Question about Panasonic 50 TCP50GT30 50 3D Plasma TV
Blinking light turn power
I have a Panasonic Viera TC-P50GT30 and the other day the power went out and when the power came back on the TV had 7 blinking lights on the front, but no picture on the tv. I did some research and took off the back panel to see if the problem was the SC board. I unplugged the power harness and the wire ribbon to the SC board gave the tv power and now I get 8 blinking lights. Ive read that if I get 6 blinking lights then its the SC, SU, or SD boards, but 8 blinking lights im not too sure. any help is appreciated.
SOURCE: TV Won't Turn On
I purchased the TV using AMX card 18 month ago. They have an extended 1 year warranty on top of manufactory's. I just have this set repaired: replaced SD board, total charge is $550. I already file a claim and hope to get reimbursed soon.
Posted on Mar 06, 2008
  • 4889 Answers
SOURCE: Panasonic th-50pz85u: TV will not
10 blinks error code is definitely due to a malfunctioning A-board. Since you have already replaced it, the only possibilities are
1)Either you have obtained a malfunctioning replacement OR
2)You did not get the correct revision version. Not that the same model number of the tv can use different sets of parts. That is why it is always recommended to order by part number. I have had a customer recently who had a similar problem and it turned out to be incorrect version of the replacement board. So check the part number of the replacement and the original . Also compare the revision versions of both and see if everything matches. Please let me know what you found.
Posted on Mar 04, 2011
  • 1156 Answers
SOURCE: I have a Panasonic Viera
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps in solving the problem...
Posted on May 06, 2011
  • 8457 Answers
SOURCE: panasonic viera TC-P50G15 tv cut
Tries tv unplug,replug it back like about an hour later,for the tv to a resetting itself back to the factory setting.The tv might work again,if not the tv power supply board is the problems and the causes.The tv power supply board it is shorted and dead some how.That the board where the tv power a/c cord plug into it.Tries websites like, to buy a whole new refurbish tv power supply board for the replacement.
Posted on Sep 22, 2011
  • 1213 Answers
SOURCE: Hi i have problem with my Panasonic TH-42PV8EY- 7
I have not repaired this model. My first thought are bad capacitors in the power supply board. If you do have the exact board to replace. I would certainly do so. Numbers check and you say they are the exact same, should be an easy fix. If this board came out of another TV of the same model, you must remember, it will have the same longevity as the board that does not work. I would compare the boards, and look for bad capacitors on the board that does not work of course. You may check the capacitors with an ESR meter (about 50 to 75 bucks). The purchase and price of one of these will pay for itself. You can fix other electronics. Thanks for asking Alan. I'll be here if you have more questions.
Posted on Oct 21, 2011
I have a 2011 panasonic viera that had the 7 blinks of *****...I replaced the SC, SU, SD boards and I still have the 7 blinks. What else it could be ?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name and type of your device, in the search box [at the top right] of the display window. It will make surf easy.
Jul 07, 2015 | Panasonic 50" Plasma Tc-p50gt30 Tcp50gt30...
Flashing red light on tv
Depend flashing code ,
7 blinks Sc board bad
10 blink power board bad
Aug 27, 2014 | Panasonic Viera Tc-P42C2 42 in. Plasma TV
Panasonic Viera tc-p65s2 - 7 blinks, won't turn on
I had the same problem with my Viera. if you disconnect the power and ribbon cable from the YSUS board (check youtube for how), the light led will blink 6 times, indicating the YSUS is bad. Check ebay for TNPA5175 board (about $115-160). The pop is one of the DG402RP chips burnout. These are about $4, but only available from China. If you can wait a month for delivery, you can solder the new one to replace the bad one. You may want to purchase several in case more are bad or it happens again.
Aug 06, 2012 | Panasonic VIERA Televison & Video
No picture and power light blinks 7 times on my viera tc-p50st30 plasma tv when it is turned on
That can be caused by either the SC or SD board. Contact the people at they can assist with proper diagnosis and they also should have the replacement board
Jun 01, 2012 | Panasonic VIERA TC-P50ST30 50-Inch 1080p...
Panasonic 50 TCP50GT30 50 3D Plasma TV Logo
44 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
