Question about Linksys Wireless-G WRT54G Router
Linksys Wireless-B Router, Model BEFW11S4
I got this router 3 years ago and set it up with an old laptop.  I now have a new laptop and I must have set it up with security and do not know what I set it up as.  I am trying to connect my new laptop and it's asking me for the wep key.  What can I do to unclock/reset this if I do not know my wep key?
  • Anonymous Apr 25, 2008
    passcode
    how to configure routers
    Scholar:
  • 59 Answers
It's really easy to find your wep key if you can log into the router page.  Usually the router is defaulted to 192.168.0.1 or 192.168.1.1
You put that number after the http:// in a web browser and it should ask you for a username and password.  Either enter the username and password you set it up for, or if you didn't set one it's probably admin admin.  Now there should be a page with a bunch of settings.  Near the top click on the tab that say wireless, and under that tab there should be something called security.  The WEP key you have set up should be in here.  The WEP key is not the passcode, just wanted to point that out.  It's most likely under something by the name of key 1 or something to that affect.  That should take care of your WEP key problem.  I would personally recommend upgrading to a wireless G router if the other devices on your network can use G.  Wireless G is much faster and also allows the use of wireless B devices on it.  Hope I helped.  If you need more help just ask, I might be able to get some screenshots up or direct you to a manual.
Posted on Oct 17, 2007
2 Suggested Answers
2Gigs
  • 141 Answers
SOURCE: Linksys BEFW11S4-RM 4 port wireless router
This is an old router. Look at the power light. You must have a STEADY power light. RESET the BEFW11s4 by pushing the reset button for 30seconds. Unplug the power of the BEFW11s4 for 30 seconds. Connect pc to port 2 or 3. pc should get an ip of 192.168.1.x. If you are getting this ip that means that the pc is already detecting the router.
Good Day
Posted on Mar 14, 2008
How do i make a password on my wifi conection..my router is linksys BEFW11S4 v.2
First, your router is old, go pickup a new one that supports the G standard, don't worry it will fall back to B standard or better yet get an N standard router. To setup wireless security directly connect a pc via cat5 data cable to one of the switch ports on the router (not the wan) and login to the web innerface, click the wireless tab, now look for the security or encrypted options. Most routers support WPA-2 encryption where you enter a phrase of 2 or 3 words if your router only supports web encryption go buy a new router. Save it, then go to your pc, disconnect, remove the wifi ssid from your managed wireless list refresh and search for the ssid of your wireless signal (name), now connect and the router should challenge you for your WPA pass phrase you setup in the router. Now your wifi ssid is secure and all connections will require the passphrase.
Aug 28, 2010 | Linksys BEFW11S4 802.11b Wireless...
I have a new hp lap top with windows 7 it is recognizing my linksys router but saying no internet connection available, i have two other laptops that have no problem connecting
You have befw11s4 router, which is very old router.
May be you will need to upgrade the firmware of the router.
change the channel to 6.
check the wireless security settings.
Make sure that the wireless MAC filter is disabled.
For this you will need to access the router set up page.
make sure that the computer is connected to the router with the cable when you open the router set up.
Click here for mode info about routers and wireless network
Jan 08, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
Having followed all the instructions as per the 'set-up' disc I'm informed that there is no connection with the internet. the cables are ok , having been checked against other equipment. your unit does not...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 29, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
My password is "wrong' whenever I try to connect on my laptop
That's firmware problem on your router. Try to download the latest firmware for you router from www.linksys.com/download then load the latest firmware. After successfully updated the firmware, you need to hard reset the router by pressing the reset button for 20 seconds then unplug the power for 10 seconds and plug it back in. You will need to reconfigure the wireless settings.
Apr 15, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
HP laptop not recognizing Linksys Wireless B Security Key..
The WEP encryption is consist of 10 characters for 64 bit hex, 128 bit hex is 24 characters and WPA is 8 to 63 characters. So it seems that you have a vista computer? The compatible encryption for vista is WPA, sometime using WEP it is not working properly. So I might advise you to access the configuration of your router (192.168.1.1) and change the wireless settings of your router to WPA-Personal.
Mar 09, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Swapping Linksys BEFW11S4 for WRT54GS
Gateway set to your servers IP address?
Wouldent they(laptops) get internet conection trough the Server? - not sure, just trying to throw a tought in the air.
Coment, and I´ll be back :-)
/Teis
Nov 23, 2008 | Linksys Wireless-G WRT54GS Router...
Good Day
Mar 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Drivers 4 Linksys BEFW11S4 ver. 4
Your wired network adapter will talk to a wired router without a driver for the router on your computer. Your wireless adapter likewise will talk to your wireless router without a driver for the wireless router on your computer. Your wired and wireless adapters however do require drivers and the wireless adapter can require configuration. Please provide the manufacturer and model of your computer so I can learn about your wireless adapter and we can work to get it connected to the router.
Do you currently have your router connected to your internet service providers connection and do you have another wired or wireless computer successfully using this device to access the internet?
Dec 09, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Cant go online wireless (working before)
Hi jamesone..
This router will not support vista laptops..and the warranty period for this router is only a single year..better you can go for advanced g or gs routers .. model no's like..wrt54g or wrt54gs..with a warranty perion of 3 years..
HI baby..
this is for u..
It seems that you are not connected to the wireless connection ..i think the operating system in your laptop would be xp..to fix this problem
right click > wireless n/w connection > click view wirelss network connection > click change the order of the preffered network connections > select your wireless network name > from preffered wireless network and remove it..and then right click wireless network connection icon again and try connect to the network.. you will get connect.. and will get an ipaddress..
Nov 29, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
I lost my lynksis befw11s4 router star up disc what can i do
There are 5 versions of this model. The drivers for your LinkSys BEFW11S4 Router are available here. You have to select which version you have and can be found at the sticker underneath the router.
Good luck and kind regards.
Oct 25, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Linksys Wireless-G WRT54G Router Logo
408 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
