Question about Sony KDL-52EX700 52" HDTV-Ready LED TV
Kdl 52ex700 power on, GREEN LED IS ON, but not picture, not sound
Power on, GREEN LED IS ON, but not picture, not sound
Benimur
  • 6966 Answers
SOURCE: Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
Hi, If all else fails, try do a hard reset. You can verify from your manual, but in some units, this is merely unplugging the unit from mains for a couple of hours. Try again, if it still shows error codes (blinking lights) you probably have to seek the services of a qualified professional. Hope this be of some help/idea. Good luck and kind regards.
Posted on Aug 26, 2007
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
tvservice306
  • 458 Answers
SOURCE: i have a sony bravia KDl-32XBR4 and when I power
Manufacturer Sony Part Number 1-474-052-11 Description POWER UNIT (G1H)
http://bestbuy.partsearch.com/PartSearch.aspx?PartNumber=1-474-052-11&x=20&y=12
Posted on Mar 16, 2010
  • 8909 Answers
SOURCE: Sony KDL-40S4100 Bravia LCD will turn on for like
B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Posted on Mar 28, 2011
SOURCE: KDL-40s4100 power light on, black screen
Main PCB is bad . I just got the information from a Sony authorize servicer price for the part only $504.87
Posted on Dec 05, 2011
I have a Sony 52 inch LED TV Kdl-52ex700 and the picture went out it powers up fine but the picture displays a lighted black screen.still get sound.any help would be appreciated thank you
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Jul 08, 2015 | Sony Televison & Video
Kdl-52ex700 powers on but black screen
It's a faulty television. More than likely something in the mobo has gone wrong. I'd recommend returning the TV for a new one if you have that option, and if not, send it off to your manufacturer so that warranty work can be done on it.
Feb 22, 2015 | Sony KDL-52EX700 52" HDTV-Ready LED TV
Sony kdl52nx800 will not turn on indicator light blinks 5 times
While looking found this:
Found this service bulletin for sony KLD
KLV40EX600 not austalia model but think KDL will be similar
Model No: KDL-32EX400 KDL-40EX400 KDL-32EX500
KDL-40EX500 KDL-46EX500 KDL-55EX500
KDL-32EX600 KDL-40EX600 KDL-32EX700
KDL-40EX700 KDL-46EX700 KDL-52EX700
KDL-60EX700 KDL-40HX700 KDL-46HX700
KDL-55HX700 KDL-40NX700 KDL-46NX700
KDL-52NX800 KDL-60NX800
SUBJECT: Counter measure for Intermittently 5 times standby LED blinking
SYMPTOM: Customer may report that intermittently after AC OFF/ ON (or Deep Standby/ ON), TV will shut down with LED blinking 5 times. If set is placed in Standby, then On, symptom will re occur. If AC is removed, set will work normally when AC restored
CAUSE: Timing mismatch of I2C communication causes interrupt signal inside TV. This causes TV to shut down with error 'Standby led flashes 5 times'
SOLUTION: This is a user correctable issue -
Where possible, please refer customer to Sony Website -(or ) and search for relevant model to download correct update. If the unit is in Workshop, please perform update as per Instructions.
Dec 14, 2012 | Sony KDL52NX800 52 in. TV
My sony bravia 52ex700 tv turns on but there is no picture help...
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 03, 2012 | Sony KDL-52EX700 52" HDTV-Ready LED TV
No picture or sound on screen
are you on the proper input? what are you trying to watch, and how is it connected?
Apr 17, 2011 | Sony KDL-52EX700 52" HDTV-Ready LED TV
Sony KDL-52EX700 52" HDTV-Ready LED TV Logo
35 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
