Question about Qca Spas Jewel Series Topaz Plus Hot Tub
Shut off valve
One of My qca shut off valves broke
2006 sebring 4 cly i bought used with 76,000 now 133,500 timing belt broke is it worth fixing
Need to remove the plugs go into the spark plug hole with a borescope and look to see if there's any bent or broken valves
Feb 07, 2018 | Cars & Trucks
Qca topaz spa parts manual
http://qcaspas.com/qca-spa-parts-chemicals
Aug 20, 2015 | Qca Spas Pool & Spa
Closed and opened shut off valve to strainer housing basket, no water in strainer, how do you know if shut off knob actually opened or just broke the knob?
if the basket fills with water once you open the strainer lid then the valve is opening properly. If you open the valve and the strainer lid but you see no water flowing in then you can believe that the valve is not opening and needs to be fixed or replaced.
May 20, 2015 | Hayward Pool Products Hayward Power Flo LX...
How to change the water filer on a rf4267hars 25.5 ft
You must shut the water valve to change the water filter. If you don't havewater valve near the fridge, shut the main water valve for few minutes. If you turn the water filter to change without shutting the water valve, lots of water flooring the fridge and you do lots of work to remove the water inside the fridge. Shut the water valve, and then replace the filter. Then turn the water valve.
Apr 02, 2013 | Samsung RF4267HARS 25.5 Cu. Ft. French...
My qca spa is surging on pump 2. I know I have no air in the system, but it surges and pulsates to the point it is loud. the inlet is clear, there is enough water in the spa. Can it be the pump? I have a...
Your best bet is to contact their fantastic support team and they will help you by phone.
Sounds like you may have an obstruction in the line or a problem with an inline component
such as the old-style wave motor (in spas that are about 10 years old or more). Sounds like
the pump is actually trying to work, so would not blame this problem on the pump until other components on that second pump line such as a possible wave valve are checked.
Jun 23, 2011 | QCA Spas Jewel Series Amethyst Hot Tub
I HAVE A 1993 DODGE SPIRIT THAT THE ROCKER ARM HAS COME OFF ONE OF THE VALVES
That certainly is an odd problem. Either the nut backed off or the stud broke. As you have the valve cover off anyway have someone who knows what they are doing put in a new stud and rocker, check the push rod for bending, if so equipped, and adjust all valves on both sides. Replace the valve cover gaskets, should be OK as the rocker arm missing just means the spring held the valve shut.
Mar 18, 2011 | Dodge Spirit Cars & Trucks
I have a carrier humidifier model #HUMCCLBP18-A. I shut the water off to install a new filter, and now I cannot get the water back on. I'm not sure if I need to turn the water opener to the right or to...
First I have a question for you. Is the shut off valve a saddle type valve or inline? A saddle valve will mount directly on the water line and be held in place with two machine screws. They will generally have a t type handle. The inline is just what you would think in that it is part of the water line. This type of valve may have the same t handle. Either way to shut valve off you turn clockwise and counterclockwise for on. Off to the right .
Most of the valves used for this application are a needle valve they have a pointed end that seals into a recess in valve body when closed. It's possible that when you shut it off the valve stem broke or just stuck in off position. If there is a small hex nut around the valve stem where it goes into valve body then you can shut off water supply off to inlet of valve and remove the nut and try to pull stem up with small pliers.
Either way if you can't get valve to open then you can easily replace them. Either the saddle valve or compression valve should cost under ten dollars. If you do replace then just follow instruction that come with valve.I hope this helps you some. Thank you
Dec 17, 2010 | Carrier Humidifiers
Qca Spas Jewel Series Topaz Plus Hot Tub Logo
19 people viewed this question
Top Qca Spas Pool & Spa Experts
john h
Ian Summerfield
Ian Summerfield
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
