Lg pg503000 how i repair horizontal line - Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
I have 2 lg repair the same trouble vertical horizontal rolling
Vertical or frame rolling indicates adjustment of the frame hold is required or perhaps there is a synchronisation fault.
Breaking of the picture in the horizontal plane is caused by the line hold requiring adjustment though the symptom can be connected with interior or exterior signal problems or perhaps a power supply fault, especially where both the line and frame are affected together.
It is probably a task for an engineer or at least someone with access to the servicing instructions.
Feb 25, 2015 | LG Televison & Video
What is Horizontal scan output fault? is HOT is faulty or other problem?
Horizontal scan is the scanning left to right on the screen to make up the width of the picture. The height of the picture works the same. This is not an easy thing to repair. You will have to find someone wit the experience to troubleshoot it.
sorry but hope this explains a little.
Jan 28, 2015 | Televison & Video
LG LED TV 42 inch 1080p 120hz horizontal lines and upside down picture
Sounds like a main digital processor board fault. In other words, its main board should be checked. This is a very skilled work, and a normal user can't do it with ease. Contact any expereicned service technician. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jul 25, 2013 | LG Televison & Video
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
My lg monitors screen is one vertical line red is comes up anothers is two horizontal line starting
This is an early indicator the LCD display is going and will only get worse. The only option down the road is to replace the monitor because the cost to repair will exceed the price of a new one.
Jul 02, 2011 | LG W1942S 19" LCD Monitor
I have horizontal lines on my LG ED 500 laptop
I just want to double check, the horizontal line that you have on your screen, is it big as hair line or almost?
Please let me know once you read this.
Jun 15, 2011 | LG E500 Express Dual Series Notebook PC
A vertical white line appears on my LG L1520B 15 monitor
This is a horizontal sync circuit gone.
In English, probably cheaper to replace than repair.
Wouldn't hurt to get a quote if it is free.
Jul 29, 2009 | LG L1520B 15" LCD Monitor
Horizontal line appears even computer is off.
Unfortunately that means your monitor is in need of repair.Most likely you will have to consider replacin the monitor as a 17$ most likely isn't worth the price of repair.
Thanks,
Lee
May 27, 2009 | LG L1751S-BN 17" Flat Panel LCD Monitor
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
