Question about OKI C6100n Laser Printer
Service call 257 fatal error - OKI C6100n Laser Printer
My OKI printer is giving me a message which reads, "Service Call 106: Fatal Error".
YYYY
106: FATAL ERROR
An error has
occurred which
requires service.
YYYY = the general
cause. 106 = error
number.
Try turning off the
printer then turning it
back on. If this does
not remedy the
problem, write down
the message including
the error number
“106,” then call your
authorized Oki Data
Service Dealer for
service.
Note: If you see a
series of octets
containing letters and
numbers scrolling
across the display, be
sure to write these
down also and report
them to the Service
Fuser error. Replace fuser or if no-go, Main board.
Aug 26, 2009 | Office Equipment & Supplies
Fatal error 122 on a oki c5200 printer
YOUR DRIVER CD IS CURREPTED.ANOTHER DRIVER CD USE.
Jun 23, 2009 | OKI C5200n Laser Printer
980-fatal-error
Service call 980:Error
Cause: Error by media clinging to the fuser
Error description: Media has clung to the fuser.
Solution: Power OFF. Replace the fuser unit.
Nov 19, 2008 | OKI C5800Ldn Led Printer
Fatal error 17H
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing rack rotation
<Remedy>
Electrical components for detection of the malfunction
Rack motor (M2)
Rack clutch (CL1)
Rack home position sensor (PC4)
Master board (PWB-A)
Controller control board (PWB-P)
Rather than try to explain in more detail i can forward you the service manual (4.17mb) if you update with an e mail address
Jun 05, 2008 | Konica Minolta magicolor 2300DL Laser...
Fatal Error 21H
FATAL ERROR CODE 21H / SERVICE CALL 21 TRANS DET SENS: Malfunction of the OHP detecting sensor
check the OHP detecting sensor (PC3A) (it's at the front above the waste toner sensor pc6)
May 22, 2008 | Konica Minolta magicolor 2300DL Laser...
OKI C5500 Fatal Error 177
From OKI error log:
Lower heater temp state - Low
backup roller thermistor indicates low temp
seek service if turning off/on printer does not solve problem
Apr 15, 2008 | OKI C5500n Printer
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
Fatal error oo4
fatal system error
service required/004
Feb 16, 2008 | Olympus m:robe MR-100 Digital Media Player
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
Aug 10, 2007 | OKI C5150n Led Printer
OKI C6100n Laser Printer Logo
22 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
