Question about Westinghouse LTV-27W2 27 in. HD-Ready LCD Television
Fixing Westinghouse LVM-37w1 LCD TV no turn on blue light then goes yellow
  • 3 Answers
SOURCE: LVM-37w1 37inch LCD HDTV
It is worth fixing but you have to replace the power supply. It is a fairly common problem with the Westinghouse units.
Posted on Oct 24, 2007
  • 298 Answers
SOURCE: LVM-37w1 Replacement Stand
The stand for this model is not available complete. Please contact Eddie for more info @ (562) 236-9800 x128.
Posted on Mar 06, 2008
SOURCE: Westinghouse LVM-37w1 Goes immediately into standby mode
Power suplly. In my case I should have done research on a lot of things before purchase - westinghouse doe snot acknowled any power supplly uissue but they would say that, and this is a direct quote from them, "Westinghouse's failure rate is less than 2%, which is great by industry standards. Unfortunately, when you sell millions of televisions, 2% is still a lot of televisions. There have been no recalls on this model (or any of our models), but it's not surprising to find a similiar issue on more than one of millions of televisions."
In other words they calim there is nothing that is really their fault. However the first thing the repair guy said before he even looked at it was "Power supply". He opened it up and tested - power suplly. However to complicate matters more I made is huge mistake of buying into a scam offered by eCost via Service.net . A two year, 100%, in home service, warranty. Bottom line is since June 8 my Monitors has not worked and sine July 7 it has been sitting untouched, not here, but at a rprair facily over 50 miles away. As of yesterday August 7, I was told Westinghouse no longer makes or provides power supplies for this unit. On top of that the repair facility will not return it to me unless i pick it up why? Because it can't be fixed and because service.net will not pay them to return it to me.
So solution at thi point for anyone with power supply issues is to try and repiar it yourself. And then in the future never purchase anything from westinghouse again. (And if offered any sort of 100% all cost covere din home warrabnty from service.net run away screaming)
Posted on Aug 08, 2008
budmrtn
  • 11361 Answers
SOURCE: LVM-37w1 Westinghouse
If you getting a lot of vertical lines, double picture, it can be the LCD panel driver board, or worst case will be the LCD panel, very expensive.
Posted on Nov 17, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Westinghouse LVM 37w1 Screen goes
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Posted on May 18, 2011
Can not get welcome menu to go away. Tv does not seem to find any inputs at all
If u have an orange light, try holding down the power button for 15 seconds to reset. Light should turn blue shortly after that.
Sep 28, 2013 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
LVM-37w1 after 5 minutes of viewing, picture and sound go off. Blue power light turns orange. attempts to turn on TV are unsuccessful. Blue light immediately turns orange.
I saw this fix posted on another blog by a fellow named Patrick. I tried it today and it it worked. It fixed my Westinghouse lvm-37w1. Basically disassemble the back of the TV (removing all the screws on the edges and middle). Remove screws holding bottom speaker and stand. There are 2 chrome rods extending down. There are small screws inside holding them on. You can turn the rods and unscrew the screws but need a small screw driver to put them back on. Remove the black cover on the back. remove the plates on the lower middle section. You will expose a printed circuit card. unplug wires and unscrew 4 screws holding it in. Remove it, turn it upside down and inspect the solder joints near the lower middle (especially under the gray relay on the other side). I found 4 solder joints that were cracked. Resolder the larger solder joints that are cracked or look bad (small solder joints are too delicate). Put it back to gether and it should work now. Mine works great. No more black screen with no sound.12_2_2011_5_11_21_am.jpg
Sep 29, 2011 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Westinghouse LVM 37w1 Screen goes black, blue light stays on, sometimes turning the tv power off and on fixes it, sometimes just have to wait about 10 minutes and it works again. Could it be the...
May 01, 2011 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Our LVM-37w1 Westinghouse TV has no sound! It only has sound through a surround sound system. We now moved the TV into another room with no surround sound and no sound comes from the TV at all!
Go into tv menu.Goto AUDIO SETTING,go down to reset.This will,reset it back to tv factory setting.The sound now,it working trought ur tv speaker again now.
Sep 09, 2010 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Feb 27, 2008 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Aug 14, 2007 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
WON'T POWER UP
I had the LCD repaired. It turns out that the power supply went out. It cost me a few hundred bucks but it was worth the repair rather than buying a new one for 3x as much.
May 27, 2007 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Westinghouse LTV-27W2 27 in. HD-Ready LCD Television Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
