Question about Vizio VW46LFHDTV10A 46 in. LCD TV
Screen flickers and doesn't remote doesn't work
Why when I turn on my Bauhn TV the screen flickers for approximately 40 seconds, then it is good. It is out of warranty. Can I personally fix the flickering? I am not financial enough buy another.
I have no idea of your technical skills but I would assume you could not disassemble it repair it and reassemble it. I would go to where you purchased it, they may be able to work something out with you.
May 30, 2016 | Televison & Video
TV Doesn't Function: Can turn on, but no menu or input recognition
the set like all has a hard reset which requires a four digit number code and the original Mitsubishi remote---sets almost everything in the set back to original except convergence.
also, don't buy any TV or electronics on CL as people dump their problems on someone else..
Aug 31, 2012 | Mitsubishi WS-65313 65" Rear Projection...
Laptop screen flickers
try to plug the laptop to a external monitor. I the display doesn't flicks your Motherboard or the graphics card fine and you need to replace your screen LCD
Aug 20, 2012 | Lenovo G530, G550, G560...
How do I fix the constant flickering of the screen?
Take the lcd assembly apart, and disconnect and reconnect the ribbon cable on the back of the lcd. Also disconnect and reconnect the other end of that cable. If that doesn't fix it, disconnect and reconnect both cables that go to the inverter board (it's the small circuit board inside the lcd assembly- example in picture below). If still no good, then you probably need a new inverter board. Call HP and get a phone number for one of their parts suppliers. Inverter boards are cheap ($10-$20). Even if it doesn't fix it, it doesn't cost much to try. If still no good, then take it to a service shop.
Hope this helps!
Joe
Mar 22, 2012 | HEWLETT-PACKARD HP Pavilion G61b70us...
Sears craftsman 1/2 hp. Door goes up with remote, but when button pushed to go down the light flashes and door doesn't move. If you push the wall mounted switch, the door goes down like normal. Works...
Check the sensors in the doorway. They should both have a small light that is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Sep 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Hi..i am using compaq presario cq 40 and screen is flickering.i had it checked and they told me lcd is the problem but they didnt even bother to check.they just turned it on and they told me that i have to...
When it flickers, can you still see the text when the screen goes dark?
May have to use a bright flashlight set right on the display to see
the text on the screen beside where the light sits.
That will tell you if it's the backlight.
You can also look at a grazing angle into one of the edges to see if the
backlight is flickering when the display does.
When it's cold, does it start with a slight pinkish color? That can be
a sign of backlight going bad.
Anything interesting happen when you flex the cable by moving the screen?
I'm not saying it's impossible, but I've never seen software cause
consistent screen flicker. And if the vga port doesn't flicker, sw is
even less likely the problem.
If you bet the odds, you'd bet on a bad display cable.
Won't hurt to try replugging it.
If that doesn't help, then your monitor may be dying....
Jun 20, 2011 | Computers & Internet
Lcd screen is flickering on and off very fast
Disconnect the lcd from the computer. Turn on the LCD and see if it still flickers fast. If it doesn't then go ahead reconnect the lcd back to the computer. If its still flickering, then go ahead and hook it up to another laptop or desktop. If it doesn't flicker on another computer then that means there is a problems with the video card on the original computer.
If it still flickers then that means the lcd is bad and would need to be replaced.
May 31, 2011 | LG L1960TR 19" LCD Monitor
Monitor flickers with lines across screen
screen is going bad which is why its flickering and has the lines across the screen. Theres a board behind the lcd and when that doesn't process the voltage properly it can cause the screen to flicker. White lines across the screen means the screen is going bad. At this point unless your monitor is under warranty, go ahead and replace it.
May 28, 2011 | Norcent Technologies LM-965WA Monitor
Have a broksonic 37in flat screen tv. There is
i have bought 2 differnet ATT remotes but they onlu work if I/m an inch from the box..I have a Tosiba flat screen. tech said the infrared remote was getting inteference he sai try an RF remote i did same problem,,help
Dec 17, 2009 | Televison & Video
Vizio VW46LFHDTV10A 46 in. LCD TV Logo
10 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
