Question about Bvlgari Diagono Aluminum and Black Rubber Chronograph 101402 Watch for Men
Instructions to wind a bvglari watch
Need to set time
Watch is missing user guide, how do I set the Honora 3ATM watch
To set a basic wristwatch, simply pull the crown (the winder button at the 3:00 position on 99% of watches) out gently - it will click into adjusting position. Wind to send time and then push back in again.
Variations on this are: If you have a watch with date display, the crown will have 2 positions, the first click will be to set the date and the second click (fully out) is to set time. If you need to adjust the date, I suggest you wind the date to the day before you need and then use the second click to wind the hands to the correct date. This way you will be able to know if you have the hour at a.m or p.m position and avoid it have the date changing during the day instead of at night.
One last variation for wristwatches is a screw down crown. Some water resistant and sports models incorporate an added feature whereby the crown is threaded so it can be tightened down to avoid water entering - the most common place water gets into a watch! If you have one of these, you simply need to screw the crown anticlockwise until it pops out and then refer to the instructions above. Don't forget to push and screw the crown back in clockwise when you are done
Apr 30, 2011 | Honora Watch
I don't know how to set the date properly on my Tag Heuer formula 1 watch. Is there a time of the day that I should do it?
If you go to http://www.tagheuer.com/the-collection/tag-heuer-formula-1/men/quartz-chronograph/index.lbl?w=CAH1110.BA0850 , you will see a menu on the right of the screen.
Clcik on "user manual" to download the manual for your watch.
There are no instructions about setting the date apart from saying the date changes at midnight but you can advance the date by winding it past midnight. If you want to advance it more than one day, wind it back and then forward past midnight again. Repeat as many times as required until you reach the date you need.
How far back you need to wind the watch you will have to find by eaperimenting and observing when the date changes. You might hear a soft "click" when winding it backward, you can the wind it forward again.
Feb 01, 2011 | Tag Heuer Formula One
How do i set the time on a armitron 45/6975 watch i lost instructions
Hi an_stocker0,
There is two pulls to set the time and date .First pull is for the day / date wind it in order to choose the right date number and second pull is for the time wind it until the desired time comes out. For better understanding follow this link for more information and instructions below. Feel free to ask whatever the results.
http://www.armitron.com/docs/Automatic%20Manual.pdf
Hope its may helps;
Regards, VOTIT
Dec 10, 2010 | Armitron Two Tone Sports Watch
I have a manual timing watch wont keep time or wind up right what am i doing wrong
Hi
1. You need to first set the time correctly,then wind it and see if it keeps time or not.
2. Most winding wrist watches needs winding every morning in order to keep it working perfectly,maybe you do not wind it everday that is why it does not keep time.
3.If the result is still the same then you might need to replace the winner.
GOODLUCK
Aug 05, 2010 | Watches
Need to adjust or move date forward
Hi
Thanks for using FixYa. To adjust the date and time you’ll need to follow these instructions---
To wind the Movement:
With the crown in position 1, flush against the case, turn the crown
clockwise, completing approximately 15 to 20 revolutions, then
gently but quickly move the watch back and forth several times to
start movement.
To set the Time:
Once the watch is running, pull the crown out to position 2 and turn
it in either direction to set hands to desired time, then push crown
back in to position 1.
For more information you can see this manual---
Tommy Watches Operating Instructions
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 28, 2010 | Tommy Bahama Rlx1004 Relax Beach Cruiser...
Setting instructions for citizen wind surfer
Follow this link, fill the details and get the info you need: http://www.citizenwatch.com/CUK/English/settings.asp
Rate me, plz.
Jan 10, 2010 | Citizen Watches
Brand New Rebel Pocket Watch How to Set
The pushbutton in the center of the winding crown is for watch case opening only. When you push it, the front lid should pop up, revealing the dial.
If you want to set the time, you have to pull out the winding crown (not the pushbutton) and adjust the hands to desired time. After setting the time push the crown back in and the watch is back in winding position.
Rate me, please.
Mar 23, 2009 | Watches
Rolex oyster perpetual datejust time/date setting instructions
Unscrew the crown pull out the crown to the first position, One click and rotate the crown clockwise. This is for Quick Set models
For non quickset
Dec 30, 2008 | Bulova Watch
Not a problem but a question...might be a stupid one too. I just bought a new Bulova self winding BVA100 series watch. The instructions say to wind 6 times before using. I can understand why but the...
Your guess is right- watch is winding clockwise only. If you wind it anti-clockwise, the clutch weel gets disengaged and watch do not wind, so, you can do that as long as you like- nothing will happen and no harm to watch will be done.
6 times mean the movement of your thumb and forefinger with watch crown between them for 6 consecutive times. 2 times is as good as well.
And there will be no any clicks or sounds as the mainspring of watch is designed not to brake, but ease itself if overwound, so, no need for any alarming sounds.
Dec 01, 2008 | Watches
Rolex watch
if your watc is automatic or self winding,you need to use your watch at least 12hours a day,to set the time , wind the crown counter clock wise,until the crown lose then full the crown to set the time,after setting the time fush the crown then wind it clockwise to lock again! thank you !
Aug 26, 2008 | Bulova Watch
Bvlgari Diagono Aluminum and Black Rubber Chronograph 101402 Watch for Men Logo
16 people viewed this question
Top Bvlgari Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Bill Boyd
Are you a Bvlgari Watch Expert? Answer questions, earn points and help others
