Question about KitchenAid KCM111OB
Adjust warming plate temperature on a kitchenaid kcm111ob
Adjust temperature of warming plate
Kitchenaid artisan the stir speed goes high around 27 cycles each 10 seconds.. Changed the control plate and the phase board and tried to adjust the screws and it stays the same! Help me please I don't...
Sorry, that answer was for someone else. The only things I've seen to cause high speed running are out of adjustment screws at the top or the bottom of your control plate or the phase board. Start point for the top screws is 8 full turns in from being not even in the hole (both sides) and on speed 1 the bottom screw does not even touch that step in the flat rod that activates the switch and moves the control plate.
Mar 21, 2018 | KitchenAid Food Mixers
My kitchensid coffee mker has a digital code Er 1 Model # KOM111Ob1
"Er1" appears on the brew button
timer display:
A button may be jammed. Unplug the
coffee maker and press each button
several times.
https://www.manualslib.com/manual/405651/Kitchenaid-Kcm111ob.html?page=14#manual KitchenAid KCM111OB Use Care Manual Troubleshooting
Sep 08, 2017 | Coffee Makers & Espresso Machines
Kitchenaid 25 cu. ft. side by side is freezing food in the refrigerator side(meat drawer and crisper)
Have you checked the temperature setting for the fridge? It may be set too low. There also may be an adjustment on the drawer for the crisper that can be adjusted (typically a slide adjustment.
Dec 05, 2014 | KitchenAid Refrigerators
Will not start making coffee push start after 30 second message on screen err2 model kcm5340bo gerald larsen 1-630-323-3112
This is to do with an error in the warming plate function. You may be able to cure this error by completely unplugging the coffee maker from the mains lead and then plugging it back in and trying to brew. If this does not help I would suggest trying to contact the manufacturer to see if it is still under warranty.
Hope this helps and thank you for usinf FixYa
Aug 30, 2010 | Microwave Ovens
How do you adjust a dishwasher door
If the resistance occurs over a range of motion of the door, look for rubbing on the hinges (I have one out of the box that needed the plate straightened.) If the resistance occurs only at latching, I'm still having the same issue (with no rubbing on counters, latch alignment, etc); so I'll try to find and inspect the stike plate (rumored to be on the dishwasher tub near the bottom).
Jul 17, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Installed an ARISTON point of use hot water heater. Water is warm when faucet is first turned on turn just barely warm after a minute. Is there a way to adjust this heater, I misplaced the manual that came...
After installation check the water temperature. If adjustment is necessary, remove front
cover to adjust thermostat. Clockwise to increase the temperature and
counter clockwise to decrease it.
To reach the thermostat:
1. Pry off the round cover plate from its right hand edge with
a small flat-head screwdriver.
2. Remove the Phillips screw revealed beneath the round cover plate.
3. The cover can now be removed by pulling out its left-hand edge.
When reassembling, work in the opposite way being careful to insert the tongue
of the cover into the slot.
Jun 04, 2010 | Bosch Ariston GL4 GL4 Point-of-Use...
Kitchenaid KSM150 stir and slow speeds are running too fast why is this?I just got this machine, its brand new from ebay (america)
It sounds like the speed control plate is not correctly adjusted. If you take the back cover off of the mixer (it is held in place with a screw at the top) and try adjusting the screws on the back plate you may be able to get the mixer to slow down.
You will notice two screws at the top of the speed control plate:
4893809-mz0mnwb1nd52ertzwibinpxu-3-0.jpg If you turn the top screws one quarter turn, both equally then test the mixer it should adjust the speed. Please make sure not to over tighten or loosen these screws as it can damage the speed control plate! You should not have to mess with any wires attached to the speed control plate or the bottom screw.
If you need more information please see the service manual here: http://ep.yimg.com/ty/cdn/mendingshed/kitchenaidservicemanual.pdf
It will specifically go over how to trouble shoot the mixer and how to adjust the speed control plate.
Please let me know if you have any questions
-Colleen @Mending Shed
May 22, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Possible problem with clutches
replace the clutch plates and friction plates
May 05, 2010 | 2003 Yamaha YZF-R1
Adjusting the temperature
Our Bunn VPR was delivering luke warm coffee. The problem was lime scale buildup on the heating element. I recommend using a cleaner such as Brew Rite or a vinegar solution. If it still does not heat properly, unplug and remove the heating element for cleaning. This corrected our problem.
Jun 17, 2009 | Bunn VPR Coffee Maker
KitchenAid KCM111OB Logo
Top KitchenAid Coffee Makers & Espresso Machines Experts
Ismael Rodriguez...
Sal De
Craig Butler
Craig Butler
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
