Sk-8845 touchpad doesn't work - Computers & Internet
I NEED INSTRUCTIONS TO OPERATE NORMA OUTDOOR TIMER NO 052-8845-8
Try Googling (noma)(052-8845-8)(manual) without parens.
Note spelling of Noma
Dec 18, 2017 | Hardware & Accessories
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
Touchpad problem
I am going to assume the touchpad doesn't work, since you didn't elaborate much in your description. If it isn't doing anything, you need to reinstall the drivers for the touchpad. If you have an external mouse laying around, use it to go to the acer site and redownload the touchpad software and follow the instructions to install it. The next time you boot your computer, it will work.
Jul 03, 2012 | Acer Aspire Computers & Internet
My touchpad not working
is their a button above the touchpad? if there is press it, you may have disabled it. if that doesn't work plug in a mouse and go to control panel once booted and verify that the touchpad isn't disabled in device manager.
Jun 11, 2012 | Acer Computers & Internet
Accer emachine e725 touchpad mouse not working............
Plug in a USB mouse and then try to download the Acer driver for your touchpad here: http://support.emachines.com/em/driver/index.html
If you install the newest driver off of the Emachines website, and the touchpad still doesn't work, then it is possible that the touchpad has gone bad.
Nov 15, 2011 | Computers & Internet
My touchpad doesn't work on my aspire one D255 netbook. The wireless mouse works but the touchpad doesn't respond to any touch. How can I make the touch pad work? Is there a function?
Hi!
If the touchpad worked well before and suddenly doesn't work any more, it is most likely it was stopped by pressing the key combination FN F7. To be sure please press the same combination again and check if it works.
If it still not work, please check if the touchpad drivers are installed on you netbook.
To do so, please open device manager. (opening the device manager could be done in more different ways, e.g. click START button and, depending on your operating system enter devmgmt.msc in the Run box for windows XP or in the Search programs and files box in windows 7).
Now, under mice and other pointing devices you should find your touchpad.
If the touchpad is not listed in device manager, drivers for it have to be installed.
Drivers for your netbook's hardware are on the acer support page.
Hope it helped,
Bogdan
Aug 28, 2011 | Computers & Internet
My touchpad will not work at all on my dell latitude laptop
Unless the Dell is fairly new, the touchpad cannot be turned off. If you have a special function key that shows a pic of a touchpad with a line through it, you use that key in conjunction with the Fn key. This combo turns the touchpad on and off.
If it doesn't work, then you may have a faulty touchpad. This means that either the touchpad data ribbon has come unattached or the actual circuits that control it are bad.
Jun 08, 2011 | Dell F3534 Touchpad
My PC Concepts Ergonomic Keyboard with Touchpad, SK-6000 model is wearing out on me. I want another one just like it and have searched the internet, etc. but to no avail. Any ideas where I can find one??
I have found them available (used) for sale by googling "PC Concepts SK-6000 keyboard" (without the quotes). Also try Ebay and Craigslist. The mfr went out of business years ago.
May 13, 2009 | PC Concepts Classic USB+2 (63142) Keyboard
Sk-6000 keyboard
For the touchpad: if your keyboard equipped with standard COM connector try: http://www.acersupport.com/library/ti_note/2x0tpad.exe (older synaptics driver - working with COM port based touchpad perfectly) - or if you have converted it to PS2 connector (i converted my one from COM to PS2) you can use the latest generic touchpad driver from http://www.synaptics.com/support/drive.cfm . (sadly synaptics dropped support for comport based devices in the latest drivers...)
Dec 23, 2007 | Maxi Switch Silitek SK 6000 Keyboard
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
