Question about Broilmaster Premium P3 Grill
Broilmaster p3 ng wont get hot - Broilmaster Premium P3 Grill
Won't heat up above 200 degrees.
Try turning off the valve to the tank, then leave the knobs on the grill open for 2-3 minutes. Turn off the grill knobs, slowly, slowly open the valve on the tank. Relight the grill and see if it gets hot.
Mar 26, 2014 | Broilmaster Premium P3 Grill
No gas running to broilmaster grill piped to gas line
It sounds like the valve is shut off. Try opening it and if you have any questions call 1-888-634-4289 They helped me when I had grill issues
Apr 16, 2013 | Broilmaster Premium P3 Grill
No gas on one side
More than likely, the burner needs to be removed and cleaned. As it sounds like the Venturi Valve, which is part of the burner is clogged. Spiders like to build nest in them.
To assist you further, I have included a link to the Owners Manual for your model. To understand how to properly remove the burners, pay particular attention to the Maintenance section on page # 29.
http://www.broilmaster.com/assets//BROILMASTER/manuals/P3X%20Manual.pdf
Hope this helped you and Happy Grilling!!
Jul 04, 2011 | Broilmaster Premium P3 Grill
The Flame is yellow is there an adjustment
Yes there is an adjustment on the air shutter control valve. Which is part of the burner system. It will look like the blades on a fan. It should be set at 3/4's of the way open. But, before you jump on that, yellow flames are also an indication that you're running out of gas or the venturi valves on the burner are clogged. Spiders love to build nest in them.. So check you tank.and the Venturi Valves first.
To assist you further, I have provided a link to the Owner's Manual for the new P3 Series grill. It is almost identical to yours, unless you have the new model. In which case it will be identical.
Hope this helped you to troubleshoot and solve the problem. Please let me know and Happy Grilling.
Jun 17, 2011 | Broilmaster Premium P3 Grill
Is there an online video or written instructions about how to replace a burner on a Broilmaster D4 grill
Unfortunately, the D4 series grill hasn't been around since Martin Industries went bankrupt 8 years ago and Empire Comfort Systems to over Broilmaster. However, today's 'P' or Premium Series is the closest to the old D4 series, as far as burners and burner installation and removal is concerned.
I have included a link to the Owners Manual, which shows how to assemble the grill and install the burner(s). Just do the burner installation in reverse. You can download and print the manual for future reference.
http://www.broilmaster.com/BROILMASTER/pdf/2010/B101362-2-0610-P3-2-P4-1.pdf
Hope this helped you. Please let me know. Happy Grilling!!
May 13, 2011 | Broilmaster Deluxe D4 Grill
Broilmaster P3 series (purchased circa 2001). Just replaced burner, ignitor and converted from Propane to Natural. Fired the thing up and it appears to flame (difficult to see), but it just won't warm...
If you didn't change the burner orifices to Natural Gas orifices, that's the problem. Even after those are changed (assuming you didn't) the grill will take a bit longer to preheat. As Propane burns cleaner and hotter than Natural Gas, in an outdoor environment.
Hope this helped answer and solve the problem for you.
May 02, 2011 | Broilmaster P4F (NG) Grill
Flames come out from under the body of the bbq? How do I fix it?
Your problem could be or probably is with the regulator...too much gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Apr 20, 2011 | Broilmaster Premium P3 Grill
Knobs melt if both burners are set to high for more than 20 minutes in the summer.
Well, short of turning the burners down, so they are not on high, you might try wrapping the knobs in aluminum foil to prevent them from melting from the heat. But be careful, they may be hot to the touch, so where oven mitts or use a hand towel to turn it off. If they are melting, you may have some burner issues that need cleaning or replacing. If the grill is several years old, and it only recently has started doing this, then it's time to repair or replace the grill, if not for safety's sake. Hope that helps. Douglas
Jun 08, 2010 | Broilmaster Premium P3 Grill
Just bought a new propane tank and attached it. When I turn the knob to ignite the grill, no gas is coming through the line. How can I fix this?
Turn tank off and disconnect coupling. Re-attach coupling and turn gas tank on very slowly. Check for leaks with soapy water. If no leaks, you should be all set start grilling.
May 23, 2010 | Broilmaster Premium P3 Grill
Broilmaster Premium P3 Grill Logo
43 people viewed this question
Top Broilmaster Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Broilmaster Grilling Expert? Answer questions, earn points and help others
