Question about KitchenAid KESC307 Electric Kitchen Range
Oven not heating to correct temperature
I have a Kitchen Aid Stove Model KES c307hwh4 and it isn't heating properly in the oven.  When I turn the oven on, the element doesn't completely turn red.  Plus I bought a oven thermometer and when the oven beeps at 350--the store bought thermometer shows a temperature of 250 degrees.  Do I need a new element or is it a "brain" problem?
  • 1 more comment
  • mesasunshine Oct 20, 2007
    This is not a new stove so why would we have a voltage problem now?
  • Anonymous Mar 25, 2014
    we thought that the element went out and bought another one and installed it but it gets red hot at 350 then only stays warm
  • Anonymous Apr 01, 2014
    Model A-BS45D F1WS. Just brought this model home yesterday and it heated to 375 degrees. Burners work just fine. Today oven heating light comes on till 250 degrees then goes off. Won't heat up. Light comes back on at 500 degrees and for broil but neither element heats up and turns red.
  • 473 Answers
First thing that should be checked is proper voltage.  Low voltage can cause this problem.  Have that checked by a professional first then let me know what you find.
Posted on Oct 18, 2007
  • Craig Shelton
    Craig Shelton Oct 20, 2007
    I didn't say you did have a voltage problem for sure.  This is the first thing that should be checked in the diagnosis process for this type of complaint.
Kitchenaid superba stove baking element does not heat
There has to be a baking element. Find it and replace it.
Aug 19, 2017 | KitchenAid Kitchen Aid Superba Series...
Ge stove oven get a f4 fault
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.What is the model number?
Nov 08, 2012 | GE Stove/Range/Oven Oven Control -...
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
Kitchen Aid Gas Range.Convection mode fan does not come on.Glow bare works,as well as the gas element.Flame is the proper colour.Could it be the oven sensor?Model nos.ykgst307hw5
Does the oven heat to the proper temperature and hold it there or does it not heat at all? I could not tell from your description of the problem.
Regards,Richard
Nov 08, 2011 | KitchenAid KGRA806PSS Gas Kitchen Range
Whirlpool gas oven sf315pemb1- oven not heating
Hi, It sounds like the ignitor has gone bad. Remove the floor panel in the oven and locate the ignitor fastened to the burner. There should be 120V going to the ignitor harness.
If you have voltage but no ignition, change the ignitor.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 27, 2009 | Whirlpool GS445LELS Gas Kitchen Range
Kitchen Aid Stove goes into clean mode
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%^&Y
Apr 13, 2009 | KitchenAid KERC506HBS Electric Kitchen...
Oven vents on front are stained and ugly. How do I clean them?
sorry but you wont be able to remove the "stain" what has happend is the paint used by maytag has become discolored from the oven vent heat and the only way to correct it is to replace the panel. they are available but for about 80 bucks. you could try to paint the panel but it will do it again.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Oven doesn't heat up properly
ovens can be calibrate for the right temperature. the adjustment screw is locate inside the shaft of the thermostat. when you remove the oven knob.
Nov 15, 2008 | Whirlpool GS460 Gas Kitchen Range
How do you tell if the oven is preheated to the correct temperature?
Follow this link to the online user manual, it describes the operation of this stove http://products.geappliances.com/ApplProducts/images/t07/0000009/r09077v-1.pdf
This should provide you with all the information you need to properly operate this model range,.. Hope this helps you.
Sep 01, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven will not bake properly
as i have said before cook times are only a guide as all ranges in different locations cook differently! get to know your stove
Dec 10, 2007 | Frigidaire GLEFM385D Electric Kitchen...
KitchenAid KESC307 Electric Kitchen Range Logo
383 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
