Question about Actiontec MyWirelessTV Wireless HDMI Kit
Tv is getting sporatic signal and blinking picture
It was working fine yesterday. Today it appears to be getting the signal sporatically as it will give me a picture and sound and then go to a greenish colored screen. Voice does the same thing.
Drive window works sporatically
Have you had your technician check the switch for loose contact??
May 10, 2012 | 2001 Toyota Corolla
Blower motor works sporatically
check the motor and the reisitor my bet is the motor is going bad and drawing excess voltage
Mar 04, 2010 | 2005 Suzuki Reno
Certain channels appear sporatic and sound and picture bounce in and out.
that is the sign of a waek signal in the digital world that is the one bad thing sbout it in the old day if you had a weak signal you would see it as snow
with digital you either have a picutr or you don't
so you will need a tech with a signal meter to find your problem
Dec 18, 2009 | Televison & Video
Code reads random cylinder misfire. sporatically
well... the misfire codes are logged in when its running bad, but first I would want to verify fuel pressure when its running bad.
Oct 18, 2009 | 2006 Suzuki Forenza
Mechanic says camshaft sensor needs replace; however the car runs fine. Check engine light comes on sporatically.
Agreed with thundergod - I had a failed cam sensor on my Audi A4 that made no discernable difference in the car's operation, but changing it and resetting the light fixed the problem.
May 05, 2009 | 1992 Buick LeSabre
Sporatic breaking malfunction
Either a leak in your brake line or a problem with your servo, get it checked out at a repair shop Asap
Apr 26, 2009 | Cadillac Eldorado Cars & Trucks
No color and sporatic play on VCR mode, with zv420mw8
If this problem happened within a few seconds, you probably have dirty heads. If It happened slowly you could have an alignment problem. Both of these problems should be repair professionally.
Fuji
Jan 29, 2009 | Philips Magnavox DVD/VCR Dual Player
Brake lights/turn signals work sporatically.
heyii lady i am not so sure in this case but if it is not a short then may be your induction coil is producing more crrent than required.. so get your coil checked.. or this time..if u have not been then put genuine compant lamps.. i hope this will help you out.. belated Merry X-mas and Happy New Year :)
Dec 29, 2008 | 2000 Pontiac Sunfire
Picture on TV blinks on and off when you first turn on. Now it blinks on and off sporatically. The color changed before this started. Reds and greens are off. It's a Sony about 10 yrs old. Is it on...
can u give me a model number for u set and u may just have a bad connections on the if pack witch is comon for sony minor problem easy fix. please let me know marty
Oct 13, 2008 | Televison & Video
Vertical hold problem
Maybe sync separator transistor is faulty
Dec 22, 2007 | Zenith C32A26 32" TV
Actiontec MyWirelessTV Wireless HDMI Kit Logo
Top Actiontec Televison & Video Experts
Are you an Actiontec Televison and Video Expert? Answer questions, earn points and help others
