Question about Soltek SL-K8M800I-RL Motherboard
Bios file hi sir i have soltek main board 85drv4-c please send me bios file to boot by floppy thanks
    Brigadier General:
  • 10,406 Answers
SOLTEK has gone bankrupt -- their web-site is "down".
So, there is _NO_ support (BIOS-update, drivers, replacement parts) available at all.
Posted on May 27, 2009
Where can i get a manual for a soltek sl-85drv4-c motherboard?
Go to this link:
http://safemanuals.com/user-guide-instructions-owner-manual/SOLTEK/sl-85drv4-c
Once you are at the sight, look on the right side of the screen. There should be an area at the top that says user manual for soltek sl-85drv4-c. In that box, you will see a PDF file with a hyperlink right below it. Click on the hyperlink and you should be in business. Let me know if you need further information.
Kerry L
Apr 10, 2009 | Computers & Internet
My computer hangs when i boot it by any bootable cd or floppy
Apparently you solved your problem and the system no longer hangs, though you never supplied the information requested.
Apr 07, 2009 | Soltek X400A (SL-85ERV2-L) Motherboard
Soltek sl-k8trpro939, error message BIOS not Loaded,
To clear cmos you'll need to remove the cmos battery from the motherboard for about 5-10 seconds then replace. You need your motherboard disk in order to load the bios. If you do not have this disk then you will need to go to the board manufacturer's website & download the bios. Follow the directions they have at the site to make a bootable disk & then boot from this disk. Hope this helps & please remember to rate my answer. Thanks.
Jan 25, 2009 | Soltek SL-KT600-RL Motherboard
Latest bios update and drivers for Soltek SL-85DR3-C rev:A3 silver PCB
SOLTEK has gone bankrupt.
Their web-site is "down".
So, there is *NO* "support" available from SOLTEK.
I am not a lawyer, but since DRIVER GUIDE is offering a service for a fee, it probably is legal for them to charge a fee.
Jan 11, 2009 | Soltek SL-85DRC Motherboard
Flashing the bios
1. Download the BIOS flash utility.
2. Download the BIOS rom file.
3. Format a floppy drive, with system files so that it is bootable.
4. Copy the utility and the rom file to the floppy drive.
5. Boot from the floppy drive.
6. At the c:/ prompt enter the name of the flash utility file followed by the name of the rom file. Example: awd816a.exe romfile.rom
7. Let the program run. Do not turn off your computer until prompted to do so.
Thanks and please take a moment to rate as fixya.
Dec 22, 2008 | Matsonic Computers & Internet
Won't boot
Under normal circumstances you do not need to boot into a drive to flash your BIOS. Normally you would take a dos boot floppy and the latest BIOS firmware and put them on a floppy, which is then inserted into the floppy drive before turning the computer on, and if the bios boot priority is set to boot from floppy before the harddrive, it will ask to boot from the floppy, which allows you to flash the bios from a command line or text graphical interface.
*Note that you may be able to use a cd, but floppy is the oldschool way - if you could boot into an operating system you could use the modern methods which flash the bios while running an OS.
Your board comes with Q-Flash in the BIOS, which means you are able to log into the bios and flash it using this utility and by putting the BIOS firmware on a floppy and inserting it into the computer.
Please see Here for instructions and Here for the latest firmware.
If you cannot access the BIOS, meaning the BIOS is completely bricked, then you will need to buy a new motherboard. Unfortunately there is no way to fix a BIOS which is completely bricked.
Dec 16, 2008 | Gigabyte GA-K8VT800 Motherboard
Startup no beep, bios defective...how to replace bios then...
you would usually flash/update the old bios, with the new bios via floppy disk drive, or cd if your motherboard supports it. if you go to the manufacturers web-site-support or downloads. you should be able to get the latest bios for the board. also read any notes on " flashing the bios " if the board won,t boot, you can,t damage it anymore than it already is. nothing to lose everything to gain.
if you have to send the board to be unsoldered/re-soldered very expensive usually.
if this information solves your problem, please rate as Fixya.
Many thanks for using the forums.
Mike @ compurepair.
Nov 18, 2008 | Foxconn 661FX7MF-S Motherboard
Motherboard drivers lost
You might want to try here
http://drivers.softpedia.com/progDownload/Soltek-SL85DRV4C-Bios-112-Download-5628.html
or here for the bios
http://www.driverslab.com/downloads/Bios/Soltek/SL-85DRV4-C_1_2_A-Windows_95_98_ME_NT_2000_XP/6799.html
Feb 23, 2008 | Computers & Internet
Bios update
go to site dl it run it should auto do itself or install on floppy ok then boot into flooppy 1st tell bios floppy 1st ok or cd ect ok
Feb 11, 2008 | Soltek SL-915G Pro-FGR Motherboard
Soltek SL-K8M800I-RL Motherboard Logo
262 people viewed this question
Top Soltek Computers & Internet Experts
clar4444
Level 1 Expert
Paul Bade
Iqbal Husain
Iqbal Husain
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
