Question about Neato Robotics Neato Brush Motor Belt
Noise to loud on floor
Squeeling noise dyson 33
Is it when you go from carpet to floor or floor to carpet? It will make a loud noise detecting a possible suction issue. I've also had loud noises and turned over the vacuum and where the brush is, traps hair, thread, rubber bands, etc. Just take a scissor and cut it all out. Don't cut the bristles. Roll the brush as you cut and pull all the stuff wrapped around the brush. Once it is free, try it again.
Jul 27, 2014 | Dyson DC-33 MultiFloor Upright Vacuum...
Loud rattling noise and no suction
You have something that's been sucked up into the floor cleaning part of the machine... then clogged it off. Be persistent and you should be able to find it and get it out..
Nov 04, 2013 | Hoover Vacuums
Making loud noise dyson
Give this site a try: repairclinic.com/RepairHelp/How-To-Fix-A-Vacuum-Cleaner/115-204-709304-/Dirt-Devil-Vacuum-cleaner-brush-not-spinning-M085845
Hope this helps if that's the cause of the loud noise.
Johnstown Epoxy Garage Floor
Sep 29, 2013 | Dirt Devil Featherlite Bagless Vacuum...
My dyson DC17 makes a loud noise when i tip the handle down to make the brush spin on the floor?
Loud noises are usually caused by worn belts, unbalanced roller brush or debris in the roller brush. Check these things. Here is a link to the belt you need:
Dyson DC17 Replacement Belt
Nov 28, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a loud noise coming from the vacuum. also doesn't pick up
Check underneath, behind the roller where the opening to the hose is. I had the same problem that was caused by a Lego lodged in the opening and when it was removed, the vacuum worked like a charm.
Jun 16, 2009 | Kenmore Progressive Bagless Upright with...
Loud noise, smell smoke, brushes turn slower than before, stoped using
yes there are replacement parts for your hoover call any athourized hoover dealer and give them your model # usualy the motors are more expensive than the hole machine
May 22, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Loud noise
This is the clutch as it jams up in the brush. Usually happens with rugs that are not secured to the floor.
Dec 11, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Neato Robotics Neato Brush Motor Belt Logo
26 people viewed this question
Top Neato Robotics Vacuums Experts
Are you a Neato Robotics Vacuum Expert? Answer questions, earn points and help others
