Question about GE Refrigerator PTC Relay - WR07X10086
Refrigerator PTC Relay - WR07X10086 - GE Refrigerator PTC Relay - WR07X10086
The refrigerator worked, but when unpluged and moved the compressor no longer runs. Is there a reset button on them?
no there is reset,but,the ptc overload relay plugged into the compressor is bad,purchase a new replacement ptc overload relay and plug in into the compressor and it will again cool properly
Apr 12, 2011 | Kenmore Side by Side Refrigerator
Not cooling
this unit has 2 evaporators one for freezer and one for the refrigerator side,if both are not working(cooling) then its your ptc overload relay on the compressor thats defective,unplug the old ptc off the compressor and get an exact replacement and this will take care of your non cooling problem
Feb 24, 2011 | Samsung RS2630SH Side by Side Refrigerator
Refrigerator is not cooling. Compressor comes on than off after 20-30 seconds
you need to replace the ptc overload relay replaced on the compressor as this component is getting weak and is cutting out,it uses temperature vs. heat to protect the compressor from a no start or when the compressor cant operate on the run windings and overheats,then this ptc overload relay cuts out the compressor to protect it,it will keep trying to start the compressor till the ptc burns out,it just unplugs off the compressor and a new replacement plugs back in
Dec 23, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
HOW DO YOU REPLACE A START RELAY SWITCH ON A FRIGIDAIRE SIDE BY SIDE MODLE FRU26SA
Power off i.e unplugged
Open the back
Remove retaining clip on wiring side of compressor plastic cover.
NOTE wiring connections to terminals on the OLD relay. 1, 2 4 4 ect... make a simple wite color to terminal number sketch.
PULL off PTC relay WITH terminals by pulling HORIZONTALLY (Usually to the left / 9 O'clock position)
NOTE the thermal overload comes off WITH the PTC relay.
Remove wire from Thermal overload terminal and transfer the thermal overload to the new PTC relay.
Slide NEW PTC relay onto compressor terminals
Transfer remaining wires from OLD PTC to the correct terminal on the new PTC relay.
TEST compressor start before installing cover... PLUG in unit
After the test unplug the unit... reinstall the plastic cover and wire clip.
Reinstall back panel
Return unit to service.
Thanks for choosing FixYa
Kelly
NOTE the thermal overload will s akl
Sep 19, 2010 | Frigidaire Side by Side 26.0 Cubic Foot...
My refrigerator is making a clicking sound and won't run
overload rleay is actually mounted to the side of the compressor, , replace if ness. symptoms will be loosing cool, if you remove it you may hear ut shake like a rattle.it starts thecompressor
Mar 17, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore side by side refrigerator is not cooling or freezing
Sure sounds like a PTC relay bad. Take the relay off and shake it to see if you can hear a rattling sound.
The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Feb 02, 2009 | Kenmore 53642 / 53644 Side by Side...
My Frig is not cooling
your ptc relay on the compressor when they go out they make a clicking noise. The compressor will quit and little bit later might try to come back on and click again. You need a new ptc relay. It is on the compressor little black box just unplug your refrigerator and pull the relay off. undo the wires and get a new one. Kinda staight forward compressor has 3 prongs that the relay plugs into.
Jan 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore refrigerator PTC relay for compressor
This is for a Kenmore PTC relay that I just pulled from my fridge. It dosn't have an ice maker. Hope this helps.
Pin 1 = White
Pin 4 = Blue
Gold Pin = Red
Oct 19, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
GE Refrigerator PTC Relay - WR07X10086 Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
