Question about Fasco GSW Hot Water Heater Exhaust Draft Inducer Blower # 63172
Gsw johnwood superflue water heater on vacation mode how do I turn it off?
Water heater went into vacation mode, not sure if it was because of a power outage. I have tried pressing green and red arrow to reset but green vacation light is still on
4 Suggested Answers
  • 13 Answers
SOURCE: gsw heater pilot stays lit, but when the main
It sounds like your main valve. The diaphram may be loose fitting or it has a small leak.
Posted on Oct 03, 2009
Testimonial: "Thanks for replying so quickly"
SOURCE: Is there a reset button on the GSW Series 5 Water
GSW Series 5 water heater is electric water heater.
http://www.gsw-wh.com/index.php?context=/products/waterproducts/gsw/electric/standard
The link above goes to the GSW page, but the manual does not match the product shown in photo
GSW has a phone number in the manual:
1-888-479-8324
I cannot see the manual, but I might be able to help.
Every electric water heater has a red reset button located on the thermostat.
Normally on a two-element thermostat, the ECO or reset button is located behind the upper panel.
Your water heater seems to have a box located where upper panel is located.
Without the manual, I do not know what functions are performed by this box.
If there is a thermostat setting on the face of the box, then maybe there is also a red reset button.
That being said, you want to drain your water heater.
The GSW water heater has a drain valve.
If the valve is plastic, rotate the knob counterclockwise.
If the valve is brass, use a screwdriver to rotate stem counterclockwise
The photo shows the screwdriver slot for brass drain valve
If your water heater will not drain, it is probably clogged with sediment at the tank bottom.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Connect a washing machine hose to drain valve.
Connect garden hose to outdoor spigot, and to washing machine hose.
Turn on outdoor spigot for 10 seconds and this will open the clog.
Repeat procedure if clog is still there.
If your water heater is clogged with sediment, you will want to clean out the water heater:
Follow the step by step on link below:
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
If I can assist you more, add a comment and I will respond
Posted on Nov 05, 2010
motor1258
  • 6674 Answers
SOURCE: I have a GSW Series 5 water heater (electric). I
It may be one of 2 elements not working, a thermostat problem, scale build up in tank, to name a few possibilities. You'll need to shut off power to water heater before doing anything to it, and perform a few tests, and check a few things to determine which one is the cause. After power is off, you remove cover(s) on side of tank and peel back the insulation to get access to element(s). Keep in mind that should you need to change one of the elements, or both (assuming it has 2 otherwise you wouldn't have any hot water at all if only 1 element and not working.) This is where it would be good to have a voltage meter ( or multimeter ) and know how to use it. Is that possible? Before you reply, please shut off power and remove cover(s) to be sure whether single or dual element. If it's single, it may just be thermostat adjustment, or faulty, or scale build up around element. Keep in mind that water to tank will need to be shut off and tank drained down below element before removing/replacing. Get back to me with info on single or dual element. Thanks
Posted on Jan 10, 2011
I have a GSW Superflue power vented electronic ignition. It lights and fires up for 15sec then goes out. Keeps doing this. When I open the two front covers the flame stays lit and strong. As close the...
definite air intake problem . check the filter at the bottom of the unit. and keep the area around the unit clear and clean to prevent recurrence
Jan 28, 2015 | Water Heaters
How to get out of vacation mode on hot water heater
If it is an older gas water heater there should be a dial Vacation mode is the lowest setting just turn it up no higher then 120F 140 will hurt you but is better for the dishwasher. 122F is ok if you have the setting
Oct 09, 2014 | Water Heaters
I bought a brand new house and the gas water heater seems to be stuck in vacation mode.
Copy following link to troubleshoot by type of gas control valve, instructions how-to-light-water-heater, including error codes etc:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
To reset the intellivent gas control, press and hold both arrow buttons for about 5 seconds
This water heater requires pilot flame. Look through site glass and upward (or use mirror) to see if pilot is ON and burning clear blue flame and not lazy yellow flame.
Check that gas shut-off is parallel to gas line:
http://waterheatertimer.org/images/Gas-water-heater-89-valve-2.jpg
Check if outlet has 120Volt, and that polarity of outlet is correct. Power vent water heaters require correct polarity: use circuit analyzer. Check if there is ground continuity between ground and manifold tube (center tube that connects between burner and gas control valve).
Scroll to top of same link to read about FV system and air intake cleaning. Must have good supply of incoming air.
Same page half way down has troubleshoot section for pressure switch testing, blower troubleshoot etc. The pressure switch and blower communicate electrically with gas control thermostat to determine when to release gas to burner where pilot ignites gas, causing poisonous combustion by-product to vent outdoors and help nature.
This model has thermopile instead of thermocouple. Basically thermopile is several thermocouples. When heated, thermopile generates enough current to run small electronic circuit inside gas control valve. This circuitry is very common in hvac units but fairly recent to water heaters. Advantage is error code troubleshoot and more optional controls, for example future response to in-home zwave remote controls and home automation
Get model number and brand from label on side of tank and post question on pro water heater forum with list of what you have tried so far.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Call plumber to bleed air out of gas line and check gas pressure.
May 28, 2013 | Water Heaters
Vacation mode hot water heater
GE is made by Rheem.
Sounds like water heater is short cycling.
Copy following link to troubleshoot by type of gas control valve, including error codes, and instructions how to replace each type of gas control valve.
Unforturnately Rheem does not post service manuals, and refers customers to call service technicians... so wonder where these guys get service manual... or maybe they guess at it.
However 2 year old water heater is under warranty. The date of manufacture shows on poduct label serial number. 3rd and 4th digit of serial number are year of manufacture. Parts are covered in second year. Rheem might require plumber to validate single-family residential installation.
In any case other companies post service manuals that cover same gas control valves. These manuals apply to Rheem.
Only difference between Rheem/GE and other brands is type of FV system.
If the air arrestor screen gets clogged (not likely with new heater), the intake air slows down causing vent to slow down. Same amount of gas is still being released and burned, causing combustion chamber to overheat. As a result, the TRD glass vial breaks and air intake trap door springs closed. At this point the gas control valve will usually signal error flashes indicating lockout. Shutdown is usually less problematic to homeowner than allowing too much gas to accumulate inside burner at once, causing risk of explosion. Gas appliance are dangerous without doubt.
Call plumber to check everything might be safest route, especially since low gas pressure is one possible cause of short cycling. And you will be comfortable afterwards knowing who to call and that gas appliance is check out professionally not to have defects that will cause problems down the road.
AO Smith Heater/Vacation Mode
Most recent power shot has intellivent gas control valve:
Copy following link to troubleshoot by type of gas control valve:
Generally you can wake up the control by holding down both temperature adjustment buttons for 1 second then release.
Otherwise, add a comment and give more information, if this is new heater or old heater that stopped working, and what error code if any you are experiencing.
Post question with more detail on pro water heater formula.
More information is needed... and fixya truncates free questions so not sure I am seeing whole problem
May 14, 2013 | Water Heaters
Is there a reset button for a 6G50NVH-FV-02 hot water heater
Depends on gas control valve, and if cause is overheating high-limit event or FVIR flammable vapor event.
Turn off water heater when using flammable vapors, clean burner parts to prevent overheating.
1) GSW Residential power vent gas water heater with FVIR system:
Some models have intelli-vent gas contol
Others have robershaw gas control with auto-reset
2) Parts manual shows #15 'auto-reset' high limit switch on the blower
http://www.gswpartsonline.com/model/27484
http://www.gswpartsonline.com/schematic/137/view
3) Possible manual:
http://www.gsw-wh.com/pdfs/GPD135NInstall.pdf
Shows resettable lockout page 15
Water temperature must be 120 degree F or lower for reset. Unplug power cord, and then plug back in and wait 15 minutes or 60 minutes depending on gas control valve.
Some intelli-vent controls must be replaced when 195 degree high limit event locks out the water heater.
If high-limit lockout repeats, then gas control must be replaced.
Also clean burner parts, air intake, and make sure flame is clear blue. and not yellow-or-orange.
4) Intelli-vent service manual might apply to your water heater:
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
If FVIR flammable vapor event locked out heater, then unplug heater and plug back in.
Immediately press two temperature buttons. Wait for green light to blink. Release buttons.
Page 34 in troubleshoot chart.
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 31, 2011 | Fasco GSW Hot Water Heater Exhaust Draft...
Rheem Power Vent 50 gas water heater will not come out of vacation mode! Have tried turning on and off, resetting and following directions on the side of the tank. Will not come out of Vacation Mode. Had a...
Water inside tank-type water heater can remain hot for some time.
That's one advantage of well-insulated tank-type water heaters.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Power outage can be related to failure of gas control.
Unplug stuff when power goes out. And then plug back in after power is restored.
Water heaters with electronics are not protected from surge.
Electronics can blow out during and after power outage. For example nearby lightning strike will cause current to run along household wires. With ordinary power outage, once power is restored, the surge can affect all kinds of electronic circuitry such as timers, water heaters, water softener, treadmill etc.
Sounds like you have intellivent gas control valve:
Open following link to identify gas control, and download typical manual, and download intellivent service manual with troubleshooting, error codes, etc.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Take a moment and vote on answer:
Aug 26, 2011 | RHEEM 50 Gallon FVR NATGAS Water Heater...
Fasco GSW Hot Water Heater Exhaust Draft Inducer Blower # 63172 Logo
582 people viewed this question
Top Fasco Water Heaters Experts
Charles T Nevin
Charles T Nevin
Gil Shultz
Are you a Fasco Water Heater Expert? Answer questions, earn points and help others
