Question about E-Machines eMachines Desktop PC
NEED TO KNOW WIRING
I JUST NEED TO KNOW WHICH PINS ON THE MOTHER BOARD TO PLUG IN THE MAIN POWER SWITCH. MOTHER BOARD IS A FIC AU31, CAN YOU HELP?
  • 36 Answers
I have been to fic's web site, i cannot find any mb labeled au31.
do you have anymore information about the board, how old, which processor, what socket, which north bridge, south bridge, which model system, etc?
however the pins are usually marked "pwr sw" or "pwr" and are usually with all the other front panel connector pins.
Posted on Oct 17, 2007
  • errbelly45 May 06, 2012
    FIC AU31 mb (a.k.a K7m-NF18G mb)
    Pin Configuration = Pinout
    The Front plastic panel of the computer is the Front Panel.
    The area of pins on the motherboard that the cables (Wires) go to, is the Front Panel header.
    Front Panel header pinout.
    The motherboard used in an eMachines T2672 desktop computer is an FIC AU31 motherboard.
    Made by First International Computers (Inc.) for eMachines.
    http://www.e4allupgraders.info/dir1/moth...
    Orient the motherboard like it is in the photo, so we are both looking at it in the same direction.
    {Processor to the top, Ram memory slots to the right, white PCI slots to the bottom. The way it sits in the computer case}
    The Front Panel header, is a small black rectangular block that sits horizontally, at the far right bottom corner.
    It has two rows of pins.
    4 across the top, and 5 across the bottom.
    (The small rectangular block above it, is for connecting a Power On LED light that has 3 wires. More on this in a moment)
    The pins are numbered.
    The pins are numbered Evenly across the top, and Odd across the bottom.
    Starting from the Left side going across to the Right, on the Top row;
    Pins 2, 4, 6, and 8.
    There is No Pin 10.
    Starting from the Left side going across to the Right, on the Bottom row;
    Pins 1, 3, 5, 7, and 9.
    A) Pins 1 and 3 are for the HarDDrive activity LED light. (HDD LED)
    Pin 1 is for the Positive wire ( + )
    (If the LED light is dim when operating, switch the wires around)
    B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used. (Reset button)
    C) Pin 9 is Not Used. (NC. No Connection)
    D) Pins 2 and 4 are for the Power On LED light, IF it is a 2 wire LED light.
    Pin 2 is for the Positive ( + ) wire.
    (If the LED light is dim, switch the wires around)
    If the Power On LED light has 3 wires:
    Use the Power On header above the Front Panel header.
    This rectangular block has 3 pins.
    Starting from the Left side going to the Right; Pins 1 , 2, and 3.
    Pin 1 is for the Positive wire.
    Pins 2 and 3 are Ground wires.
    E) Pins 6 and 8 are for the Power On switch. (Power On button plastic assembly has an ATX power on switch inside it)
    This is a link to a free motherboard manual, for the FIC AU31 motherboard. It is in Zipped file form.
    (A Zipped file is a compressed file. It is used for one, to send a large file over the internet)
    If you do not know how to unzip a file, post in a Comment, and I'll lead you step by step.
    http://www.elhvb.com/mboards/OEM/eMachin...
    In the list on the left side, left-click right on the file name - AU31
  • joecoolvette
    joecoolvette Jan 31, 2013
    I see. So you copied my solution VERBATIM, and attached your name to it. joecoolvette
Retail drivers xp
http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1537
Or is there something I'm missing by the reference - Retail?
All the drivers I pulled up are XPx86.
Means XP and 32-bit version.
What drivers do you need? Post back in a Comment.
The eMachines T2899 Desktop PC uses an FIC AU31 motherboard.
(First International Computers)
Also known as the K7M-NF18G.
This is the download link to the motherboard manual,
http://www.elhvb.com/mboards/OEM/eMachines/manuals/index.html
Click on the blue - FIC AU31 - in the left column.
Regards,
joecoolvette
Dec 16, 2012 | E-Machines T2899 PC Desktop
Need the pin Config for the Motherboard pwr switch and hdd switch for a Emachine T2672 and pwd led thanks
http://www.e4allupgraders.info/dir1/motherboards/socketa/au31.shtml
There is No Pin 10.
For additional questions please post in a Comment.
Regards,
joecoolvette
[ P.S.
The motherboard chipset is an Nvidia Crush 18G + MCP AGP
It is an Nvidia Force 2 chipset,
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_chipsets#nForce2
Supports Processors that are AMD, and fit in a Socket A processor socket.
(Socket A is also known as Socket 462)
Supports AMD processors that have either a 200MegaHertz Front Side Bus, or a 266MHz FSB, or a 333MHz FSB.
AMD Athlon XP processors with either a 266MHz FSB, or 333MHz FSB.
From the 1500+ model up to the 2800+ model.
AMD Duron processors with a 200MHz FSB.
From the 800MHz to the 1.3GHz models
(AMD Athlon XP is the top of the line. Then it's Duron, then Sempron.
A Sempron processor has half of the L2 cache that a comparable Athlon XP does)
Ram Memory is DDR Sdram at either 200MHz, or 266MHz, or 333MHz, or 400MHz.
Depends on the Processor used.
(Ram Memory typically operates at half of the frequency rate ('Speed') that the Processor does.
If the processor's FSB is 333MHz, you can use 400MHz DDR Sdram. {PC3200}
Confusing I know.
DDR Sdram is 'double-pumped'. It is actually 200MHz for PC3200.
This is close to half of 333MHz.
Processor has an FSB of 266MHz? Ram memory used will be 266MHz. Remember, it is actually 133MHz for the ram memory. (PC2100)
Need an AMD Athlon processor?
I found this place years ago. Not advertising for them. Just computer geeks sticking together, and sharing information. (I have bought a motherboard from them, and it works fine),
http://www.weirdstuff.com/cgi-bin/category/10201
Sep 04, 2011 | E-Machines eMachines Desktop PC
I have an old E-machine t3085 and i reformatted it and now i have no internet and can't seem to find the drivers on there site do you knoe where i can get them
The eMachines T3085 desktop computer uses an FIC AU31 motherboard.
(First International Computer, Inc.)
It is also known as FIC K7M-NF18G
http://e4allupgraders.info/dir1/motherboards/socketa/au31_downloads.shtml
{Ethernet}
In case you should ever need them;
Motherboard Specifications:
Jumper Settings:
http://www.e4allupgraders.info/dir1/motherboards/socketa/au31_jumpers.shtml
CPU Support:
http://www.e4allupgraders.info/dir1/motherboards/socketa/au31_cpu.shtml
Motherboard Manual in Zip file form:
Click on AU31 in the left column.
(If you do not know how to unzip a zipped file post back in a Comment for guidance)
Aug 08, 2011 | E-Machines T3085 PC Desktop
I Need the jumper settings for the fic k8mc51g motherboard from a emachines desktop computer. Putting the motherboard in a custom case.
There is a 4-Pin Speaker connector that is not used by Gateway on the motherboard (right beside) the CMOS jumper settings (Pins).
The clear CMOS settings jumper block is right beside the speaker pins. You can use this jumper block to clear the CMOS RAM, which is powered by the onboard real-time clock button cell battery.
Pin 3 is indicated by the markings on the board.
Settings: Pins 1 and 2 covered = Normal Operation Pins 2 and 3 covered = Clear CMOS enabled.crazyeyes746.jpg
Jun 26, 2011 | Computers & Internet
Need wiring connection diagram for Power Switch to Motherboard for EMachine W2925 model. Wires were disconected accidentally while cleaning inside of tower
micha219, the eMachines W2925 desktop computer uses an FIC motherboard.
First International Computer { Inc }
The Model Number of the FIC motherboard is VC37.
FIC VC37.
Disregard the following if you are aware:
The plastic front of your computer is the Front Panel.
The area on the Motherboard that the cables (Wires) from the Front Panel connect to, is the Front Panel header.
Processor to the Top, Ram Memory slots to the Right, the Front panel header is in the Bottom Right corner.
It is a rectangular shape with two columns of pins.
The length goes up, and down on the motherboard.
The pins on the Right side of the Front Panel header are numbered Odd.
The pins on the Left side of the Front Panel header are numbered Even.
There are 4 pins on the Left side.
There are 5 pins on the Right side.
Starting at the Bottom on the Right side going Up;
Starting at the Bottom on the Left side going Up;
A) Pins 2 and 4 are for the Power On LED light.
(If after connecting the LED light is dim, reverse the wires)
B) Pins 6 and 8 are for the Power On switch. (Power On button)
C) Pins 1 and 3 are for the HarDDrive Activity LED light.
D) Pins 5 and 7 are for the Reset switch. (Reset button. IF used)
Pin 9 is NC. Not connected
Oct 18, 2010 | E-Machines eMachines Desktop PC
Install a AU31 E machine Motherboard I need to know exactly where each of the tiny power wires go on the motherboard that controls the power.
from the power supply there's a wires with 16 or more pins / connected as 1. insert the in corresponding socket on the motherboard. on the casing there's a wire that has a label of power or power switch. insert that in the motherboard with an indicator power (pins like)
Jun 02, 2010 | E-Machines eMachines Refurbished EMA...
I have a pc3500g motherboard and need to know where to plug wires
Dear... Mr.A. Ganesh
From Chennai(India)
pin configurations are printed in the mother board.watch carefully .it may be just few inches away from the front panel connector.
Even u cant find it...
you dont worry about it.You just assemble the
Cpu ,SMPS
then switch on the main .
then short a moment( 1second ) at any two pins which is in the front panel connector ( using tester/sqrew driver);continiously cheak like this one by one pair of pin(Verticaly and Horizontaly).
when you short the corrrect pin,then system on.so you can find it like this.then connect the power button easily.
I am 5 years Experienced Engineer. Mother Board should not get any problem doing like this.
Thank you
Feb 12, 2010 | Computers & Internet
Need where pwr sw and pwr led and hdd led plug onto au31 motherboard
Here is a link for the manual for your au31 motherboard. The diagram explaining the front panel headers is on page 12.
http://www.lurkhere.com/~nicefiles/AU31_manual.pdf
Dec 02, 2009 | E-Machines T3092 PC Desktop
Need help with motherboard power connection wiring.
i have no mother board cd then system is formatting is not possible please help me i want drivers cd
Apr 11, 2009 | Compaq Computers & Internet
MY MONTOR HAS POWER AND IS NOT WORKING.
Hi, dont loose faith. If you look on your mother board along the edge closest to the front of the case you will see a series of pins, usualy about 10 pins. Printed on the board will be the names of the plugs that match. The wires from the front of the case have corresponding names. The power and reset switch will work no matter witch way around you put them. The HDD led and the pwr led will only work one way so if these lights dont work, just reverce the plugs. If desperate you can bridge two pins together at a time until you get the on/off switch. Note you cant hurt anything unless you use a hammer. Regards mistyman
Sep 03, 2007 | FIC FR33E Motherboard
E-Machines eMachines Desktop PC Logo
172 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
