Question about Sony VAIO RB30C (VGCRB30) PC Desktop
Won't boot up
When i push the power button the fans kick on at high speed, but that's all that happens. The lights on the keyboard are not on and the monitor does not come on.
5 Suggested Answers
  • 12 Answers
SOURCE: VAIO PCV-W600G DESKTOP
Try unplugging components one by one (disk drive power, CD power, video cards, etc) with the system unplugged and see if the fan speeds up when you restart it. Note than when you remove certain cards, video for example, you may get beep codes.
Everything in a slot on your PC shares a common power bus so any card installed may be pulling too much load on your power supply. Pull em one by one re-starting between each one.
If this doesn't locate the fault, check the power plugs to your disk/cd drives and ensure that you are getting 12VDC between the yellow and black wires and 5VDC between the red and black wires.  If you are not, and you have already pulled all cards/drives, you have either a defective power supply or your motherboard is drawing too much current.  In the last case, pull your memory cards one by one and re-start between each pull.
YOu will get memory size errors if you let the boot procedure go too far but all you want is for the fan to go.
You  can accurately pinpoint POST errors with a POST diagnostics board available at most PC shops. It comes with a code manual.
Posted on Oct 15, 2007
customers184
  • 154 Answers
SOURCE: What lights should be on when the computer boot
You may possibly have a bad video card and a bad circuit on your motherboard. I would have the motherboard replaced. Some motherboards come with video cards, so once it is replaced, you may alerady have a new one with the motherboad part. If you not versed in doing this, you may want to get a professional to do so.
Posted on Nov 23, 2009
shijin007
  • 64 Answers
SOURCE: Sony VGCRA810G Desktop Viao computer
Dear 911,
The problem may due to that.... So Plz check with another SMPS(power supply).
Reply me the status...
cheers
Posted on Jun 17, 2011
pctuneuo2012
  • 10 Answers
SOURCE: My Vaio vgc-rb52 turns on, but nothing on the monitor. cooling fans both blowing.
try to start on safe mode
restart pc taggle F8 key see if you get options and select safe mode 3
then perform a driver roll back under device manger or system restore to earlier time
could be an update did not finish instaling creating a system error or loaded uncompatible driver in you video card
try anothe video card if you have one pci pci xpress on ecven a pci old video card could help you at least get image back in order to continue troobleshooting
Posted on Jul 24, 2012
Craftmade Ceiling Fan Problems
Make sure your fan is on high with the pull chain switch. Push the remote Hi button then pull the chain until it's on the high speed, Then DO NOT use the pull chain. Same with light , Push light button on remote then pull chain until it's on then leave the chain alone. If that doesn't do the trick then you probably need a new receiver.
Jun 15, 2013 | Craftmade International CXL52 Electric...
Acer am1100 won't start up
Discribe what happens when push the on/off button and you try to boot, fan spin? LED's blink? HDD/DVD light blink? Sound? Any thing on screen at boot? What blue light?
Feb 26, 2013 | Acer Aspire AM1100-B1410A Refurbished AMD...
Computer won't do anything, keyboard does not light up, screen is blank
So there is not so much as a BIOS message on screen? Any beeps?
If there is no life at all, you have a CPU/motherboard failure. This may be direct or indirect (e.g. no power to MoBo). Check your connections.
Otherwise, your boot device may not be operating. This is usually a dead or disconnected HDD. Check that it is plugged in. Does it get warm? Can you feel any vibrations from it? It should spin even if your cpu is dead but MoBo is alive.
Oct 26, 2012 | HP Compaq Presario SR2038X PC Desktop
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
Push button is always stuck on the fan runs on high speed will not boot
yes will not boot because the power switch button is always contacting to switch. is like a long press about 3 or 5 seconds it can be turn off the system. remove the front cover clean the push button power switch housing and apply lubrication such as grease or oil.
Oct 11, 2009 | Everex GA3400 PC Desktop
Casablanca fan only runs at highest speed
When I turn on any of the fan speeds fan does not come on. When I remove the blades and turn on the ceiling fan on and give it a push the fan stays running. What could it be?
Aug 30, 2009 | Casablanca Fan Panama II 50" Ceiling
When I hit power button on computer, power light doesn't come on...and the fan kicks on, but nothing else happens. nothing shows up on monitor except the test screen with 3 colors...the computer doesn't...
THis sounds like a power supply issue.. I had a similar issue with mine. my fan would kick on for about 2 seconds then shut off.
Hope that helps
Ciza
Oct 29, 2008 | Gateway (4000274) Motherboard
Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
Oct 27, 2008 | Casablanca Fan Bel Air 3811T Ceiling
KINGSTON VALUE RAM 1GB PC3200 MEMORY
You have the answer in your question. I have checked the PC specification and you are right, it uses PC2700 memory. Therefore you need to install PC2700 memory. PC3200 memory will be the wrong speed and will not be supported.
Daryl
Apr 18, 2008 | Computers & Internet
Sony VAIO RB30C (VGCRB30) PC Desktop Logo
20 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
