Question about Thermasol Steam Bath Generators - Ambiance Pro - AMBPRO
Thermasol classic won't reset after power flush
Button stuck
Please remove the unit from any power. Once you have, please replace the unit to find that the button is no longer in the stuck position. Please do not attempt to troubleshoot the button when and IF any power is being applied.
Jan 09, 2011 | Thermasol Steamshower Generator Classic...
TTMPL code showing on my Signature series control panel. ???
I have a Thermasol steam generator which had the error code TTMPL and it had to be replaced by the manufacturer. From memory, the error code might stand for "tank temperature monitor pressure low" or something similar. As an aside, the replacement generator just started to show the same error message -- so now I'm two for two -- and not entirely happy.
Jan 16, 2010 | Thermasol Steam Bath Generators - Ambiance...
Power flush problems Pro 240 -locked out at 1000hrs
This is a communication error please contact Thermasol tech support at 800-776-0711 and we can help you out.
Dec 19, 2009 | Thermasol Steam Bath Generators - Ambiance...
LCD shows TTMPL and steamer doesn't work. The model is SET-NTS-SN of Thermasol Signature series.
Funny, mine starting displaying the same thing around the same time. I contacted Thermasol and apparently the temperature sensor in the generator unit is malfunctioning and needs to be replaced. They're sending one to me, i'll let you know if it works.
Dec 14, 2009 | Thermasol Signature Series Control...
ThermaSol, Elite - Error 5, can this be corrected without a service call? How?
look in the ubser manual. it should tell you what the error is how to reset it.
Nov 01, 2009 | Thermasol Elite Control Package
Steam generator will not activate- thermasol model ASD300A
how do you know the unit has power?
what control do you have?
does it light up.
Mar 15, 2009 | Thermasol Steamshower Generator AF Series...
Thermasol Pro 150 - 25094. Doesn't work. I have a very simple controller. Just a gib gray button and four other led lights near the 15 , 30, 45, and 60 lights to set the time. I think I need to do the auto...
yes thats correct or if you have manuel flush at the genrator there is a ball valve. open for minutes then close and run generator for thirty minutes without anyone in the shower.
Mar 12, 2009 | Thermasol Steam Bath Generators - Ambiance...
Thermasol steam generator constanly taking on water
the water feeder leaking and you will need a new one call 800 776 0711
Feb 06, 2009 | Thermasol Steamshower Generator AF Series...
Thermasol Steam Bath Generators - Ambiance Pro - AMBPRO  Logo
52 people viewed this question
Top Thermasol Electrical Supplies Experts
woodzowl307
Jim Goldsmith
Jim Goldsmith
Are you a Thermasol Electrical Supply Expert? Answer questions, earn points and help others
