, 2009 | Toshiba D-R2 DVD Recorder
RC2 keeps appearing on my Panasonc DVD/VHS recorder...What do I do?
Hold down 1 or number after RC (RC1, RC2, or RC3), and enter/ok button on the remote for 6 second while pointing it to the recorder.
Jul 02, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ28 won't talk with remote
hi you need to reprogram the remote to fit with the unit there have 3 codes for remote 1 or 2 or 3 to reprogram your remote with the code indicated on your display press and hold the [3] and [ENTER/OK] buttons together for approx 5 to 10 seconds, then release
Jun 24, 2009 | Panasonic DMR-EZ28K DVD Recorder
Remote control
re-sync remote by pressing "enter"/"OK" while holding number "1" or "2" or "3" - the proper number should be displaying on unit as RC1, RC2, or RC3
Mar 31, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
DMR-ES46V "set 1" error message
Hi, All you need to do is point the remote at your DVD player and hold both the number "1" and "enter" keys down for about 10 seconds. Evidently that re-sets the remote. It worked for me so good luck.
Pete
Oct 06, 2008 | Panasonic DMR-ES35VS
Panasonic DVD/VCR message U61
Dear stds ~ My DVD Recorder Keeps Opening & Closeing The Tray A Gives An Error Message Saying ~ Repair Has Failed ~
DVD Recorder ~ DMR ES46V Panasonic ~
Error Message ~ U61 !
If Possible To Resolve ~
Please Do !
Before I Buy A New One !
Please Respond ASAP To ~ glvw@nyc.rr.com
Thanks !
May 22, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
Dvd recorder remote control
Anytime your unit displays RC1, 2, or 3 - the remote code needs to be reset. Other messages are "chk remote n" or "set n", n being the number 1, 2 or 3. These remote codes are set in case you have multiple products that interact w/ the remote - so when operating one device the other doesn't interfere. Unfortunately, every now and then for completely unknown reasons, they can slip out of the proper code. All you have to do (if your remote is, in fact, functional) is press and hold the number on the remote that corresponds with that which displays on the unit - in your case the number 3, and hold the Enter key at the same time for about 5 to 10 seconds. This should resume operation shortly thereafter. However, you will not see any confirmation on the display as you are performing this reset. It is trial and error.
Jan 28, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Error code RC3
Sep 12, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
