Question about Clarion DXZ555MP CD Player
Clarion cz100 headunit stuck on telephone
My clarion cz100 headunit is stuck on "telephone" screen. what do I do to fix it? It wont change radio source and im not sure how to fix it.
5 Suggested Answers
SOURCE:
Gerrito
  • 3 Answers
SOURCE: my headunit
I leaved mine like two hours in the telephone screen and then it whent its self out and works good now.
Posted on Feb 28, 2008
blueextc3221
  • 15935 Answers
SOURCE: color diagram for a clarion radio
If this is a factory radio - the year would be required.
However just before 2000 model year... and for a couple years after - the following wiring colors are prettymuch constant....
Constant 12V+ Red/White Switched 12V+ Red/Yellow Ground Black Illumination Green/Red Dimmer Red/Yellow Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Blue Left Front (-) Yellow Right Front (+) Green Right Front (-) Gray Rear Speakers 4" Roof Mount Left Rear (+) Orange Left Rear (-) White Right Rear (+) Orange/Blue Right Rear (-) Orange/White
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 08, 2010
  • 239 Answers
SOURCE: Clarion CZ100 install ?
yellow battery
red accessory
black earth
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
Posted on Aug 19, 2010
kenw392
  • 2226 Answers
SOURCE: where do i hook the brown wire to clarion cz100
The brown wire is probably phone mute. You don't really need to attach it to anything for the radio to work.
Posted on Dec 06, 2011
What is the pinout orderfor clarion cz100
No idea.
Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
Oct 21, 2015 | Clarion Car Audio & Video
Clarion Marine Problem w Sirius CeNet Unit
When a CD changer or Sirius satellite receiver is added to a system, the source unit’s main wiring harness must be disconnected before the changer and/or satellite receiver’s CeNET cable is connected to the source unit. Otherwise, the source unit will not “recognize” that a CD changer or Sirius satellite receiver has been added.
Apr 09, 2008 | Clarion (NAVSIR) SIRIUS Radio Receiver
Where do i hook the brown wire to clarion cz100
Dec 04, 2011 | Clarion CZ100 Car CD MP3 Player
I need a wiring diagram to hook up a new radio.
First you will need to get a wire harness for your specific make, model & year of car. This will interface the car wiring plug to your new clarion headunit.
Next you will connect the wires from your purchased wire harness to the wires of your Clarion Headunit. Using **** connectors with a wire crimper is the best way to do so.
Here is a wire color coding guide for the wires on your Clarion headunit:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
Mar 17, 2011 | Clarion Car Audio & Video
I Have A Clarion CZ100 On My Integra, I Put It Back On Yesterday Because My Car Came Out of The Shop. It Was Doing Fine Until Today, Turn On My Car and It Played, But When I Wanted To Change The Radio...
it's more likey the faceplate, and where it makes contacts with the unit. if you try applying pressure and moving the detachable faceplate on while attached and it turns on, there could be a cold solder/loose connection on the board.
Feb 06, 2011 | Clarion CZ100 Car CD MP3 Player
I have a clarion cz100 hooked up to a 1000 watt autotek amp and it is connected to a red top optimum battery. When i turn it up to BUMP it if im not moving the stereo will shut off. I had it hooked up to a...
some stereos will shut off if the voltage drops below 12 volts. measure your voltage at the battery with the car at idle and stereo turned up and all accesories and lights on. you should have 14.4 volts with the car running. the batteries voltage is 12.6 volts so you have to have more than this to be able to maintain steady voltage to your components. if the voltage drops too low when the bass hits it can shut off your radio. a capacitor can help this and the safe number is 1 farad for every 1000 watts. if you plan on adding any other amps autotek and phonix gold both make a digital capacitor that is compact and go anywhere from .5 farad to 10. the bigger the cap the better. if your voltage readings are ok then check that your speaker output wires are not touching.
Dec 23, 2010 | Clarion CZ100 Car CD MP3 Player
Installed cz100 radio sounds great, cd loads & reads but no sound???
are you using an amplifier? if so, it sounds like you are using the blue (antenna remote turn on) wire instead of the blue/white (amp remote turn on) to turn the amp on.
Nov 16, 2010 | Clarion CZ100 Car CD MP3 Player
yellow battery
red accessory
black earth
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
Aug 10, 2010 | Clarion CZ100 Car CD MP3 Player
My headunit
Apr 01, 2007 | Clarion DXZ555MP CD Player
Clarion DXZ555MP CD Player Logo
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
