Question about Medion MD1917 PC Desktop
Medion desktop does not boot up, screen blank.
Medion desktop does not boot up. powers on and cd rom opens but does not activate monitor, mouse, keyboard etc. Starts to grind as if it is booting windows but not complete start up. The screen remains blank and fan runs but boot up does not continue. If left for 30 minutes nothing happens and fan just continues to run.
Had same sounding problem with a Medion PC myself. I don't know the cause exactly but the fix I have is this:
Switch off PC, switch off PSU and unplug the power cable from the PC. Then press the power button on your PC. You may see lights and fans start up for just a brief second. This is because there was still charge in the PSU's capacitors which we needed to clear out.
You can now plug the power cable back in, switch on the PSU and turn your PC on.
(I realise this is too late for the original poster's uses but others may find it useful when searching for a problem!)
Posted on Jun 06, 2010
  • 700 Answers
Check first your memory card or RAM card. Reseat it or wipe its edge connector with soft eraser, this will clean its insulation build up in the connector allowing a good contact.
But do this when the power is off and unplugged to the wall socket or disconnect it to the UPS if you have.
If it doesn't power up try to install a good ram spare, could be your ram is failing. If it doesn't boot up. Try to boot your unit at basic setup. To isolate which is making the fault. You gonna have a good spare when doing this.
Hope it is only ram issue.
Posted on May 18, 2009
Have a Medion PC E4075 D want to change operating system from windows 8 to windows 7 ?
hello there u will need a windows 7 dvd with product code to activate just simply go to bios and change boot order to cd rom and boot cd and follow the windows install routine when u are required to install to a partions over rite windows 8 partiion u will have options to do that on install so just follow the instuctions on cd and most of all back up youre personal data ie photos , email and documents mps3 etc
hope that helps thanks
Sep 19, 2013 | Medion Computers & Internet
Power on nothing
wow...can you boot it at all from the installation CD, by chance? any screen action at all?
Feb 16, 2008 | Medion M3 Composer 5200 PC Desktop
Was installing hp starter disk 6500 into dell4550 dell was terned off my mistake and now wont re-boot just blank screen with small light flashing were fast upper left corner of screen
Enter the system bios and set the boot order to boot from CD ROM. If this order is correct and you are still experiencing the same issue. Re-enter the bios and set it to default setup. However, enter the boot order and ensure the CD-ROM is the first boot device and Hard Drive is the second.
Enjoy the power of a PC
Mar 13, 2010 | Dell Dimension 4550 PC Desktop
Black screen
Sounds like your screen is being switched to "Power Save" mode due to inactivity. This should switch back when the mouse is moved. This can take several seconds on a laptop. You can remove this "Power Save" by right clicking anywhere on blank desktop, select "Properties", "Screen Saver" and "Power Settings" then select "Always On" for the monitor.
Sep 13, 2009 | Toshiba TECRA 8000 13.3" TFT LCD Display...
Compaq s5000nx does not boot up. Blank screen. No
Here and here are a couple of links from HP that may help. And here's a great article for troubleshooting startup problems in general. Also helpful may be links at this site.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 11, 2009 | Compaq Presario S5000NX PC Desktop
Trouble Updating BIOS: Medion M3 Director 5100
plz check the fsb of ur new memory.plz conform it the memory is supporting ur motherboard.
Jan 15, 2009 | Medion M3 Director 5100 PC Desktop
Medion PC model MD 1777 wabout 4 yrs old will not start/boot up. Blue light just flickers continusly and makes a tapping sound.
Remove any disk inserted n your computer (floppy or cd) and try again.
Check the cables connection and monitor connection.
If no boot, try boot your PC using the CD restore provided with your machine
Oct 12, 2008 | Medion MD-1704 PC Desktop
Medion director 5000 desktop does not boot
You need to get to the Bios through setup (F2) Change boot configuration to boot from CD Rom. Using your Windows Setup disc,Reboot,press R to get to recovery console.From there you can rebuild your boot configuration.
Jul 15, 2008 | Medion M3 Director 5100 PC Desktop
Processor issue? bios/motherboard?
First, Pull the hard drive. If the hard drive shorts out it can cause all sorts of problems. Generally it detects Hdd before mouse and keyboard.
Apr 18, 2008 | Averatec 3200 Notebook
Medion MD1917 PC Desktop Logo
1,393 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
