Question about Cobra 19 DX IV CB Radio
My Cobra 19 CB emits a pieping noise when RX or TX
I replaced the TDA2003 already worked fine for a liitle while but in hot and humid location radio started to piep again.
I have 6 units same problem different locations / set up / antenna all in hot and humid location
  • sentani_avio May 20, 2009
    I have 4 units with the same problem. When they are hooked up to the battery, with solar panel charger, they will start making this noise. When I hook them up to my bench power supply and test them with a AM/FM 1200S I get the same problem when I heat up the TDA2003 ic. I replaced the ic's but get the same problem.
    Do I have to look at other types of radios that are able to work in a hot and humid invironment? Any ideas on a better cheap radio?
    it's a Cobra 19DX IV, the audio amp is a TDA2003.
    You know if I could upgrade the TDA2003 with something similar?
informatica
  • 1114 Answers
SOURCE: Cobra 75 WX ST 40-Channels Handheld CB Radio manual/antenna
Hi - You can download the manual from the link underlined in blue below:
75 WX ST
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 31, 2008
  • 10 Answers
SOURCE: I have a Cobra 29 LTD with Bluetooth. I have no
if the antenna warning indicator is lighting during transmission then the antenna is either located and.or installed improperly or a defect exists in the antenna mount or the feedline itself, including connectors.
Posted on Jun 10, 2009
Benimur
  • 6966 Answers
SOURCE: Radio lights up, but no TX/RX.
Hi and welcome to FixYa,
Based on your description, a possible drift in the local oscillator.  Check the 10.24Mhz crystal filter and its local oscillator for output and consistency.
Good luck and thank you for asking FixYa.
Posted on Aug 24, 2009
  • 1274 Answers
SOURCE: Red RX/TX and red ANT light on my CB
Well,first hand ,some cobra radio,s have red some have green RX/TX lights, but are you modulating? Some green lights turn red. What is your standing Wave on the antenna,s? You need to check it and the output of the radio. To do this you need a watt or field strenth meter. Can get one at Radio Shack. Your standing Wave is ok as long as it is below a 2. That has to be done on the antenna. ..hope this helps...
Posted on Mar 12, 2010
Testimonial: "Thx the rx/tx light is supposed to turn red I found out. Still trying to get the antenna prob fixed though."
SOURCE: CB Radio has red light on Rx and red light on
The red light on rx is fine, it's supposed to change from green to red. The red light on your antenna means you have a swr issue, something in your antenna system is not right. You need to go to a reputable CB shop and have them check your swr.
Posted on Aug 09, 2010
Good day I have an cobra 148 Gtl tx and rx a working but no out put
It might not seem obvious but on many, if not all, current CB radios have separate wires coming from the microphone for RX and TX. It seems like the mic wire for TRANSMIT may be open. It is a common failure.
Feb 28, 2015 | Cobra 148GTL
148 gtl cobra cb radio and the rx/tx light stay on
This sounds like a problem with the MB3756 Regulator IC. It controls voltage regulation and TX/RX Switching. It is a common failure in these radios. Check voltages with schematic that can be found at
CB Tricks Home Page
Sep 02, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
Mirage 88.. RX okay TX distorted
try the original mic . If its still distorted then it,s a radio problem.
Mar 14, 2012 | Galaxy Radios DX- 88HL Base CB Radio
Cobra 29LTD Classic RX seems to go off frequency. Transmit is fine, but can't receive on same channel. i.e. TX on Ch 11, but RX some other frequency. Was talking to my wife and suddenly, her signal was...
all functions of the radio are performed by the main IC 2816c . The frequency is controlled by this also and if it is blown you will loose your frequency and the problem that emits is in your statement.
Oct 23, 2011 | Cobra 29 LTD CB Radio
The 19 DXIII only receive, not transmit, need wiring diagram to analyze the switching circuits strong 73 Marcosbaldo PY2MPN Px2H8904
its the vertical boards inside the radio.. if they vibrate loose it will loose either tx or rx or both.. resolder them they should return to operation.
Aug 23, 2011 | Cobra 19 DX III 40-Channels Base CB Radio
I have a Cobra 29LTD serial number 43011339 that has no TX or RX. The radio powers up but the RX led is not on. TR 23, R105 and TR 21 get hot to the touch as soon as the radio is powered up. I replaced...
Hi,my name is John. you need to adjust both TR23 & TR21 to 8 volts.......then you should be OK.......good luck. Rate this solution on the four thumbs--up.thanks John.
Oct 07, 2010 | Cobra 29 LTD CB Radio
Mar 11, 2010 | Cobra 29 LTD CB Radio
I have a 148f gtl with no rx on am only,just noise.tx good and rx on side band fine,also tx on am. thanks ,bocephus
Check xtal X1 (7.3450 MHZ). It's in the am osc. I had exactly the same problem. I live in a highly corrosive coastline area
Apr 11, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Tx: fine rx : no..
Your power output has blown, they are called your "finals" they can be replaced quite cheaply.
Mar 26, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Cobra 19 DX IV CB Radio Logo
146 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
