Question about Breville Vin170 Extreme Steam Digital Steam Generator Iron, 2400 Watt
On off button and control light flashing on iron, but nothing happening, breville vin 170
Vin 170 filter how much
Fixya does not sell filters. Check with a local appliance parts supplier.
Nov 13, 2016 | Irons
Digital settings flashing
Breville VIN170 Extreme Steam Digital Steam Generator Iron, unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on.
Below is a link to the user manual for the Iron
http://www.breville.co.uk/downloads/dl/file/id/378/steam_generator_iron_vin170_instruction_book.pdf
Hope this helps, if you require any further assistance please contact me.
Oct 18, 2014 | Breville Vin170 Extreme Steam Digital...
How do I replace breville ironing catriged
Hello there,
From Breville website, there is NO insruction manual for the VIN 002 !!!!!
Go here for all of them
http://www.breville.co.uk/cat-search?cat=Irons&term=Manual
I don't know what you meant by 'cartridge' but Just looking at one randomly, it says.......
Anti-scale filter
Your iron is fitted with a permanent anti-scale filter. This filter is fixed and cannot be
removed for cleaning
Hope this helps
Sep 16, 2014 | Breville IN002 Iron
Filter light flashing what do I need to do no manual available
Aug 07, 2013 | Breville Vin170 Extreme Steam Digital...
Breville VIN 214 iron leaking - can anyone help please
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
  4. God bless you
Apr 04, 2013 | Black & Decker Prestige X805 Iron
How do i reset filter flashing on my breville iin195,just replaced filter but still flashing
how do i reset my filter on my steam genorator iron breville iin195 many thanks if some 1 could help please
Sep 28, 2011 | Breville Irons
How do you reset the water filter light when you put in new filter on Breville Steam Generator please
Ok, had this too. Done some research and it looks like you have to unplug the iron from the mains , keep both the power and steam level buttons depressed and then plug in and switch on.
Chris.
Feb 12, 2011 | Breville Irons
Need manual for swan steam generater iron model s15040
you have probably solved this by now but
I just got the same model new
switch on instructions as follows
press and HOLD the POWER button for 3 seconds to switch the unit on
once temperature has been reached, press and HOLD the steam button on top of the iron for up to 20 seconds
this will prime the steam pump and only has to be done once for each ironing session
the pump noise will stop once it has been primed with water
hope this helps if still needed
if you need the user guide, let me know, I'll scan it for you
Wendy
Jun 29, 2009 | Black & Decker Steam Generator SG200 Iron
Red light flashing
Blinking red light is a standby phase, its not going to get hot like this. Shake it or just start ironing, the red light will go solid and the plate will heat up. The red light will go off when the plate is hot enough. It will go on again (solid) after a few minutes to keep the plate at the right temperature. If you leave it standing around for a while it will begin blinking again (standby).
These irons are known for malfunctioning though, mine stays in standby and the plate never heats up! Hopefully yours is fine.
Feb 07, 2008 | Braun SI6225 Iron
Breville Vin170 Extreme Steam Digital Steam Generator Iron, 2400 Watt Logo
165 people viewed this question
Top Breville Irons Experts
Tom Chichester
Rani wadia
Rani wadia
Are you a Breville Iron Expert? Answer questions, earn points and help others
