Question about Mitsubishi WD65835 65" HDTV
Picture is getting more dim every time i turn tv on
Very dim picture
Should I fix my TV or buy anew one?
Before you buy a new TV go through all the TV menu options to see if it has automatic dimming depending on the amount of light in the room. If it does it may be malfunctioning and turning that feature off may fix the problem.
May 29, 2016 | Samsung 6030 Series UN46FH6030 46" LED TV...
Picture dimmed. can see the picture and in menu increased the backlight to max but did not go back to normal. checked eco settings and did factory reset. still very dim but can see the picture.
Yah kindly follow this tip. After loosing the back cover when the tv power cord is removed from power socket, check for bulged or defect power capacitors in both the primary & secondary side of the power pack if found any kindly replace it with the actual or equivalent value as this electrolytic capacitor defects is much common for Samsung power packs
Apr 04, 2016 | Samsung UN46EH5300 - 46" LED-backlit LCD...
Update tv
Go to settings on the TV menu. It should be under picture and you can change the picture mode and auto dimming setting from ON to OFF...if you want to do an update.. then go to Sonys website .. key in your model number ..look for firmware updates then download this file onto a formatted USB flash drive.. remove and insert into TV and when turned on the set should pick up the update automactiaclly
Jan 09, 2014 | Sony BRAVIA KDL-32S5100 32 in. LCD HDTV
Turn set on picture is dark.. if I leave the TV on.. in several hours it's viewable.
I have seen several Samsung's including 3 that were only a few months old at the time where it was the lamp---one was so dim it was very hard to even see the picture or that the screen was lit.
Two suggestions here: One of course would be to buy and gamble and replace the lamp.
What I found in two of the three cases was when I removed the lamp the glass pillar inside it was "bent" at a angle from heat or a natural defect--in both those cases a new lamp cured this dim picture issue.
Set will monitor the lamp and if too dim may shut set off or even blink for a prolonged period of time.
If the lamp is over 2 years or age (average life) or was replaced with a non-Samsung lamp you are going to have to take the gamble to try another one.
Inspect the lamp---that pillar supports the filament and if bent the lamp is suspect at best.
May 20, 2012 | Televison & Video
Dark picture on wega lcd
Yes, if this TV has a bulb it is likely to be the bulb.
I am not familiar with this exact model, but other LCD Projection TV will show dim picture after some time. Expected life of the lamps is about 2yrs. After 2yrs the picture will become dim. After 5yrs I am suprised it is even working.
Dirt doesn't cause this problem unless your are a smoker or have the unit "literally" outside. DO NOT try to clean it or let someone tell you to do it because it will cause more problems than it fixes.
May 07, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
It will lock up and not turn on
check caps in power supply for bubbled tops and replace.
Mar 18, 2009 | RCA L26WD12 26 in. LCD TV
Tv gets bright and then get dim and dose this the entire time tv is on
If you watch a DVD, does the picture also flash? If not, it might be just the TV signal. Are you using a cable/satellite receiver? If so, check it's connections. If anything viewed on the TV, using different inputs and a different cable/wire, is flashing, it is a problem with the light engine or color wheel, if the TV is DLP.
Oct 17, 2008 | Sony KP-61XBR48 61" Rear Projection...
Tv dimming
It is probably time to replace the lamp. Be sure to buy an original Sony lamp, as the aftermarket replacement lamps are known to have issues. If you liked this answer be sure to rate it. Thanks!
Jul 16, 2008 | Sony KDS-60A2020 60" HDTV
Sony kp-65xbr10w led light blinks 5 times
i have a sony tv model kv36fs17. led flashes 5 times. tv works but no red color. would could be the problem? thanks
Jan 23, 2008 | Sony KP-65XBR10W 65" Rear Projection...
Mitsubishi WD65835 65" HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
