Question about iLive 37in Bluetooth Soundbar - Itb382b -
Itb382b remote will not learn tv remote - iLive 37in Bluetooth Soundbar - Itb382b -
My sound bar itb382b switches sources on its own. Any idea why it won't stay on source we choose?
if you are using a remote that is the same or similar to the brand name of your sound bar then particular buttons my trigger your sound bar to change devices for example when you change the channel on your TV with your TV remote it might trigger your sound bar to change as well. this is common for infrared receivers
Dec 08, 2014 | iLive ITB382B - 37" Bluetooth Sound Bar
Original and replacement both have same problem of big increase in volume every 10 minutes or so and we have neighbors to worry about. Remote doesn't work quickly in turning volume down, but we need to...
The source is your issue. The amplifier or TV itself. Try another TV plugged into the amp or some other sound source like a iPod, etc, to test if TV or amp. This is your next step and should show you the proble!m.
Apr 17, 2014 | iLive itb382b 37 hd wireless bluetoothr...
ITB382B LLive manual
I am having trouble getting it to connect to my surround and tv properly.
Jan 08, 2013 | GPS
Need code to make universal remote work on sony tv
hello sir,
i m having problem please n please solve it........
i hv recently buyed a new LCD Sony Bravia KLV32BX300 ON 2nd FEB. 2011 and im having Airtel digital tv HD alos and i have connected LCD and DTH with HDMI cable ok....then problem is that how to make my DTH universal remort to operate my tv remort sensor..how to sync..my sony remor with dth remort..and i have try my best but im faild i know my dth remort code that is [OK+2] HOLD THESE buttons atleast 3 sec. ...............tell me what was my sony bravia pairing code.........please please nnnn please
Oct 25, 2009 | Sony Bravia KDL-42V4100 42 in. LCD TV
How do u program Bush DFTA13HD STB TV buttons
The following is an extract from the Bush DFTA13HD/ DFTA13HDSIL user manual, page 9;
1. Press STUDY key until Red LED remains lit (for about 3 seconds)
2. Point Converter (Bush) remote control to TV remote control directly, keep the distance about 1~3cm
3. Press the "Power" key at TV/s remote control to send signal to Converter remote control. The LED light will flash till steady. Then press "Power" key at Converter remote control. It will record the signal.
4. Now the Power key can turn on/off TV/s power
5. Repeat settings of learning for the other keys
You can repeat Step 3-4 for setting of learning for the other keys at TV remote control, such as VOL /-, CH /-, and F1, F2 are reserved for any other keys you want to set up.
Note:
1. When you have finished setting the learning keys, press the STUDY key to leave the learning status, and the LED light will turn off.
2. The learning function of this remote control may not support all types of TV sets, if you still can not control your TV after you have attempted the above steps, then this remote control may not support your TV or its remote control.
Jul 19, 2009 | Televison & Video
New RCA RC246 remote with new RCA L40FHD41 TV. Dish remote won't adjust volume. Any ideas?
The Philips Universal Remote SRU4208WM/17 works with this TV. Must use the code learning feature.
Jul 12, 2009 | Universal Remote Control DIRECTV Universal...
Cox Cable Communications remote (URC 7820b01-09541) with Samsung
The Cox URC-7820B is not the one shown in the picture.Guess that's the Samsung LCD TV.
Here is the Manual for the 7820B, which is the Learning version of the 7820. Learning means if the TV codes for Samsung in the Manual do not work, then you can Learn them from the Samsung Remote by pointing their IR light(LEDs) at each other and follow the Learn the instructions in Manual:
www.urcsupport.com/images/uploaded_images/Cox_M7820.pdf
Feb 09, 2009 | Samsung TV Remote Control
iLive 37in Bluetooth Soundbar - Itb382b - Logo
82 people viewed this question
Top iLive Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an iLive Health and Beauty Expert? Answer questions, earn points and help others
