My viking opal 670 always has a main motor-overload
4 Suggested Answers
bargainbox
  • 1388 Answers
SOURCE: I have a husgvarna viking 830. I was working on
If the lever to lift the presser foot is now just loose, take the face cover off (Left side aound light) and take a look, presser bar may have over extended and fallen off the lever connection...needs to be taken even higher as the lever is eased back and reset to "normal"
Posted on Sep 02, 2009
  • 104 Answers
SOURCE: husqvarna viking diamond deluxe embroidery machine main motor overload
I'm not familiar with the Diamond machine but suggest the following. The motor is overheating. Is the sewing machine cord plugged directly into an outlet or are you using extension cords? Voltage drop due to long or light duty cords can cause the motor to run hot.
Can you trun the handwheel freely? If not, there is friction or binding in the machine that needs to be corrected. The blank screen and reboot are simply protection devices like a circuit breaker in your home electrical circuits. Find the source of the problem!
Posted on Mar 24, 2013
  • 72 Answers
SOURCE: where is the serial number on the opal 670 sewing machine
The serial number is on the bottom of the sewing machine. There is a sticker that states where the machine is made, what the model and serial number are as well as the electrical information. Just tip it over onto the back of the machine.
Posted on Jan 12, 2015
What does it mean when it says main motor overload please wait
If it's a Huskylock Serger it means the machine is in a "bind," possibly think fabric, etc. The motor is "overloaded" and shuts down. If it continues after serving for a short time on normal fabric the motor needs to be rebuilt or replaced. See a local Viking Service Tech for repair or motor replacement.
If it is a Sewing/Embroidery Machine it may still be an issue with the motor but could also be the main control board or power supply. Again see a local Viking Service tech for repair.
Apr 14, 2015 | Husqvarna Viking 1
How do I find out what year my Contempo sewing machine model number 670 FB was made?
Hi Nikki
if you know which company made it go their website.
i saw that Husquarna made a 670 model
take a look and see if it is the same one, if not try to find the manufacturer.
http://www.husqvarnaviking.com/en-US/Machines/OPAL-670 ww35 husqarnaviking com
all the best
kolbrun
Apr 05, 2015 | Sewing Machines
Ricoh mpc 6000 sc 670
Engine startup error - sudden communication reset between controller and VBCU 7/29/2008 Helpful SC 670 Engine startup error - VBCU defective 7/29/2008 Helpful SC 670 Engine startup error - VBCU installation incorrect 7/29/2008 Helpful SC 670 Engine startup error - LCT lift tray sensor was shorted 9/2/2008 Helpful SC 670 Engine start up error. Check main power supply, cn 409 for 5volts 7/20/2009 Helpful SC 670 Engine startup error - Replace laser unit and follow SP adjustments after laser unit replacement 4/5/2010 Helpful SC 670 Engine startup error - IOB board defective 6/8/2010 Helpful SC 670 Blown fuse 2 on VBCU due to shorted harness in registration motor harness 6/8/2010 Helpful SC 670 Engine start up error - Check wiring for df feed in cover.. 8/6/2010 Helpful SC 670 Engine startup error - Replace finisher main board 10/26/2010 Helpful SC 671 Controller mis-match error - Install correct controller b
THIS UNIT IS VERY HARD TO WORK ON YOU NEED A SERVICE CALL, GOOD LUCK! -Carl
Mar 31, 2015 | Ricoh Office Equipment & Supplies
Where is the serial number on the opal 670 sewing machine
Jan 11, 2015 | Husqvarna Sewing Machines
Husqvarna viking diamond deluxe embroidery machine main motor overload
Mar 23, 2013 | Husqvarna Sewing Machines
Why does my 936 serger keep showing overloaded ?
My suspicion is that Viking sergers (905, 910, 936) bind up after heavy use and years of service. In other words, they are not "lubricated for life". Can you turn the handwheel on the machine? If not (or if extremely hard), you now know what the motor was dealing with. My guess is the motor is burned out, but you need both a total overhaul of the main shaft bearing system (cleaning the bearing and relubrication), and, a new motor.
I probably should consider repairing sewing machines in my retirement.
Mar 18, 2013 | Husqvarna Huskylock Computerized 936
My husquavarna Emerald 183 ights up when turned on but will not ''go''. I followed everything the manual said to do ie remove bobbin, plates, clean out any lint or threads etc then put it back together -...
sounds like an overload of some sort. Suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
If you bought the machine new the warranty may still be in effect.
Feb 13, 2010 | Husqvarna Viking 1
I have a Husqvarna Viking quilt 870 sewing
The overload message is usuall due to a bind in the mechanical function of the machine. When the motor has an extra "load" caused by something like a tight belt or dry bearing, it "overloads" the motor and the error message is displayed. It is doubtful your problem is computer related. Either way a trip to your service tech is required. If you continue to sew with it, you do run the risk of possible damage to some other parts of your machine. The computer portion of your Husqvarna is guaranteed for 5 years and the mechanical parts carry a 20 or 25 year guarantee depending on when you purchased your machine. A copy of your bill of sale from a Husqvarna Viking dealer or a stamped warranty card is the proof of purchase needed to obtain warranty replacement of parts. Labor is only guaranteed for 1 year.
Sep 26, 2009 | Husqvarna Viking 1
Sep 01, 2009 | Husqvarna Viking 1
Motor constantly running
My Viking bottom freezer mount is VERY loud as well... in the refrigerator part in the top back it grinds and runs ALL day and ALL night - what is the solution?
May 23, 2009 | Viking Professional Series VCBB36 Bottom...
42 people viewed this question
 Grubhead
Grubhead
