Question about Baby Gear
I lost the bolts and screws to my toystory toddler bed
Where can i find out what kind i need?
SOURCE: converting crib into toddler bed
call 1-800-2951980 and they will e-mail you the directions.
Posted on Sep 08, 2008
SOURCE: Crib to toddler bed instructions
I need instructions to transform my mama and papas Aspen Cotbed into a bed! We have lost the instructions! Can u help?
Posted on Oct 17, 2008
  • 5 Answers
SOURCE: Need instructions converting crib to toddler bed
I have all the instructions posted in an album on photobucket.com. In the site only search field (not the web search) type emilykenepp and change the search criteria from images to people. This should bring you to my profile- under my albums I have an album titled Graco Lauren Crib Assembly Instructions. Click on that and you should be good to go! Pages 10 and 11 are for the conversions. Also, for any further assistance, the customer service number for LaJobi (the people who actually manufacture the crib for Graco) is 1-888-266-2848 and for Graco it's 1-800-345-4109. Hope this helps!
Posted on May 07, 2009
SOURCE: toddler bed
Here is a website that has the instruction manual in PDF format.
http://common.csnstores.com/common/marketing/baby/delta%20childrens%20products/Toddler%20Bed%20Instruction%20Manual%20(dora).pdf
Posted on May 24, 2009
SOURCE: generation 2 worldwide toddler bed lost all hardware (screws, etc
You should not attempt to buy hardware to reassemble the crib. Gen 2 has had recall problems with their products. One of the ways a recall is performed is to have the customer send the hardware to the company instead of the whole assembly, rendering it useless. If you received one without hardware, it was probably recalled.
Posted on Feb 09, 2010
No directions for a Bily (baby I love you) crib set and how to change to a toddler bed.
I lost my screws to the bily crib the one that goes into a toddler bed does anyone know what screws and sizes I need to buy?
Jul 03, 2012 | Baby Gear
I lost my manual, I need to know how to transform the crib into a toddler bed
Converting a Simplicity Crib into a Toddler Bed:
Please note, Simplicity has gone out of business and the Simplicity Cribs should NOT be used as cribs. They were sold at Walmart, Target and BabiesRUs. The word on the street is that Walmart is the easiest to deal with when it comes to returning them. Those who wish to return Simplicity cribs don't need a receipt, they can just take them to Walmart for store credit. BabiesRUs was apparently giving about $65 while Walmart was closer to $190. Again, this is just what I have heard from others.
You can find the specific information on the Simplicity recall here.
If you do want to use your Simplicity crib as a Toddler Bed, I have not read any warnings against this. Again, I might just take it to Walmart anyway and get a store credit and perhaps buy a new convertible crib. You can get some great ones on Amazon for around $150 with delivery included.
I would pack it up, take it in for store credit, and get a new crib!
You can get some great deals these days on cribs, there's a great one on Amazon for $150 with free shipping so it's kind of a no-brainer.
As I have heard, Walmart will take it back, no questions asked and no receipt necessary and you can get a brand new one with brand new parts, brand new instructions and no recalls or risks!
Good Luck.
Here's one of my favorites:
mkd123_2.jpgGraco Sarah Classic 4-in-1 convertible bed
If you still want to convert it, here is what you need to do:
1. Remove the front panel of the Simplicity crib. Use an Allen wrench and 45mm bolts (there should be extras underneath the crib, along with an Allen wrench, but if there aren't then you can pick some up at your local hardware store.)
2. Check the mattress support. It needs to be in the lowest position available, which will allow the toddler to get in and out of bed easily. It is also the only position that will make the rails line up properly with the pre-drilled bolt holes. To lower the mattress, unscrew the four bolts from the four corners of the mattress support and slide the support down. The holes for the lowest setting are just about the bottom wood panels. Use your Allen wrench to reattach the mattress support with the same bolts you pulled out when the mattress was in the higher position.
3. Attach the toddler bed rails to the crib frame. Use two 38mm Allen bolts on each rail. There are pre-drilled holes in both the rail and the crib frame. Line up the holes and then loosely screw the bolts into place. The bottom of each rail has a metal L-shaped hook. This will slide under the mattress support. Use a 19mm Allen bolt to attach this piece to the mattress support. When everything is lined up and screwed in loosely, go back and tighten each bolt. Repeat on the other side.
4. Check the entire crib frame for loose bolts. Use the Allen wrench to tighten all the screws. Toddlers can be rough on their beds, so it is important to make sure the bed is safe. You should recheck for loose bolts often. Jumping and climbing on the bed can easily loosen the bolts and screws.
5. Don't forget to hang onto the front panel and store it carefully, you will need it later to convert the bed into a full sized bed.
Jan 23, 2011 | Simplicity for Children 4-in-1 Convertible...
Trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Mar 25, 2009 | Delta Enterprise Baby Gear
Generation 2 worldwide toddler bed lost all hardware (screws, etc
Jan 17, 2009 | Baby Gear
Convert crib to toddler bed
I finally found my instructions!! It's actually really easy to convert to a toddler bed:
Step one: Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
Step two: Lower the mattress to the lowest setting.
Step three: Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
Step four: You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
That's it.. You've now got a toddler bed!
Apr 26, 2008 | JCPenney All-in-One Nursery Crib
Convert to toddler bed
They do have answers on their website, you may want to check your printed or online crib instructions to remind yourself how you put the crib together, too.
I found the answers here:
http://www.pali-design.com/index.php?path=customer_services&template=faq&section=customer_services&subsection=faq&page=faq
i've pasted them below. You can make it a toddler bed without a side rail just by removing the movable side of your crib, and you can install the side rail instead of the movable side if you want it to look a little more finished and help keep your child from rolling out of the bed.
FAQ
How to convert a crib into a toddler bed
To convert a crib into a toddler bed you must loosen the two front gold bolts left and right side of the crib and remove the dropside (the front gate that goes up and down). After removing the dropside be very careful that you tighten back your two gold bolts.
How to install the streight rail (toddler rail)
To install a streight (toddler) rail loosen the two front gold bolts left and right side of the crib and remove the dropside, once you have removed the dropside replace with the streight rail. Always be very careful and make sure you tighten back your two gold bolts in the front.
Oct 14, 2007 | Pali Sabrina Crib
Baby Gear Logo
120 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
