Question about Acer Computers & Internet
My acer TravelMate 4270 will not start up with a generic battery. I can switch to battery once the machine is started from the mains power. Is there anything I can do?
  • rogan902 May 18, 2009
    the battery is brand new and the laptop is nearly 3 years old
    Thanks Geekman
    The battery works just fine when I turn on the computer using the mains power but the computer will not let me turn on the using only the battery. It gives a warning saying that I should insert the correct battery and then shuts down.
    Rogan
  • Acer Master
  • 32,281 Answers
How old is the battery and laptop?
Posted on May 18, 2009
  • Chris Hingee
    Chris Hingee May 18, 2009
    A new battery that has been on the shelf for some time needs to be charged and discharged several times before it can achieve its full amp hour capacity. Make sure you fully discharge the battery before you charge it up to full capacity. Do not charge the battery from a half discharged state.
  • Chris Hingee
    The laptop will run with or without a battery as long the adapter is connected to the mains supply.
    Is the new battery an exact replacement from the laptop manufacturer?
    The new battery could be faulty, try it in another laptop or get it tested from the shop where you purchased it from.
    If the tested battery is OK then there is a problem with the charging circuit in the laptop.
I have acer travelmate 800 series,the notebook stopped working so i bought a new motherboard and power switch still the laptop will not start. it is getting power but wont start, i have tried taking out...
Have you tried powering it up without any periferals?? take out the RAM, HDD, WIFI, CD, etc... I've seen a BAD wireless network card preventing the system to power up... if it seams to power up than put back stuff in one by one starting with the RAM to see what periferal is causing the problem... If not than it could be the CPU...
Good Luck!
Mar 25, 2011 | Acer for Acer TravelMate 800 Series...
It wont run of the mains, it will charge the battery and then run but once i start up it runs of the battery even if plugged in to mains
The power supply adapter needs to be checked to make sure it is putting out the full rated power under load.
Feb 14, 2011 | Acer TravelMate 2702WLMi Notebook
Acer Travelmate 4060. Dead. Flashes power/battery led once when I hit the power button then nothing
Try removing the battery and plugging the machine in as if you were going to charge it, then try starting it up.
If it doesn't start up, check the connections on the adapter. If everything looks fine then theres a possibility that you have a broken adapter.
Mar 30, 2010 | Acer Aspire 4520-5582 Notebook
Acer 4650 Travelmate Black screen
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer TravelMate 3260-4874 Notebook
Generic computer won't boot up
Have you tried removing the main battery and the cmos battery for about 30 minutes?
Jan 22, 2009 | Acer TravelMate 2300 Notebook
Acer travelmate 2300 - power on but as if BIOS did not start
Open the memory cover from bottom of the laptop if you can find. And re-plug the memory chips carefully..make sure it be plug in properly. and try switch on again.
Nov 05, 2008 | Acer TravelMate 2300 Notebook
My Acer travelmate only works from battery not mains
Most likely the power plug has come loose off the motherboard. Unless you are extremely handy with a soldering and desoldering iron, I recommend taking it to a professional to do it because one wrong move can destroy the whole motherboard.
Jun 21, 2008 | Acer TravelMate® 4062WLCi...
Acer Travelmate 4270
ive got the same model. mine gets damn hot too. especially after about 4hrs you can barely type on it or use the mouse pad.
i sent it back as soon as i got it. acer replaced the fan and said it was fine. 4hrs later it was running as hot as before. they probably did nothing but waste my time for 2 weeks. just poor design i spose. poor cooling system poor design. i also noticed the fan air vent is on the right hand side. again poor design, most people are right handed. getting hot air blown on your hand when using an external mouse, during a hot summer day is not pleasant. dont think ill buy an Acer again
Nov 10, 2007 | Acer NSK8458AN Keyboard
Help to repair ACER Travelmate 290LCi
this is normally motherboard or powe side problem check your motherboard
Oct 19, 2007 | Acer TravelMate 290LCi Notebook
Acer travelmate 270
I had the same problem and it was my battery - i would strongly suggest getting a new one, doesnt need to be an ACer - it could even be a generic one- just as effective.Try www.cellphoneshop.net, they sell cheap batteries.
Aug 31, 2007 | Acer TravelMate 270XV Notebook
Computers & Internet Logo
125 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
