Question about Olympus FE-200 Digital Camera
Lens protector stays closed. How can I get it to protract again.
4 Suggested Answers
  • 20 Answers
SOURCE: lens
see this site -- may help - but follow carefully
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 02, 2008
lock123
  • 6831 Answers
SOURCE: when running on batteries, camera lens stays open
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Also, please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 08, 2010
t00nz
  • 4738 Answers
SOURCE: I dropped my camera on the lens while it was open, now it will not close. I noticed it was slightly blurry when i tryed to take a new pic. I turned it off and then back on and the lens didn't move
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Posted on Feb 05, 2012
Lens protector stuck open
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it. There are many non-invasive techniques that people have come up with to accomplish this. Some may be seen on this blog article. You can also open the lens barrel up to fix the covers, but only as a very last resort. This article provides further information on correcting this problem.
Jan 24, 2012 | Canon PowerShot S90 Digital Camera
Kodak EasyShare M863 Digital Camera -Blank screen
Hi Greg, Its not on the settings., Here the thing you need to Do
Turn Off the camera, remove the memory card then Turn On the camera and go to auto mode or smart scene., now if yu see black screen check the Lens is yur lens has cover or check if the Lens protracted. Now if the Lens has no cover and protracted thats good it means theres no problem on the lens., Now press Menu Button, If the options did not display it means LCD or screen is already defective. you can also press review button.,
Please call kodak Toll Free 1 800 235 6325 and have your camera repair., GudlucK!
Nov 05, 2009 | Cameras
I have the canon sx100 is, it dropped and now the shutter eye won't open
If only the shutter eye is not opening but the lens is extending properly, then you will need to remove the fron shutter frame and review it.
It may be that one (or both) springs that open the lens protector are loose, or the plastic tab that allows to open/close the lens protector is broken.
If the lens does not extend when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solutio is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Jul 18, 2009 | Canon PowerShot SX100 IS Digital Camera
Lens Error!
In My case, the lens was coming out part way a start up and pulling back in without camera coming on. Some times the screen would stay a dark blue and could not be shut off. Ensure batteries are new or remove and replace existing. Lens will come out part way and retract when the battery door is opoened and closed. Press "on" button and as the lens comes out touch and hold the lens, with a finger placing pressure on the side of the lens. The lens will stay out. With camera upside down blow into the sliding mechanisms of the lens. Grip the furthest most extened lens with two fingers and pull the lens all the way out with steading pressure. The pressure should be equivalent to lifting one to two pounds of bread with two fingers. Perform this with the camera upside down so that any dirt particles can fall out. A slight rocking (side to side motion) of the lens may help. Once fully extended, open and close the battery door. The lens should retract. Turn on the camera. A couple of ideas relatd to this problem 1) If the concentric circles of the lens are not even, this could indicate a large grain of sand. After lens is extended or partialy extended push the lens on the side where the largest gap is while the camera is upside down. This may provide a larger gap for the grain to fall out. 2) Dirty camera case. I turned my camera case upside down over a piece of white paper and was amazed at the particles of sand that fell out. I turned the case inside out and completely brushed and vacuumed the case.
Jul 13, 2009 | Nikon COOLPIX P60 Digital Camera
Lens does not close anymore -
When you opened it the cog connected to the motor which opens and closes the lens probably shifted and no longer has traction against the ring around the inside of the lens which turns it to open and close it. If you open the camera up again be extremely careful - the lens has loads of springs inside it - lose one of these and it won't work properly. I opened up the whole thing to try and fix my lens which had been jammed in after a friend dropped it. I fixed the lens but couldn't put the damn thing back together again to many tiny parts and no guide to the jigsaw!!
Nov 16, 2008 | Casio EX-Z1050 Digital Camera
Camera malfunction
when the lens are protracting i held them  and they didnt go back in. then i turned it on and it worked! but the lens dont go back in when the camera turns off and the zooming is messed up because of it, but it works!
Nov 14, 2008 | Olympus FE-230 Digital Camera
Having problems with my canon ixus860. When I turn the camera on, the lens can not protract in or out. It's says lens error on screen. Is this a common problem? I don't believe I have dropped this camera...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Oct 12, 2008 | Cameras
"lens error" on casio ex-z3
Sorry to say but a lens error actually is a problem that you cannot fix at home. When a lens error occurs, the motors inside that make the lens retract and protract were some how damaged, usually caused if the lens try coming out when you have it in your pocket or against a surface so it cant fully come out. You will have to send the camera in for service and you can do that by calling 1-800-706-2534, option 1.
Oct 19, 2006 | Casio Exilim EX-Z3 Digital Camera
Olympus FE-200 Digital Camera Logo
13 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
