Disable touch screen for dell inspiron 2350 - Computers & Internet
Pyrhyc
  • 2028 Answers
SOURCE: disable touch pad on my Dell Inspiron 6400 notebook
Open the device manager, then open the touch pad, then you will see the enable/disable option towards the bottom.
Posted on Aug 21, 2008
  • 8 Answers
SOURCE: DIsable touch pad on Inspiron 1501 laptop with XP
In your system you should be using synaptics touchpad driver. First of all look for it under mouse properties in control panel. If its not there then install in from support.dell.com. Under this application you would be having option to disable touchpad when external mouse connected. Try this.
Please rate the comment
Posted on Jan 20, 2009
benwabnick
  • 2404 Answers
SOURCE: tDisable trackball dell inspiron 4100
This is a common problem that affected a host of dell models which had a 'trackball' or whatever the little 'nib' in the middle of the keyboard is called? You can try to remove the 'Synaptics pointing Device' in add/remove programs. This may help. There is one and only one way to fix this issue, you have to lift the keyboard and disconnect the 'trackball' thingy from the mainboard....do not disconnect the touchpad, the touchpad itself is not the problem but suffers from the drift caused by the malfunctioning ball in the middle of the keyboard. the fix above u will lose use of the 'ball' but not the touchpad, and you wont be tempted to smash the laptop off the wall . Click on this link or copy and paste the complete link into your browser. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Posted on Jun 10, 2009
immortal4u
  • 223 Answers
SOURCE: I can not disable touchpad
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
Posted on Dec 30, 2010
  • 104 Answers
SOURCE: how to disable the dell
If you want to permanently disable it, you can go to device manager and disable the driver. You can enable it if you ever want to use it again.
Posted on Feb 25, 2011
How do i connect a wireless keyboard and mouseto a dell 2350 touch screen
this should be plug and play if not you will have to change in device properties
Sep 06, 2014 | Dell Dimension 2350 PC Desktop
How to fix dell Inspiron 2350 touch screen problems
Reinstall drivers,or reinstall OS.If not working you have a hardware problem-touchscreen replace.
Jun 08, 2014 | Dell Inspiron One 19 All-in-One Desktop PC...
Touch screen doesn't work right
getting fixed by a dell support center will be the best option touch sensors are very dangerous to handle y outsiders
Apr 25, 2014 | Dell Inspiron One 2350 All In One 1080P...
Turn off touch screen dell
If you are referring to touch screen feature, you may look into control panel for touch screen settings.
a. Click on Start>select Control Panel.
b. Check if you can find dell touch screen settings applications.
c. If you find one disable the touch feature from there.
If not, you may contact Dell for further support.
http://support.dell.com/
Hope this helps.
Sep 25, 2011 | Dell Inspiron One 19 All-in-One Desktop PC...
How to disable the dell inspiron n3010 touch pad? there is a button on the keyboard to press in order to enable/disable the touch pad; but it does not work.
Feb 25, 2011 | Dell Inspiron 13R (N3010), 14R (N4010),...
It jumps around the screen when I'm typing
you may be touching the touch pad while resting your thumbs. this laptop does not have a key to disable the touch pad.
Nov 18, 2009 | Dell Inspiron 1521 Laptop
How do I disable the touchpad?
Try disabling the touch pad in the device manager. If that don't work unplug it from the motherboard. You will have to take the bezel and the keyboard off to unplug the touch pad.
Jul 11, 2009 | Dell Inspiron 1521 Laptop
Mouse drifts all over screen
Hello there, this a well known problem with inspiron 4000's like a majority of other Dell Inspiron user's... After some time I've managed to fix it simply by downloading a touchpad driver (Tp2aa10i.exe) for Inspiron 4000 from a Dell website. The problem is the defect of the mousestick! And Dell is aware of it! Upon installation, simply disable the mousestick and the headache's gone! This way you can still use you your touchpad and mouse.....
Dec 16, 2008 | Dell Inspiron 4000 Notebook
Computers & Internet Logo
251 people viewed this question
David Payne
David Payne
