Heating & Cooling Logo
A
Anonymous Posted on Dec 26, 2013
Fujitsu split system fault codes AST24PBA-W
New remote control will not command unit, timer light flashing all the time. Control is the right one purchased from Fujitsu . Have you any suggestions thanks
5 Related Answers
Anonymous
  • 86 Answers
  • Posted on Mar 17, 2008
SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
bobotfel
Felizardo Erilla
  • 241 Answers
  • Posted on Apr 16, 2008
SOURCE: I have a Fujitsu Split
Try to disconnect the supply from circuit breaker for 10sec. and "on" again, if it doesn't work you need at qualified technician for that problem.
Anonymous
  • 67 Answers
  • Posted on Jan 23, 2009
SOURCE: Remote Control Unit-Fujitsu Air Con. Model:AR-DL1 is broken.
If you contact Fujitsu in your country and you will be able to buy it straight from them, if they are still available. Now I have to warn you as a Fujitsu warrenty agent they are very very expensive.
I would prolly recommend getting a universal remote. ALOT cheaper
Anonymous
  • Posted on Jan 27, 2009
SOURCE: FUJITSU SPLIT AIR REMOTE CONTROL PROBLEM
I had a similar problem with only fan air then the blinking lights, found out that mice had got into the circuit board and corroded some connections with their urine. I would try the above solution by turning the power off for ten sec first but remember that you have to leave it for a few minutes before you operate remote.
bobotfel
Felizardo Erilla
  • 241 Answers
  • Posted on Feb 13, 2009
SOURCE: A/C will not respond to remote control.
The unit has a problem with the safety device, its either defective or have some error. Try to reset the error by disconnecting the power supply for 10sec. then "on" and try. If error still exists may be some of the safety device is defective. You need a qualified technician for this problem.
Check also the air filter if clean and clean if dirty and reset the error.
1helpful
My fujitsu Halcyon indoor unit Operation and timer lights (red and green) flash 4 times and then the timer light (green) flashes three times.
Red 4 Flashes Green 4 Flashes Power Failure
Off 3 Flashes Reverse Comms Fail In Use
I have one of these units and it has had its fair share of troubles, but great when it is working. My latest issue is the the flap on the indoor unit doesn't open!
This generally works for me. Pull out the isolator outside on the wall or disconnect at the breaker. Leave for a couple of hours. Reconnect and wait 15 minutes. If you are connecting via the isolator you will hear relays clicking and solenoids rattling as the unit goes through a Self Test procedure, then try normal operation.
Blink Codes and Troubleshooting.
https://www.orionair.co.uk/PDF/fujitsu-trouble-shooting.pdf
H4 error code is shown on AC display what can i do to slove this problem
Full list of Gree Air Conditioner Mini Split Units Fault Codes. When error codes appear on the Gree air conditioner indoor display, this tells the user there is an issue with the Gree AC unit. The error code displayed will inform you of the issue or problem that is occurring with the air conditioner. Knowing what the error code means and its definition will help you to understand and troubleshoot the exact Gree air conditioner part that needs to be fixed, cleaned, repaired, or replaced. You can then clean, fix, or replace the Gree part yourself and save money. See below for all error codes that can occur on Gree Mini Split AC's.
Gree Mini Split Air Conditioner Error Codes - How To Fix
Gree Viero AC Mini Split PDF Owners and Troubleshooting Manual
GREE DUCTLESS AIR CONDITIONING & HEATING SYSTEM INSTALLATION MANUAL
Gree Mini Split Air Conditioner Part Names and Locations
INDOOR AND OUTDOOR UNIT
The Gree Air Conditioning Vireo System has onboard error code diagnostics. The outdoor unit will provide status indicators and the indoor wall unit and remote control will display error codes. The following is a summary of the codes with explanations...
GREE AC DIAGNOSTIC ERROR CODES
Gree Vireo Mini Split Air Conditioner Error Code F0
Refrigerant Leakage Protection
1) Refrigerant leak(s).
2) Indoor coil temperature sensor not calibrated.
3) Refrigerant flow is restricted (ex. valve, exv, debris)
Outdoor Unit Red Light Indicator - 9 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E1
System High Pressure
1) Over charged with refrigerant.
2) Blocked or dirty outdoor coil.
3) Extreme outdoor ambient conditions
Gree Vireo Mini Split Air Conditioner Error Code E2
Indoor Anti-Freeze Protection
1) Low return airflow.
2) Indoor fan speed is too low.
3) Indoor coil is blocked or dirty.
Outdoor Unit Yellow Light Indicator - 3 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E4
Compressor High Discharge Temperature Protection
Please refer to the malfunction analysis (discharge temperature, overload) in service manual.
Outdoor Unit Yellow Light Indicator - 7 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E5
Overcurrent Protection
1) Supply voltage is unstable.
2) Supply voltage is too low and system load is too high.
Outdoor Unit Yellow Light Indicator - 5 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E6
Communication Malfunction
1) Communication cable is wired incorrectly between indoor and outdoor units.
2) Indoor or Outdoor control board malfunction.
Outdoor Unit Yellow Light Indicator - Continuous On
Gree Vireo Mini Split Air Conditioner Error Code E8
High Temperature Resistant Protection
1) Incorrect refrigerant charge level.
2) Refrigerant metering device malfunction.
3) Compressor malfunction.
Outdoor Unit Yellow Light Indicator - 6 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code EE
EEPROM Memory Malfunction
Control board malfunction.
Outdoor Unit Yellow Light Indicator - 11 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code C5
System Configuration Malfunction
1) No jumper cap inserted on the control board.
2) Incorrect or damaged jumper cap on control board.
3) Indoor and outdoor units are not compatible.
Gree Vireo Mini Split Air Conditioner Error Code Fo
Pump Down or Gathering Refrigerant Status
Optional Service Mode
Outdoor Unit Yellow Light Indicator - 17 flashes and 1 sec Off
NOTE: All of the Gree Air Conditioner Model Numbers below are applicable for the error codes on this page...
Gree AC Vireo Models: VIR09HP115V1A, VIR12HP115V1A, VIR09HP230V1A, VIR12HP230V1A, VIR18HP230V1A, VIR24HP230V1A, VIR30HP230V1A, and VIR36HP230V1A.
Gree Mini Split Air Conditioner Error Code Charts
Gree Mini Split AC Remote Control Button Names
Gree Mini Split AC Remote Control Icons Display Screen
Gree Mini Split Air Conditioner Air Filter Cleaning Procedure
Need help with error codes on your Gree AC? Please leave a question below and we will be happy to help.
Fujitsu Aircon model AST24PBA-W has green Timer light continuously flashing and red Operation light giving 5 flashes. Outside unit fan will not run. What does this code indicate has failed?
Most likely a faulty fan motor. You will need a tech to diagnose correctly as this uses a DC motor which has a circuit board inside so has very specific tests. Other possible faults for this code are compressor rotation error, CT abnormal or current trip all of which will need a tech to diagnose.
2answers
The operation and timer lights on my Fujitsu split system are flashing on and off several times when the unit is switched off I noticed this after the system had stopped blowing air & I knew the room...
I have same problem like yours to my newly installed Fujitsu multi-split system (the first time use since system installed 1 week ago). I rang the electrician who did the installation; he said it must be the units themselves nothing to do with electricity.
Okay, then I rang Fujitsu and their local service agent. They suggested me to switch off C/B for an hour to reset the units. I followed the instruction but the indoor units still did not respond to remote control...
It simply looks like no power supply to indoor units (they are hard-wired to the outdoor unit). So I used a multi-meter to test the power terminals of indoor units (Danger! If you have no idea about this, don't even try! ): it seemed no power supply even C/B is on. I turned to the isolator which next to the outdoor unit. The isolator was making arcing noise when I switched it on and off. The indoor units suddenly turned on for few minutes then died again.
So I figured out the problem is that crooked isolator. I called the unhappy electrician to replace the isolator. End story....
I hope my experience will help you a little bit.
5helpful
2answers
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
5helpful
3answers
Top Heating & Cooling Experts
Paul Carew
john h
